I have made custom brushes in Photoshop Elements. Individually they show in the Brushes drop down menu but is there a way
of adding a folder with these brushes to this menu ie add to the list of types of brushes. If I have them elsewhere in folders I can load them when I require them but it doesn't show me what each brush in the folder is until I load them. Whereas when I click on a set of brushes in the drop down menu it immediately shows me the brushes in that set.ā I have a lot of extra brushes so it would be great if I could add their sets to this drop down menu.
Thank you
Joan
Brushes are presets and you can create your own library.
From the tool options bar click the brush choices and then click the pull-down menu (top-right) which has several horizontal lines and a down pointing arrow icon.
Choose Preset Manager
Select (highlight) your brush and then click the button Save Set. Choose a name for your library and click save.
After creating your library of brush presets return to the pull-down menu and choose Load Brushes.
