Hi guys,
I do have an issue with splitting PDF document into separate files using "Top level bookmarks", so I followed all the steps include Output Option and using "use bookmarks names for file names". But I still have them split into one.
Is there any help PLEASE?
I use Adobe Acrobat Standard DC.
There's only one top-level bookmark in this file, so that's what you get when you process it...
You need to either move the sub-bookmarks to the top-level, or use a script to do it, like this (paid-for) tool I've developed which can export each section based on the lowest-level bookmarks: Custom-made Adobe Scripts: Acrobat -- Extract Lowest-Level Bookmarks
What kind of action is associated with the bookmarks?
If you use bookmarks option, means any file with multiple pages are going to split up to many separate files which keep their proper bookmarks names.
In my case after making the split all the files went into one file. Which is nothing happened.
You didn't answer my question... Right-click one of the bookmarks and select Properties, then go to the Actions tab. What kind of action is associated with it?
Hi Sir, thanks for showing that,
The action is "Go to a page in this document"
In that case it should work... Can you share the file in question (via Dropbox, Google Drive, Adobe Send & Track, etc.)?
I was trying to send the PDF file via Adobe. and here is but I am not sure if I did correctly.
Also I delated some of the file content it is belong to the client.
Thanks Try67
I works perfectly after I moved all sub-bookmarks as bookmarks, and delated the empty previous main one.
try67ā@
