0 Replies Latest reply on Mar 26, 2008 7:42 PM by Raj_T
    HTTP XML - need help
    Raj_T
      I am new to Flex and ActionScript. Need help:
      Modified the code found at: http://learn.adobe.com/wiki/display/Flex/2b.+Code+Files
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute">
      <mx:Script>
      <![CDATA[
      import mx.rpc.events.ResultEvent;
      import mx.rpc.events.FaultEvent;
      import mx.controls.Alert;
      [Bindable]
      private var shippingInfo:XMLList;
      public function handleXML(event:ResultEvent):void
      shippingInfo = event.result.report.table.tr as XMLList;
      //Alert.show(shippingInfo.td);
      //Alert.show(shippingInfo.td.(@colnum=='c0'));
      //Alert.show(shippingInfo.td.(@colnum=='c1'));
      public function handleFault(event:FaultEvent):void
      Alert.show(event.fault.faultString, "Error");
      </mx:Script>
      <mx:HTTPService result="handleXML(event);" fault="handleFault(event);" id="xmlRPC" resultFormat="e4x"
      method="POST" url=" http://localhost/xml_test/test_flex.xml" useProxy="false">
      <mx:request xmlns="">
      <zipcode>{zipcode.text}</zipcode>
      <pounds>{weight_lb.text}</pounds>
      </mx:request>
      </mx:HTTPService>
      <mx:Label x="56" y="32" text="Zip Code" width="55" height="18" textAlign="right" fontWeight="bold"/>
      <mx:Label x="56" y="58" text="Weight" width="55" height="18" textAlign="right" fontWeight="bold"/>
      <mx:TextInput x="130" y="32" id="zipcode" width="160" height="22"/>
      <mx:TextInput x="130" y="58" id="weight_lb" width="160" height="22"/>
      <mx:Button x="130" y="95" label="Get Shipping Options" click="xmlRPC.send();" width="160" height="22"/>
      <mx:DataGrid
      dataProvider="{shippingInfo}"
      x="80" y="141" width="562" height="292" id="shippingOptionsList" editable="false" enabled="true">
      <mx:columns>
      <mx:DataGridColumn headerText="Country" dataField="td" />
      <mx:DataGridColumn headerText="Car" dataField="td2" />
      </mx:columns>
      </mx:DataGrid>
      </mx:Application>
      The above code works fine for the following XML file:
      <?xml version="1.0" encoding="ISO-8859-1"?>
      <fxf version="1.0" data="hold">
      <report records="5" lines="5" columns="2" rows="10">
      <target format="" version="" type="" destination="OUT"/>
      <table>
      <tr linetype="data" linenum="1">
      <td colnum="c0">ENGLAND</td>
      <td2 colnum="c1">JAGUAR</td2>
      </tr>
      <tr linetype="data" linenum="2">
      <td2 colnum="c1">JENSEN</td2>
      </tr>
      <tr linetype="data" linenum="3">
      <td2 colnum="c1">TRIUMPH</td2>
      </tr>
      <tr linetype="data" linenum="4">
      <td colnum="c0">JAPAN</td>
      <td2 colnum="c1">DATSUN</td2>
      </tr>
      <tr linetype="data" linenum="5">
      <td2 colnum="c1">TOYOTA</td2>
      </tr>
      </table>
      </report>
      </fxf>
      Now, my actual XML in Production world would look like:
      <table>
      <td colnum="c1">JAGUAR</td>
      </tr>
      <td colnum="c1">JENSEN</td>
      </tr>
      <td colnum="c1">TRIUMPH</td>
      </tr>
      <td colnum="c1">DATSUN</td>
      </tr>
      <td colnum="c1">TOYOTA</td>
      </tr>
      </table>
      </report>
      </fxf>
      (Notice in this XML, under each <TR> you would find two <TD>s)
      Use this XML file, I am having problems. I need to specify which TD goes into each column. Even if I use:
      dataField=".(attribute('colnum')=='c0')"
      it is not helping me.
      Please help me. Thanks in advance.
      - RT
