1 Reply Latest reply on Aug 10, 2018 2:04 AM by fonzieelanimal
    Please help me with his problem xD
    fonzieelanimal
      Hello, the problem is that it does not matter how you render this video, so it trembles, I've tried everything. It comes from another rendering done in Sony Vegas but in Premiere (version CS6) I can not stop shaking, both in the preview and in the video already rendered. More than anything in the subtitles Here I leave the video. See more than anything the problem is in the subtitles, Sony Vegas previously.
      https://youtu.be/jhomPG0EwC0
      And here the specifications of both videos
      Original video
      General Full Name: C: \ Users \ Fonzie \ Desktop \ Agus \ UCF \ 1 - Low Self-Esteem Chronicles - UCF.mp4 Format: MPEG-4 Profile Format: Base Media / Version 2 Codec ID: mp42 (isom / mp42) File size: 10.1 GiB Duration: 1 h 12 min Bit rate mode: Variable General bit rate: 20.0 Mb / s Coding date: UTC 2018-05-12 19:45:14 Labeling date : UTC 2018-07-25 01:30:00 Video ID: 1 Format: AVC Format / Info: Advanced Video Codec Profile format: High@L4.2 Format settings: CABAC / 1 Ref Frames Format adjustments, CABAC: Yes Format settings, RefFrames: 1 frame Format settings, GOP: M = 1, N = 30 Codec ID: avc1 Codec ID / Info: Advanced Video Coding Duration: 1 h 12 min Bit rate: 19.8 Mb / s Width: 1 920 pixels Height: 1 080 pixels Aspect ratio: 16: 9 Frame rate mode: Constant Frame rate: 59,940 (60000/1001) FPS Color space: YUV Chroma subsampling: 4: 2: 0 Bit depth: 8 Ti bits po swept: Progressive Bits / (pixel * frame): 0.159 Track size: 10.0 GiB (99%) Language: English Date of coding: UTC 2018-05-12 19:45:16 Tagged date: UTC 2018- 05-12 19:45:16 Audio ID: 2 Format: AAC Format / Info: Advanced Audio Codec Profile Format: LC Codec ID: mp4a-40-2 Duration: 1 h 12 min Type of bit rate: Variable Rate of bits: 192 kb / s Maximum bit rate: 507 kb / s Channel (s): 2 channels Channel positions: Front: LR Sampling rate: 48.0 kHz Frame rate: 46,875 FPS (1024 SPF) Compression mode : With loss Track size: 98.5 MiB (1%) Language: English Coding date: UTC 2018-05-12 19:45:16 Tagging date: UTC 2018-05-12 19:45:16
      Rendered video (the uploaded to Youtube)
      General Full Name: C: \ Users \ Fonzie \ Desktop \ Agus \ Sequence 01 (1080p_60fps_H264-128kbit_AAC) .mp4 Format: MPEG-4 Profile Format: Base Media Codec ID: isom (isom / iso2 / avc1 / mp41) Size file: 9.70 MiB Duration: 22 s 13 ms General bit rate: 3 697 kb / s Movie: Sequence 01 Performer: Fonzie Recording date: 2018 Coding application: Lavf58.13.102 Comments:
      [youtube] jhomPG0EwC0 [/ youtube]
      Video ID: 1 Format: AVC Format / Info: Advanced Video Codec Profile format: High@L4.2 Format settings: CABAC / 2 Ref Frames Format settings, CABAC: Yes Format settings, RefFrames: 2 frames codec ID: avc1 ID codec / Info: Advanced Video Coding Duration: 21 s 950 ms Bit rate: 3 571 kb / s Width: 1 920 pixels Height: 1 080 pixels Aspect ratio: 16: 9 Frame rate mode: Constant Frame rate: 60,000 FPS Color space: YUV Chroma subsampling: 4: 2: 0 Depth bits: 8 bits Sweep type: Progressive Bits / (pixel * frame): 0.029 Track size: 9.34 MiB (96%) Color range: Limited Primary colors: BT.709 Transfer characteristics: BT.709 Matrix coefficients: BT.709 Audio ID: 2 Format: AAC Format / Info: Advanced Audio Codec Profile format: LC ID codec: mp4a-40-2 Duration: 22 s 13 ms Bit rate type: Constant Bit rate: 126 kb / s Channel (s): 2 channels Channel positions: Front: L R Sampling rate: 44.1 kHz Frame rate: 43,066 FPS (1024 SPF) Compression mode: With loss Track size: 337 KiB (3%) Language: English Default: Yes AlternateGroup / String: 1
      [title edited by mod]
