2 Replies Latest reply on Apr 23, 2008 7:53 AM by dark_coder
    getURL button not working
    dark_coder
      I need some serious help or maybe a can of redbull. Im using external swfs to load into an empty movieclip in an index.swf. Thhe links to each swf work fine tested both locally and uploaded. The problem is that ive got a button inside one of the external swf's that uses the code below:
      adobe_btn.onRelease = function(){
      getURL(" http://www.adobe.com/products/flash", "_blank");
      as you can see nothing fancy just a normal button. The problem is that tested on its own the button works fine but when I load it from the index.swf its not working. I dont know what else to do as im sitting in the corner whispering things to myself. Any help will be great
