4 Replies Latest reply on Aug 14, 2018 12:52 PM by TexasErin
    XMP presets won't select
    claudias17325289
      Hello, Wondering if anyone is able to help a clueless girl trying to use Lightroom?
      I downloaded some Presets from a blogger i follow and they are showing up in my downloads as XMP files. However when i go to import them from my documents/downloads (i have tried moving them to different locations) they show up but won't let me select them? They also sometimes show up still with an internet icon on the left hand side?
      Could anyone please tell me what i should do/am doing wrong ?
      Claudia x
        • 1. Re: XMP presets won't select
          Mohit Goyal Adobe Employee (Admin)
          Hi claudias,
          Could you please let us know the exact version of Lightroom you are using now? If you are using Lightroom 7.3.1 and later version then, you can import the presets within the Lightroom.
          Refer the below screenshot.
          Regards,
          Mohit
          • 2. Re: XMP presets won't select
            TexasErin Level 2
            I have better luck pasting the presets into the appropriate folder. Using the Import dialog doesn't always work, depending on how the maker organized them.
            Go to Preferences (LR menu on Macs, Edit on PCs), click on the Presets tab, and then click on "Show LR Presets Folder." Paste the presets into the appropriate folder (Develop, Local, Print, etc.). If you aren't sure, they are probably Develop presets.
            • 3. Re: XMP presets won't select
              JohanEl54 Adobe Community Professional
              That button leads to the old presets folder. If the OP is using Lr Classic 7.3 or higher, and the presets are already in the new XMP format, then that is the wrong folder.
              • 4. Re: XMP presets won't select
                TexasErin Level 2
                Good point!
                Are the presets in zipped folders? They shouldn't be. And are you trying to import folders of presets or individual presets?
                Try navigating to the proper folder to paste them there. The new folder location on Macs is:
                User>Library>Application Support>Adobe>Camera Raw>Settings. You can paste unzipped folders inside this folder, or paste individual presets inside the User Presets folder.
                Not sure what the Windows equivalent is but you can search for Camera Raw or Settings to locate it.
                Does that help?
