Is it possible to have a text box or a drop down box that can be changed by a second, third ... person that should sign the document?
E.g. the first person makes a comment or chooses a value from the drop down box and the next person would like to change / comment what the first person has done.
Hi Christiand,
Sorry as it is not possible.
Once the form fields filled and sent by the first user, it will get disabled for the next user/signer.
However, there is a workaround that you may try.
When you add the form fields for the user and you may set the default value for the fields.
Then assign that field to the user who needs to change/comment on that field.
Check if that works for you.
Let us know if you need any help or have any question.
Regards,
Meenakshi
Hi Christiand,
Regards,
Meenakshi
