Expand my Community achievements bar.
Learn about Edge Delivery Services in upcoming GEM session
AEM 6.4 - Programatic flush request
Avatar
Level 2
Hi
I'm trying to perform a flush request from a custom workflow step.
In order to send the request I'm using the  sendFlushUrl method from the FlushService.
But when  when I do in the error log I get the following message:
com.adobe.cq.social.ugcbase.dispatcher.impl.FlushServiceImpl Worker.run: no agents available - ignoring flush: FlushJob[urlToFlush=/content/xxx/xxx/xxx, refetchUrls=/content/xxx/xxx/xxx]
I had configured the default dispatcher flush agent to point the webserver url.
Does anyone face this problem or know any other way to do it?
Thanks in advance
Avatar
Level 2
Hi, sorry for the delayed response
smacdonald2008
With the cURL call form a terminal it works as expected, not sure why the method described not work.
kautuksahni
I review the configuration and it seems to be correct. I've already check the link you posted, that's why I was trying to use the sendFlushUrl from the FlushService.
I finally archive a solution, after a review on the requirements, using the replicator service and a EventListener.
Thank you both for your collaboration.
Avatar
Level 1
Hi qglez
I am looking for the same solution, Could you please pass the source for Listener and Replicator service in this thread ?
Avatar
Administrator
In order to make the flush service working properly, create flush agents for each dispathcer with following additional settings-
1. Set the Request method - "POST" because this service expects a POST method flush agent.
2. Send additional parameter for "resource only replication"
Also, there are other way to do this. Please have a look at AEM 6.0 and above: Programmatic Cache Invalidation in AEM 6
-Kautuk
Kautuk Sahni
