3 Replies Latest reply on Aug 12, 2018 1:50 PM by carlosz13485882
    Keyframing HELP
    maggies84133902
      Hello, every time I try to toggle animation I get the message "This action will delete existing keyframes. Do you want to continue?" What do I do???  I can not do any effects with this problem!
        • 1. Re: Keyframing HELP
          Meg The Dog Adobe Community Professional
          Why are you toggling the Animation on and off? You only need to do this once, to turn on keyframe animation. Once it is toggled on, you add additional keyframes via the Add/Remove Keyframe button:
          Once you have keyframes for the animation, clicking on the Animation toggle will potentially remove any keyframes you have for that parameter - which is why you get the warning.
          MtD
          • 2. Re: Keyframing HELP
            rodneyb56060189 Level 4
            I think what you want to do is
            1) adjust keyframe to make it do what you want
            or
            2) delete keyframe ..which will throw off the others in terms of the 'curves' already created...but you can then add another one and try to fix your problem.
            It's hard to do... to make the timing and motion and opacity or whatever the keyframe is doing to behave properly but with patience and choices ( ease in, ease out, Bezier, etc. ) it can be done.
            good luck !
            • 3. Re: Keyframing HELP
              carlosz13485882 Adobe Community Professional
              To add to what MTD said, you only have to toggle the animation for a certain property once,
              then when you move in the timeline (both the effects control timeline or the actual timeline),
              and change the value for that property you toggled the animation for, this will automatically
              create a new keyframe with the new value. Your animation will play between those 2 keyframes.
