23 Replies Latest reply on Sep 16, 2018 9:46 AM by KWW1955
    Very displeased
    KWW1955
      Friends,
      I'm very fond of Acrobat Pro, and have been for a very long time. I use it at some great length in my work, and I've recently purchased the same version to install at my home as I'm beginning to work more from home.
      There are a couple of problems which are driving me insane to the point where I'm displeased to no end with the lack of support from Acrobat in solving these problems.
      1. For the life of me I cannot find a way to make a customized "tool set" come up every time I open a PDF as the default.  I don't want to have to select the tool set every single time.  Why on earth can I not designate a customized tool set as the new default?  More troubling and frustrating is that I have been able to customize the "Default Set" at work, and on another computer I use frequently in presentations in classes I provide around the county.  It works just fine on them, and not on a brand new installation at my home.  Why is that?
      2. The same issue holds true for the "Page navigation", "Page Display", "Select and Zoom" bar.  I cannot make the selections remain from one PDF to another.  Why is that?
      3. And, finally, I can not determine how/why the "Recent Files" list seems to be erased once I exit a session with Acrobat Pro and close the program.  Again, this doesn't happen on the program I've installed at work, or on the travel computer.  What on earth is the matter?
      Could someone please help me sort these three items out?  I cannot begin to describe how frustrating it is when a program works fine in one location and not in another.  It's about as annoying as it gets.
      Ken Wagoner
      Escondido, CA
        • 1. Re: Very displeased
          Adorobat Adobe Employee
          Hi Ken,
          As per the issue description mentioned above, you are facing issue with Acrobat, is that correct?
          You may try customizing quick toolbar by right-clicking an empty space in the toolbar and choose the tools that you want to appear in the toolbar. You may also try creating a custom tool and check if that helps. Refer to this help document for the same: Adobe Acrobat Workspace basics
          Also, try rebooting the machine once if you haven't already and check if that helps with recent files issue.
          Let us know if you need any help.
          Shivam
          • 2. Re: Very displeased
            KWW1955 Level 1
            Shivam,
            I thank you for the reply.
            However I have to admit that I had not made the modifications to the toolbars, setting them exactly the way I wished them to appear, closing the program, and then immediately rebooting the machine. Once I return home this afternoon I'll give that a try to see if that is the answer.
            Do you have any thoughts on the missing "recently opened files" issue?
            Ken Wagoner
            Escondido, California
            • 3. Re: Very displeased
              For 2, are you trying to change this in Preferences? Do Preferences changes "take"?
              • 4. Re: Very displeased
                Hi Ken,
                Normally Recent Files" list shouldn't get erased once Acrobat Pro is relaunched. Try repairing Acrobat using "Repair installation" option under Help menu, reboot the machine after repair and check.
                Also, let us know dot version of Acrobat and the operating system installed on the machine? You may refer to the steps given in this link on how to check the version in Acrobat: Identify the product and its version for Acrobat and Reader DC
                -Shivam
                • 5. Re: Very displeased
                  KWW1955 Level 1
                  Shivam,
                  Unfortunately the "Recent Files" lasted until I exited the program.  I opened several different files, and when I closed them I did see the list on the screen, and it was also under the "File" menu pull down.  However once I closed the program and started it again, that list disappeared.
                  Here's the version information from a screen capture:
                  Also, when I was performing the repair the following popped up:
                  At this point my frustration level is very high.
                  Ken Wagoner
                  Escondido, CA
                  • 6. Re: Very displeased
                    KWW1955 Level 1
                    TestScreenName, I tried to set the recent files in Preferences and it still would work only as long as that one instance of running Acrobat was still active.
                    Ken Wagoner
                    Escondido, CA
                    • 7. Re: Very displeased
                      I mean, random other preferences. Sounds as if no preferences are being saved, which may be an Acrobat problem, a system probem, or somewhere between.
                      • 8. Re: Very displeased
                        Hi Ken,
                        Please try the troubleshooting steps given in the following help document: Error 1328: Error applying patch to file | Acrobat, Reader
                        -Shivam
                        • 9. Re: Very displeased
                          KWW1955 Level 1
                          Shivam,
                          I'll be trying once I accomplish the re-install, which did not work.  I'll be slowly going through it step by step until I get the desired results.
                          Ken Wagoner
                          Escondido, CA
                          • 10. Re: Very displeased
                            KWW1955 Level 1
                            Shivam, and others...
                            Very well, here's an update.  I've finally been able to completely remove, and then reinstall Acrobat Pro XI. It was a quite difficult process and involved some work in the registry which always makes me extremely nervous.  So, the product is up and running!
                            Some of the features I needed work very well.
                            • "Save As Other" is finally working flawlessly for "images", which is a critical tool for me in my work.
                            • Acrobat functioning as a printer is also working flawlessly.
                            • However, the issue with editing the default toolbars remains as a problem.  I've been able to customize the default, and it seems to remain in place throughout the editing session, and returns when the program is closed, and then reopened.  However once I place the "Recognized Text In This File" tool on the default, it goes away the very next time I close and open the program.  Here's a picture of what I want:
                                 And once I exit the program, and reopen, here's what it displays:
                                 That's pretty annoying, however if it continues to be the only missing tool I can deal with it.  It is sort of odd though.
                            • And the problem of the program failing to list the previously opened files is still taking place.  I opened several files, and then closed them, and here's what I saw when I closed the files I was working with:
                                 Note how it shows three "recent" files.  All well and good.  Once I exit the program, here's what comes up when I reopen it:
                                 It doesn't show a single "recent" file.  So, I guess until this gets resolved, the answer is to keep the program loaded at all times, and only finish working on files by closing the file not the program if I want a list of recent files.
                            I'm still "displeased" however not quite as much as I was before.
                            Ken Wagoner
                            • 11. Re: Very displeased
                              KWW1955 Level 1
                              And I neglected to mention the other issue was the navigation Icons don't seem to last beyond the operating session.
                              Here's what I want:
                              And once I exit the program and re-open, here's what I see:
                              And yes, I'm still "displeased."
                              Ken Wagoner
                              Escondido, CA
                              • 12. Re: Very displeased
                                Hi Ken,
                                Try updating Acrobat to the latest patch (11.0.23) using "Check for updates" option under "Help" menu, reboot the machine after installing update and check if that resolves the issue. If issue still persists, try replicating the issue in a new user account by clicking on the Start button > control panel > add or remove user accounts > create a new account. Login into that account, launch Acrobat from there and check.
                                -Shivam
                                • 13. Re: Very displeased
                                  I’m pretty displeased that you’ve ignored my troubleshooting suggestion. But that’s the way it goes.
                                  • 14. Re: Very displeased
                                    KWW1955 Level 1
                                    Test Screen Name,
                                    I did try working with "Preferences" and it did not result in any change in the behavior of Acrobat. I didn't respond with a confrontational post decrying "It didn't work!", as I did not feel it would be of any value to make such a remark.
                                    As I noted on Saturday (9/1) my two remaining issues seem to be the disappearance of my selection of page display tools once the current editing session has ended, and the lack of a list of recently opened files.  When I get home from work this evening I'll try the suggestions from Shivam to see if they have the desired impact.
                                    If you have suggestions other than working with "Preferences" I'd welcome anything that might resolve these problems.
                                    Ken Wagoner
                                    Escondido, CA
                                    • 15. Re: Very displeased
                                      I didn't suggest it would change the behaviour of Acrobat. Certainly wouldn't. That's why it's a troubleshooting step, not a solution. We suggest things, you try them, you tell us what happened, we make guesses and ask more questions. Eventually we might suggest things to try fixing it.
                                      Saying "It did not work" is not confrontational, it's the most basic level of polite reply for someone who took the to think about your issues !!!
                                      My crucial question was "Do Preferences changes "take"?". That's what you never answered. ALL your symptoms might point to a single cause, perhaps.
                                      • 16. Re: Very displeased
                                        jane-e Adobe Community Professional
                                        Are you suggesting to make any change in Preferences, then quit and relaunch to see if the setting took hold?
                                        • 17. Re: Very displeased
                                          It seems I'm not as clear as I thought I was. I'm suggesting making several different random changes to preferences, quit and relaunching. If the preference changes haven't happened this points very strongly at ALL preference changes being lost, and in turn at a system permissions problem rather than a software issue.
                                          • 18. Re: Very displeased
                                            I thought that might be where you were going with Preferences, but I wasn't sure whether or not it was coming across. That's a great idea for troubleshooting—either way we learn something.
                                            • 19. Re: Very displeased
                                              KWW1955 Level 1
                                              I understand now, and I appreciate the thought.
                                              I did make several changes in "Preferences" such as "Page Display, Show Transparency Grid", "General, Select Default PDF Handler", and "Documents, Documents in recently used list:" to 5.
                                              All of the changes were retained, however the list of recent documents, and the page display and page zoom settings weren't retained.
                                              So I'm down to two issues.
                                              Thank you all for your patience and efforts to help me.  It is very much appreciated.  Hopefully I can return the favor for another user down the road.
                                              Ken Wagoner
                                              Escondido, CA
                                              • 20. Re: Very displeased
                                                It appears that there is one missing tool, and I just want to test to see if there is a limit or something. Adobe stopped support for Acrobat XI almost a year ago, and I can test it myself because it's changed it DC. Try removing one tool, then adding the last tool. Does that save?
                                                And on the recent files, I see the command for "View All Files". What happens when you click that?
                                                • 21. Re: Very displeased
                                                  KWW1955 Level 1
                                                  Shivam,
                                                  I tried installing the update that Acrobat Pro XI said was the next one up, which was (11.0.20).
                                                  when I ran this install the update proceeded for a while then engaged in "rollback" and left me with the following error message:
                                                  I have been able to download "AcrobatUpd11023.msp" however I'm not sure how to proceed.
                                                  Thank all of you for trying to help me.
                                                  Ken Wagoner
                                                  • 22. Re: Very displeased
                                                    KWW1955 Level 1
                                                    An update.
                                                    While moving the file "AcrobatUpd11023.msp"  I accidentally hit right-click, and saw the option to "Apply".  Having nothing to lose at this point I went back and did so.
                                                    During the update, I received the following message:
                                                    Again, having nothing to lose I selected "ignore" and the install continued with no further errors. And I received this notice:
                                                    I rebooted the Machine, opened a few files, added my page navigation and page display menu items.  Once I exited the program and reinstalled - those menu items were no longer displayed, nor was there a list of previously opened files available.
                                                    I need to get to work, so I'll look into this again when I get home this evening.
                                                    Ken Wagoner
                                                    • 23. Re: Very displeased
                                                      KWW1955 Level 1
                                                      Friends,
                                                      I thank all of you for your suggestions and advice.  To my dismay none of them have had the desired impact on the program.  I have tried them all to no avail.  I haven't any idea why the settings I've selected for the toolbars (page display, select and zoom, etc) or the list of recently opened files will still be as I selected or used in a previous session for this iteration of the software.  What is particularly unsettling is that those same features remain functional on every other instance when I've purchased and installed this software.  It functions perfectly on my work computer (Windows 7, 64-bit), and on my Surface Pro (Windows 10, 64 bit).  For whatever reason it fails as I've noted on this machine (Windows 10, 64 bit).
                                                      I thought of tracking changes in the registry when the preferences were reset to what I wished for however while I found freeware that will track registry changes I simply put don't have the knowledge to take the dangerous step of modifying the registry.
                                                      So, I'm going to chalk this up as an example of "what can't be cured must be endured", and accept the limitations.
                                                      I'm grateful that the community made every effort to help me, and I will do so for others if I can address something.
                                                      thank you all,
                                                      Ken Wagoner
                                                      Escondido, CA
