• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Suppress error window
Advocate ,
Aug 15, 2018 Aug 15, 2018
with photoshop cc2018
This error is coming out of me
do not get any errors with photoshop cc2014?
how to suppress this error?
TOPICS
Actions and scripting
Views
2.7K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
People's Champ ,
Make your skript so.
Show an error message.
try {
    // you script code here
catch(e) { __alert(e); }
function __alert(e)
    if (e.number != 8007)
        var fname =  File.decode(File(e.fileName).name).toLowerCase();
        var func = "";
        try {
            if ($.stack)
                var stack = $.stack.split("\n");
                func  = "Call:\t" + stack[stack.length-3]+"\n\n";
        catch (e) { }
        var source = "";
        try {
            if (e.source)
                source = e.source.split("\n")[e.line-1];
                source = source.replace(/^\s+/g, "");
                source = source.replace(/\s+$/g, "");
                source += "\n\n";
        catch (e) { }
        var msg = e.message + "\n\n";
        var dsc = e.description + "\n\n";
        if (dsc == msg) dsc = "";
        alert("File:\t" + fname  + "\n\n" + func + "Line:\t" + e.line + "\n\n" + source + "Error: " + e.number + "\n\n" + msg + dsc, "Bug!", true);
Votes
Translate
Translate
Report
Report
Advocate ,
r-bin
the script consists in adapting the form to the immegine
the problem is that if the form does not exist, there is an error
// script
try {
var doc = activeDocument;
doc.activeLayer = doc.layers[0];
var LB = doc.activeLayer.bounds;
var docHeight = doc.height;
var docWidth = doc.width;
if(doc.height>doc.width){
var LHeight = Math.round(LB[3].value) - Math.round(LB[1].value);
var LWidth = Math.round(LB[2].value) - Math.round(LB[0].value);
if(LWidth> LHeight) activeDocument.activeLayer.rotate(90);
if(doc.height<doc.width){
if(LWidth<LHeight) activeDocument.activeLayer.rotate(90);
var perWidth = ((docWidth/LWidth)*100);
var perHeight = ((docHeight/LHeight)*100);
doc.activeLayer.resize(perWidth,perHeight,AnchorPosition.MIDDLECENTER);
doc.activeLayer.translate((0-LB[0].value),(0-LB[1].value));
function __alert(e)
        var func = "";
        try {
            if ($.stack)
        catch (e) { }
        var source = "";
        try {
            if (e.source)
                source += "\n\n";
        catch (e) { }
Votes
Translate
Translate
Report
Report
People's Champ ,
In the beginning, put
app.displayDialogs = DialogModes.NO;
Votes
Translate
Translate
Report
Report
Advocate ,
I tried your solution
  1. app.displayDialogs = DialogModes.NO;
but photoshop crashes and I have to close it
Votes
Translate
Translate
Report
Report
People's Champ ,
It's strange.
Run this script.
try
catch(e) { alert(e); }
Show the message.
Show the structure of the layers in the document.
Votes
Translate
Translate
Report
Report
Advocate ,
I get this error
Votes
Translate
Translate
Report
Report
People's Champ ,
Well, it's all right.
Most likely the crash was caused by the __alert() function on your MAC. I can not check.
Now replace
catch (e) {alert (e); }
to
catch (e) { }
Votes
Translate
Translate
Report
Report
People's Champ ,
geppettol66959005
I get this error
In this case, was there a crash?
Votes
Translate
Translate
Report
Report
Advocate ,
r-bin  ha scritto
geppettol66959005
I get this error
no I did not have any other mistakes.
anyway
I solved the problem with a stratagem
to work there must be at least two active levels.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
I get the error as you do and I get the _alert(e) dialog when adding in the .NO option.
No crash.
Can you add in logging of the original layer numbers and what you are sending to resize and transform? Does this crash or hang? Does this happen on all layer dimensions? Which version of Photoshop are you running? 19.1.5? Only Mac has the problem or did you try a windows machine? I'm on windows10  and I also tried my mac with no errors. I just did a new document with a single layer. Unless I run on a background layer I'm not able to reproduce the dialog or get the crash/hang.
I like that _alert message you have made...can I use it in my scripts?
Votes
Translate
Translate
Report
Report
Advocate ,
Use photoshop cc2018 19.1.5
on machine mac
I have specified that on photoshop cc2014 does not come out any error
r-bin
unfortunately, photoshop crashes
thank you for your time
Votes
Translate
Translate
Report
Report
People's Champ ,
The fact that you do not get errors on CC2014 (CC2018), possibly a bug
Here such code gives two errors in CS6. In CC - silence
alert(app.activeDocument)  // must be error when there are no open documents
x = y // must be error when 'y' not defined
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Are you sending in the crash dump via the Crash Report Dialog? Are you giving us an email or other way for me to find the crashes? You can send me the email in a private message. Can you attach the file you are using or dimensions of the layer in question?
Votes
Translate
Translate
Report
Report
People's Champ ,
Can you comment on my post #10 please?
Votes
Translate
Translate
Report
Report
People's Champ ,
If you want to crash on CS6-CC2018
Run this script when there are no open documents.
var d = new ActionDescriptor();
var r = new ActionReference();
r.putClass(stringIDToTypeID("document"));
d.putReference(stringIDToTypeID("null"), r);
executeAction(stringIDToTypeID("resetDocumentChanged"), d, DialogModes.NO);
Votes
Translate
Translate
Report
Report
Adobe Employee ,
I've fixed that for a future version of Photoshop. I recommend checking for at least one document before calling that code for Photoshop to avoid the crash. You have any other crashers for me?
Votes
Translate
Translate
Report
Report
LEGEND ,
I'm sorry for little off topic but here's other r-bin find that's not crash but odd behaviour that I can't understand why some Adobe folks consider as normal. For me and him​ it's surely a bug, isn't it in your opinion and shouldn't it be sorted out for next Ps release finaly? Photoshop: Selection modifications after transform | Photoshop Family Customer Community
Votes
Translate
Translate
Report
Report
People's Champ ,
Aug 17, 2018 Aug 17, 2018
https://forums.adobe.com/people/Tom+Ruark
Another crash ))
Close or collapse the Bsuhes panel.
Restart photoshop.
Without opening the Brushes panel, run this script or action which calling the same menu.
runMenuItem(stringIDToTypeID("toggleShowMRUInBrushesPanel"));
PS 19.1.4 Windows x64
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Fixed, in a future release of Photoshop, for crashing when toggling brush menu in panel. The workaround would be to get the status of the brushes panel and toggle it open first. Then toggle the menu in the panel.
Any more?
Votes
Translate
Translate
Report
Report
People's Champ ,
Are you a crash hunter?
I'm more interested in the usual bugs, because of which I do not use version 19.
Therefore, the crash is caught purely accidentally during the tests.
About checking the status of the Brushes panel Yes, it is possible.
But here too there are very strange results. Most likely also a bug.
Confused "shown" and "visible".
Check.
r.putEnumerated(charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt"));
d.putReference( charIDToTypeID( "null" ), r );
d.putString (stringIDToTypeID("command"), "getViewInfo");
d.putString (stringIDToTypeID("viewID"), "$bpst" );
d.putString (stringIDToTypeID("panel"), "brushpresets" );
var view = executeAction(stringIDToTypeID("uiInfo"), d, DialogModes.NO).getObjectValue(stringIDToTypeID("view"));
r.putProperty(charIDToTypeID("Prpr"), stringIDToTypeID("panelList"));
var panel = executeActionGet(r).getList(stringIDToTypeID("panelList")).getObjectValue(28);
alert("view shown: " + view.getBoolean(stringIDToTypeID("shown")) +"\n\n"+
      "view visible: " + view.getBoolean(stringIDToTypeID("visible")) +"\n\n\n"+
      "panel visible: " + panel.getBoolean(stringIDToTypeID("visible")) +"\n\n"+
      "panel obscured: " + panel.getBoolean(stringIDToTypeID("obscured")),
    "Brushes")
Votes
Translate
Translate
Report
Report
LEGEND ,
Bugs are the same reasons I work in CS6 EXTENDED though I have CC2018.
Votes
Translate
Translate
Report
Report
Community Expert ,
Bugs are why I have CS6,  CC 2014 and CC 2018 19.1.5 installed.  IMO CS6 and CC 2014 are better then CC 2018 for they have fewer bugs.....
JJMack
Votes
Translate
Translate
Report
Report
People's Champ ,
Aug 27, 2018 Aug 27, 2018
Any more?
I discovered by chance one very unpleasant bug. It is present in CS6 and in CC2018, and most likely in any version.
Suppose someone intends to either accidentally or by mistake create and execute such a script.
var d = ActionDescriptor;
d.putInteger(1, 0);
alert("Haha, I broke the photoshop!");
After that, any scripts, including native Photoshop, including all extensions including the generator, which in the code use new ActionDescriptor() construction, stop working.It helps only to restart Photoshop.
I hope you will tell me what you think about this bug.
Votes
Translate
Translate
Report
Report
Community Expert ,
There are nasty bugs in Photoshop scripting that Adobe does not seem to care to fix whatch out for suspend history and moving when you have an active selection. Photoshop: Script bug resize layer back document up one history state | Photoshop Family Customer Co...
JJMack
Votes
Translate
Translate
Report
Report
