1 Reply Latest reply on Aug 10, 2018 5:51 AM by Amit_Kumar
    How to Delete GDPR Records Automatically.
    nikitap46765450 Level 1
      I am trying to delete GDPR records, by default 2 step process is activated.
      Because of which every record gets deleted only after confirming delete.
      How to override confirm delete setting of GDPR & automatically delete records.
      I have tried below code. Provided in following link :
      Campaign Classic - General Data Protection Regulation
      Even after using following code records doesn't get delete automatically, It remains in confirm delete pending state.
      What can be the issue?
      loadLibrary("nms:gdpr.js");
      This code calls an API to create new Privay request on the DB
      It requires 4 parameters below
      Feel free to change parameter values
      // 1. namespace internal name
      var namespaceName = "defaultNamespace1";
      // 2. reconciliation value for privacy request
      var reconciliationValue = "example@adobe.com";
      // 3. privacy request type
      // GDPR_REQUEST_TYPE_ACCESS = 1;
      // GDPR_REQUEST_TYPE_DELETE = 2;
      var requestType = GDPR_REQUEST_TYPE_ACCESS;
      // 4. confirm deleting data required
      // value : true or false
      var bConfirmDeletePending = true;
      // BEGIN
      var requestId = nms.gdprRequest.CreateRequestByName(namespaceName,reconciliationValue, requestType, bConfirmDeletePending);
      // User can use a simple queryDef with requestID as a parameter to check request status
      Thanks.
