• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Posting Video To Instagram, Terrible Quality
Community Beginner ,
Aug 19, 2018 Aug 19, 2018
Hi there,
I'm an upcoming videographer/video editor.
For years, I've been trying to upload high quality videos to Instagram and have had no success.
It seems that no matter what settings I use or what video editing software I use, nothing changes. I've used Final Cut Pro X switched to Premiere and back again.
Can someone please tell me the correct settings to export a video from Premiere Pro, to Instagram?
Every time I post a video it looks pixelated, blurry and not at the high quality that I need to start my business or just to have decent looking videos on my Instagram feed.
Any help will be much appreciated.
Thank you,
Rochelle
Views
8.3K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
From https://www.facebook.com/business/ads-guide/video/instagram-feed/video-views ​ :
Upload the highest-resolution source video available without letter or
pillar boxing (no black bars). Most file types are supported. However,
we recommend H.264 compression, square pixels, fixed frame rate,
progressive scan and stereo AAC audio compression at 128+ kbps.
Be sure to also read the other informations on the website
Votes
Translate
Translate
Report
Report
Thank you!
Will read that now and see if it works. I've literally run out of ideas of what to try.
If it's ok, I'll reply if it hasn't worked.
Rochelle
Votes
Translate
Translate
Report
Report
Community Expert ,
Rochelle, feel free to reply again if it hasn't worked. That's what the forum is for
Kind Regards,
Maurice
Votes
Translate
Translate
Report
Report
Well I believe I already came across that article a while back.
Still, no success.
I wonder if I should screenshot my settings so you guys can see if I'm missing something...?
Rochelle
Votes
Translate
Translate
Report
Report
Community Expert ,
That would be helpful
Votes
Translate
Translate
Report
Report
Screen Shot 2018-08-19 at 18.11.48.pngScreen Shot 2018-08-19 at 18.11.58.pngScreen Shot 2018-08-19 at 18.12.07.png
Sorry I'll post the specific part next time.
It's jus the part under the Video heading that I was trying to show the different settings that apparently is supposed to work.
Rochelle
Votes
Translate
Translate
Report
Report
Community Expert ,
Turn off Max Depth and Max Render,
Set software encoding to hardware encoding
Target and Max Bitdepth both to 16.
Set VBR2 to VBR 1 pass.
See how that goes.
Votes
Translate
Translate
Report
Report
Will try that too.
Thank you!
Votes
Translate
Translate
Report
Report
Community Expert ,
Aug 28, 2018 Aug 28, 2018
Rochelle, it's been a while. How did this turned out for you?
Votes
Translate
Translate
Report
Report
Hi there,
Ann Bens suggestion helped a lot and a follower of mine on Instagram, shared a video that also helped.
Thank you
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 19, 2019 Apr 19, 2019
Between both sources, what were the final specs you went with?
Votes
Translate
Translate
Report
Report
May 13, 2019 May 13, 2019
Hi there,
I used what Ann Bens suggested, for the export settings. I also make sure to change the sequence to 1280 by 1280. A follower on Instagram would also scale the video clips to that size. I haven't tried that yet, as I usually leave it with the two bars. I just put text in the two bars and then export.
Hope that helps!
Rochelle
Votes
Translate
Translate
Report
Report
New Here ,
Oct 25, 2020 Oct 25, 2020
Hey! I'm having trouble with the quality when I upload to Instagram as well. The video looks great when I export it and transfer it to my iPhone, but then when I put it on intagram, the quality is really bad. I've tried the suggestions on this feed and I haven't seen a change. I filmed the video with my iPhone 6s and I'm transferring the video back to my phone through iCloud Drive. I'll post a screenshot of one of the most recent export settings I tried. I'd really appreciate your help. I'm stumped!Export Settings.png
Votes
Translate
Translate
Report
Report
New Here ,
Sep 09, 2021 Sep 09, 2021
LATEST
Try to export using the settings in this video. I got great results:
https://youtu.be/6b3YugCy3eo
Getting the best quality video on Instagram is crucial because it's being flooded with lots of content so standing out from the crowd helps a lot. What do you guys thing about the new trend and abandoning photographers? 0:00 Introduction 1:02 Resolution and Screen Orientation 1:33 Reels IGTV and ...
Votes
Translate
Translate
Report
Report
