2 Replies Latest reply on Aug 13, 2018 11:55 AM by fonrig
    How to determine if a page is blank?
    fonrig Level 1
      Trying to create a script to determine if a page is blank.
      Been thinking on scrolling through the BodyPage collection but not sure how to link that to the actual flow.
      Any ideas I can start with?
      Thanks.
        • 1. Re: How to determine if a page is blank?
          frameexpert Level 4
          I use a series of dependent functions to determine if a page is empty. The example here tests the current page, but you can expand it to test all of the pages in a document. Note that this code considers a page empty if there is nothing in its Flow A text frame. Technically, there could be other text frames or graphics directly on the page and this script doesn't check for this. But in most cases, you are looking for a page with nothing in its Flow A text frame so this will work fine. Please let me know if you have any questions or comments.
          #target framemaker
          var doc = app.ActiveDoc;
          // Test the current page.
          var page = doc.CurrentPage;
          // true for empty; false for not empty.
          alert (pageIsEmpty (page));
          function pageIsEmpty (page) {
              var textFrame;
              textFrame = getTextFrame (page, "A");
              if (textFrame) {
                  if (textFrameIsEmpty (textFrame) === true) {
                      return true;
              return false;
          function getTextFrame (page, flow) {
              var frame, graphic;
              frame = page.PageFrame;
              graphic = frame.FirstGraphicInFrame;
              while (graphic.ObjectValid () === 1) {
                  if (graphic.constructor.name === "TextFrame") {
                      if (graphic.Flow.Name === flow) {
                          return graphic;
                  graphic = graphic.NextGraphicInFrame;
          function textFrameIsEmpty (textFrame) {
              if (textFrame.LastPgf.ObjectValid () === 1) {
                  return false;
              else if (textFrame.LastCell.ObjectValid () === 1) {
                  return false;
              else if (textFrame.LastAFrame.ObjectValid () === 1) {
                  return false;
              else if (textFrame.LastFn.ObjectValid () === 1) {
                  return false;
              else {
                  return true;
          • 2. Re: How to determine if a page is blank?
            fonrig Level 1
            Thanks Rick, this works perfectly. You definitely are the FM Scripting master. Others please don't take offense, you're pretty good too.
