hi everyone
this is rana.
i have a million files of pdf color scan document and i want to convert them into black and white to save the space.
i have already tried with (Action...automate and batch) thing.
in batch process i have two problem
1: photoshop only accept max 50 pdf file color scan pic and my every pdf file have more than 5 color document in each.
i want change this to 150 pdf file per batch proccess...50 pdf file is not enough.when i open more than 50 pdf file its say you have open too many file close window.
2:when photoshop accept the 50 pdf file its show every file one by one and all color scan document pic in pdf file show and i have to select all the pic in one pdf file to convert into black and white......i have to do this step again and again with every pdf file till 50.then i start bath process .this is so much time cunsuming.
i only wanted that every color scan document in pdf file is auto select till 50 pdf file.
i d`not want repeat again and agian same step to select color document in every file.
3: also want photoshop auto deselect the blank page..
any solution for these 3 problem
help me
You can use Acrobat Pro to convert these documents. It's easy and powerfull.
Just go to Tools menu, select Print Production tools and finally use Preflight command. Select Convert to black and white or grayscale and do it witch batch process
pawel
Hi pawel
can u explain more deep.if any video link its very helpful or screen shot.
i have PDF file of color scan pic and change BW pic...but remain same PDF file.
Acrobat Pro auto select all Pdf file data or not.
what a maximum PDF file i can open Acrobat Pro for batch process.
i have two issue open files Second again and again all file pic select in every file.
if i use Acrobat Pro my these 2 problem will be solved or not.
kindly tell me this....this is 2 main issue for me..
with this 2 problem i`m only able to process 2500 pdf file per day in duty hour.
