11 Replies Latest reply on Sep 11, 2018 4:21 PM by R Neil Haugen
    GPU render error, unable to preces frame
    TheExplorographer Level 1
      You cannot afford my lost time.
      GPU Render Error
      Unable to process frame.
      Writing with exporter: H.264
      Writing to file: \\?\M:\TheVanishing001mp4.mp4
      Writing file type: H264
      Around timecode: 00;30;00;06 - 00;30;00;13
      Rendering effect: AE.ADBE Lumetri
      Rendering at offset: 1799.970 seconds
      Component: EffectFilter of type GPUVideoFilter
      Selector: 9
      Error code: -1609629695
      I have turned OFF render at maximum quality... which alone seems like I am overpaying for software that doesn't work.  I just lost all that time as I have a file that is worthless.  This is completely random. Sometimes, no problem renders fine..other times I get the above error.  Yes, I am on the latest nVidia drivers. They were clean installed and do not have issues. I am completely frustrated at this point!
      [title edited by mod for better search]
        • 1. Re: FIX YOUR SOFTWARE!
          R Neil Haugen Adobe Community Professional & MVP
          Typically that means you have an issue at the point in the timeline it gives you. Fix that.
          Neil
          • 2. Re: GPU render error, unable to preces frame
            Carlos Ziade Adobe Community Professional
            You have a problem in rendering Lumetri effects applied, try removing them,
            or if you still want the Lumetri, try to delete the render files by going to sequence - delete render files
            or manually delete the video previews from outside of Premiere. Then clean your Media Cache.
            If after doing all of the above the problem persists, try nesting the clips on which you have Lumetri
            after removing the Lumetri Effect, then reapply Lumetri to the nested. Check if that works as well ...
            • 3. Re: GPU render error, unable to preces frame
              juanmario Level 4
              In the project settings, change GPU acceleration to Solo Software.
              • 4. Re: GPU render error, unable to preces frame
                Thanks for the suggestions fellas...but I have to ask... WHY??  I am doing nothing that I wasn't doing before this god awful bug.  By the way, I have discovered, turning off the layers Opacity Keyframing fixes this problem.  This is a bug..Adobe knows it.  PR right now is crippled. I am paying full price for crippled software.  I am most certainly not changing my workflow.  I built this beast of a system so that my creative flow is not hindered by hardware or software and right now software is being a PITA!
                • 5. Re: GPU render error, unable to preces frame
                  First, by your comments, you don't understand a number of things about this app. Which is normal, how many do?
                  So ... Max Render Quality is only of use in certain limited situations, such as major resizing involving a lot of diagonal lines. Other than that, it's not of use. And can at times cause artifacts, so the better advice is that's off most of the time. Same for Max Depth, especially if you've got a dedicated decent GPU. 2-pass renders for exports mostly just take up extra time, without any appreciable improvement to the export. Except ... it can help in a very few sequences.
                  Not having them on is NOT 'missing' anything of use with the app. Period.
                  Apparently, you're one of the few that has the issue of opacity keyframing a clip or adjustment layer causes a problem? If so, yes, any software has some bugs ... some things that don't work right on some gear and media combinations, that sort of thing. I can't replicate, as it's working normally on my Win10 rig.
                  I do understand and appreciate the angst. Like most anyone using a complex hardware-demanding app like this for 5 years or so, I've been hammered at some point also. Around four months one time, requiring I stay with an earlier version until the appropriate bug fix had been released.
                  Also, if there's some glitch in the media cache files, you can have this sort of Lumetri fail message. I do get them but pretty rarely ... and always dump the media cache and check the timeline at the time-code spot. And am exporting in a couple minutes.
                  Neil
                  • 6. Re: GPU render error, unable to preces frame
                    To add to what Neil said, that which I agree 100%, you should have informed us
                    if you have tried our suggestions to delete the render files or video previews associated
                    to your project. When projects rendered on previous versions are rendered again on newer
                    versions, sometimes an abnormal overlapping of the video previews might occur especially
                    when you have effects like Lumetri, so, simply deleting the render files and then cleaning
                    your media cache is something that should be done and become your habit as always this
                    is a necessary step not only with Premiere Pro. When you turned off 'Opacity' keyframing
                    and that I guess was done on the layer that has the Lumetri, that layer's render previews
                    were not being rendered again, no more of use. I guess if you deleted all the render files and
                    media cache and tried again even with those opacity keyframes on, your problem might have been solved.
                    • 7. Re: GPU render error, unable to preces frame
                      This was a brand new project. And the media cache is generally dumped before I start anything new...and it was this time. So no, it wouldn't have worked. Thanks for the help, to others. All I know is that they better get it fixed.  I am tired of public forced betas.  That needs to be done on an non-production stream by volunteers.  No where in my Adobe contract does it say that I agree to TEST software.  Also, the salt tossed around by community "pros" here is appalling.   Great image for the company.
                      • 8. Re: GPU render error, unable to preces frame
                        I wouldn't be here if it was a typical issue. And it was ONE track... no edits. Turning off keyframing on the opacity fixed it immediately. This is a bug. Period.
                        • 9. Re: GPU render error, unable to preces frame
                          Didn't say it wasn't,  and if you read my last post, it's clear I saw it as such.
                          I don't know of a complex multi platform app that is ever totally bug free. None. Period. I've been hit by bugs in this app myself, one caused me to stay with an earlier version for 4-6 months.
                          And I've had others less maddening.
                          So I'm not negating that you have a big or it's a pisser for you.
                          That said many things happen more if certain processes or patterns aren't understood or taken. Hence going through possible options and approaches that may obviate or at least get around something will be suggested.
                          The development team knocked off a ton of bugs this cycle, a huge improvement over past releases. So I give credit for that. This forum is the deadest post-release I've seen in five plus years.
                          So that means pushing on the remaining ones is a good thing to do.
                          As is checking steps and processes that may help also.
                          Neil
                          • 10. Re: GPU render error, unable to preces frame
                            RO2.0
                            I was wondering if you happened to find a fix.  I'm getting the same error and it seems to always happen between Opacity Key Frames.
                            • 11. Re: GPU render error, unable to preces frame
                              Please file over on the UserVoice system that you're having this. I've created the bug report linking to this thread, but PLEASE! ... both of you (and any others!) ... go there and add your comments to my posting.
                              gpu render error "unable to process frames" linked to opacitiy keyframe being "on" – Adobe video & audio apps
                              That is the way in the Adobe system to get the data directly to the QC engineer's systems. If they don't see it, they don't know about it.
                              Neil
