Expand my Community achievements bar.
Learn about Edge Delivery Services in upcoming GEM session
SOLVED
Coloring a text in a string using javascript
Avatar
Level 2
Hey guys ,
Actually I have a text field which is binded with a long text , need to color a specific character from the string. Got an idea of using replace function  replacing the text with a colored text using javascript , used the following script : (the rawValue contains text "this is only for testing")
var e = "BLAH";
this.font.fill.color.value = "0,56,101";
//e.value.font.fill.color = "0,56,101";
var str = this.rawValue;
str = str.replace(/ only /g, e);
this script works but it colors the entire string , the third line of script does not work(so commented it). Can we set color to the value of the variable e which I've defined above and pass that variable to replace function ???
1 Accepted Solution
Avatar
Correct answer by
Level 10
1 Reply
Avatar
Correct answer by
Level 10
Hi there,
here is a link you can refer to help you with this.
Adobe LiveCycle Designer Cookbooks by BR001: Programmatically updating Rich Text (or xHTML)
