• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Get FindChange query data
Explorer ,
Aug 12, 2018 Aug 12, 2018
Hi Experts,
I want to get all the saved queries in Find/Change.
Query names and their query data, i.e replace text, find text...etc
Only thing I could find was IFindChangeOptions but it does not have classes related to queries.
Can you please help me.
TOPICS
SDK
Views
806
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Aug 12, 2018 Aug 12, 2018
Hello ddarz4u​,
I also could not find any way in the C++ sdk to get this list. It seems this is not meant to be accessible by a direct api call. However i have a way to achieve what you need, the custom queries are saved as XML files, you can parse these files and then load a particular query(could not find a C++ sdk to do the same directly). So you could traverse the folder location where the custom queries are saved, use it to get the list of all the queries(file name is displayed in the File C
Votes
Translate
Translate
Community Expert ,
Hello ddarz4u​,
I also could not find any way in the C++ sdk to get this list. It seems this is not meant to be accessible by a direct api call. However i have a way to achieve what you need, the custom queries are saved as XML files, you can parse these files and then load a particular query(could not find a C++ sdk to do the same directly). So you could traverse the folder location where the custom queries are saved, use it to get the list of all the queries(file name is displayed in the File Change dialog). The you can parse the XML file to set the appropriate interfaces to make the find change query, and execute it. Let me know if you find a direct API to load query as present in the JS api, alternatively you could call the JS code from C++ plugin.
Look at the load queries section in the following URL to get the locations at which the custom queries are saved
https://helpx.adobe.com/in/indesign/using/find-change.html#find_change_items_using_queries
Hope this helps.
-Manan
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Aug 13, 2018 Aug 13, 2018
Manan is right, there's no straight api to load the query names, it's a manual work. But once you get the IDFile queryXMLFile, load query with command
kFCQueryXMLReaderCmdBoss
InterfacePtr<ICommand>queryCmd(CmdUtils::CreateCommand(kFCQueryXMLReaderCmdBoss));
InterfacePtr<ISysFileData> sysFile(queryCmd, UseDefaultIID());
sysFile->Set(queryXMLFile);
CmdUtils::ProcessCommand(queryCmd);
Then you can use IFindChangeOptions to get the options data, example:
InterfacePtr<IFindChangeOptions>pFindChangeOptions((IFindChangeOptions*)::QuerySessionPreferences(IID_IFINDCHANGEOPTIONS));
WideString findString = pFindChangeOptions->GetFindString(IFindChangeOptions::kTextSearch);
WideString replaceString = pFindChangeOptions->GetReplaceString(IFindChangeOptions::kTextSearch);
Votes
Translate
Translate
Report
Report
Community Expert ,
Thanks for the insight Alo, i missed the command (the chm search has its own idiosyncrasies )
Votes
Translate
Translate
Report
Report
Guide ,
Aug 14, 2018 Aug 14, 2018
Hello,
From jsx, app.loadFindChangeQuery.
P.
Votes
Translate
Translate
Report
Report
Explorer ,
Thanks Pickory​​
To get this, we should have to have query names list?
Votes
Translate
Translate
Report
Report
Guide ,
LATEST
Hello,
For the docs.
void  loadFindChangeQuery (queryName: string, searchMode: SearchModes)
Value
NameDescriptionValue
SearchModes.GLYPH_SEARCHGlyph search.1181183091 = 'Fgls'
SearchModes.GREP_SEARCHGrep search.1181184627 = 'Fgrs'
SearchModes.OBJECT_SEARCHObject search.1181704819 = 'Fobs'
SearchModes.TEXT_SEARCHText search.1182038131 = 'Ftxs'
Usage
In function
void  Application.deleteFindChangeQuery (queryName: string, searchMode: SearchModes)
void  Application.loadFindChangeQuery (queryName: string, searchMode: SearchModes)
void  Application.saveFindChangeQuery (queryName: string, searchMode: SearchModes)
Votes
Translate
Translate
Report
Report
