• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
4
New comp background is transparent even though I chose black
New Here ,
Aug 17, 2018 Aug 17, 2018
I just got back on After Effects after being off for awhile. When I start a new comp and choose black background, it gives me a transparent background. Did I accidentally change a preference or setting? Has anybody else had this happen?
Thanks for any help I can get.
Views
17.9K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advisor , Aug 18, 2018 Aug 18, 2018
The marked switch is probably on (blue) at the bottom of your Composition window. Click it to turn it off (grey).
Votes
Translate
Translate
Community Expert ,
The comp background is always transparent. You can choose any background color you want but if you don't put some pixels there the bg will be black when played on most media players with most professional codecs. If you are seeing a checkerboard then you have a switch thrown in the Comp Panel. If the problem pops up when you render then you have to either put a colored background at the bottom of the timeline or render without an alpha, which will give you a black background with most codecs no matter what background color you set for the composition.
The only real reason to choose a different background color for the comp when rendering a project with transparency is to effect the antialiased edge pixel color when you choose Premultiply with Alpha in the render settings.
Votes
Translate
Translate
Report
Report
Advisor ,
Votes
Translate
Translate
Report
Report
New Here ,
Aug 10, 2019 Aug 10, 2019
Votes
Translate
Translate
Report
Report
New Here ,
Jan 11, 2020 Jan 11, 2020
This helped. Thanks!
Votes
Translate
Translate
Report
Report
New Here ,
Feb 18, 2021 Feb 18, 2021
thanks a million!!!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 22, 2023 Mar 22, 2023
I know you gave this answer years ago...but thanks today, lol!
Votes
Translate
Translate
Report
Report
New Here ,
Oct 22, 2023 Oct 22, 2023
Thanks – that worked!
Votes
Translate
Translate
Report
Report
New Here ,
Nov 28, 2023 Nov 28, 2023
LATEST
Thank You SIR!!1
Votes
Translate
Translate
Report
Report
New Here ,
Oct 18, 2020 Oct 18, 2020
Thanks 😄
Votes
Translate
Translate
Report
Report
