confirm that you can connect to the secure adobe servers by reading, http://helpx.adobe.com/x-productkb/policy-pricing/activation-network-issues.html
do you see both logos?
Yup can see them both sorry for the late reply
Check your Hosts file :
Resolve connection errors with Adobe Creative Cloud and Creative Suite applications
There are no adobe related entries in the host file and the server authentication is already enabled
if you still see the same message from your cc desktop app, are you behind a corporate firewall?
i dont think so kglad​
Username refers to your Windows session name .
Check your permissions access to the temp folder or you can rename the existing one and create a new one with with the same name "Temp" in the same location:
C:\users\username\AppData\Local\
Username???
arij2010​ the ck_ash one???
Normally this one .
where is it sir arij2010​
Username for you is "ck_ash" .
arij2010​
I do not understand, you do not know how to go to a path on your machine? You double click on AppData then double click on Local and there renames the folder "Temp" then creates a new folder and renames it in "Temp" then reboot your machine .
arij2010​.There is no temp folder it goes on like this "CK_ASH>AppData>Local>Microsoft>Inputpersonalization>TextHarvester"
Normally in Local folder you should have a Temp folder , an Adobe folder and more .I think this is not the right session .Try to make a search for the Temp folder on your machine .
Is it this one arij2010​???
When the search is finished you can see the folder path ,Go back to the search result to see that .
Then wut will I do with the temp folder? arij2010​
When you are on the location that contains "Temp" folder ,renames the folder "Temp" then creates a new one and renames it in "Temp" then reboot your machine .
So I will rename the folder Temp to "Temp" then i will create a new folder then name it Temp?????
or will i need to delte the temp folder first then create a new one and name it temp?
Rename the folder Temp to "Temp.old" then create a new folder then name it Temp
ohhhh okay wait wait ill try it
