1 Reply Latest reply on Apr 25, 2008 9:04 AM by -windowns-
    Drag and Drop - image of draggable item is not near mousepointer
    Wubsorz
      I have created pane where you can drag contact into a group, everything works fine but the drag image is not always at the same spot as the mouse pointer is. As visible in the image: Drag image.
      These contacts are in a VBox:
      <mx:VBox id="summariesContainer" paddingTop="10" paddingLeft="10" >
      <mx:Repeater id="contactRepeater" width="100%" height="100%" dataProvider="{contacts}">
      <!-- Draggable items -->
      <contacts:ContactSummary contact="{contactRepeater.currentItem}"
      mouseMove="dragIt(event)"
      dragComplete="dragCompleteHandler(event);" />
      </mx:Repeater>
      </mx:VBox>
      When I pick the first contact from the VBox it is right where it should be .... when I pick the second contact it is slightly below the mousepointer. In short: The distance of the contact from the top of the VBox is the distance it will have from the mousepointer. How can I correct this?
      Below is the contents of my dragIt method:
      private function dragIt(event:MouseEvent):void {
      if (!event.currentTarget is ContactSummary) {
      return;
      var contactSummary:ContactSummary = event.currentTarget as ContactSummary;
      var contact:Receiver = contactSummary.contact;
      //Set the drag initiator based on the event object
      var dragInitiator:ContactSummary = event.currentTarget as ContactSummary;
      // Create a DragSource object.
      var dragSource:DragSource = new DragSource();
      // Add the data to the object.
      dragSource.addData(contact, 'contact');
      // Create a copy of the ContactSummary to use as a drag proxy.
      var dragProxy:ContactSummary = new ContactSummary();
      dragProxy = event.currentTarget as ContactSummary;
      // Call the DragManager doDrag() method to start the drag.
      DragManager.doDrag(dragInitiator, dragSource, event, dragProxy);
