1 Reply Latest reply on Mar 28, 2008 7:29 AM by kdennis4
    Channel Connection Failed  HTTP 405
    kdennis4
      I've got the -services-config.xml set up and pointed to complie in Flex, but I'm getting these errors:
      Send failed - then I hit "OK"
      Channel.Connect.Failed error NetConnection.Call.Failed: HTTP: Status 405: url: ' http://mySite.com/flex2gateway/'
      I've read several posts and created a new channel that does not point to the "localhost:port" and channel-definition id. It looks something like this:
      <endpoint uri=" http://mySite.com/flex2gateway/" class="flex.messaging.endpoints.AMFEndpoint"/>
      I'm using Flex 3, so I don't know if there is any issues with it. Any suggestions would be greatly appreciated!
        • 1. Re: Channel Connection Failed  HTTP 405
          kdennis4 Level 1
          Found the problem. In case anyone else runs into this issue:
          On your Server you need Coldfusion version 7.0.2 at the minimum. When you goto the URL of http://x.x.x.x/flex2gateway in a web browser you should get a white blank page. Also make sure that you have a tab within the CF Administrator under Data & Services called Flex Intergration. I have had these same issues and found that my Production Server did not have the Flex Intergration so I had to Uninstall CF7 and ReInstall 7.0.2 to get the Flex Intergration.
