I am converting MS Word documents to PDF via ES4 PDF generator. Input documents contain track changes(TC) (red lines,backline .).
1st case
Converting .doc via PDF generator, PDF result doesn't contain track changes.
2nd case
Converting .doc via MS Word via Acrobat addon, PDF result contains track changes. (MS WORD and Acrobat installation is on the same server like PDF Generator)
Perhaps I've tried all possible combinations of settings FileType and AcrobatPDF in adminui, but nothing works.
Can you please give me some advice what has to be done to get TC in PDF result?
This issue is similar to
LiveCycle not showing Word Redlines
Solved! Go to Solution.
Views
Total Likes
You can switch this on:
Depending on how you're generating your PDF's this might not work for you. If you're using a process that specifically chooses from the various settings to use then you'll have to modify what that is choosing and you may not want to change the default at all after you create the new settings. I'll leave that to you.
Past that, I hope this gives you the results you're looking for.
Views
Total Likes
Views
Total Likes
