Let me preface this with I am a Microsoft Excel MVP. I know when Excel is open and when it is not. But the installer says it is open and won't install.?
SD
check your activity monitor or task manager for any non-os ms programs running.
[moved from Adobe Creative Cloud to Installing, Updating, & Subscribing to Acrobat]
Does that even after a reboot?
Didnt have excel open, but went into task manager and excel was running in the background 4 times, so ended task on all four and acrobat installed correctly. Hope this helps.
Yes, that's why I asked for the reboot. Anytime you have problems like that, a reboot cleans all. It is good practice anyhow to reboot before and after installing programs as that creates a clean environment.
Excel did not close properly the last time you started it... If you can afford, reboot.
I was having the same issue, but followed what gust77740527 said and I found Excel running in the background also! Fixed my issue - thanks Gus!
