Hello all, I've tried my best to find an existing script that I could modify for this with no luck. I want to be able to move a selected anchor point or points by a set amount, for example on the example below I want to shift those two anchor points 3mm to the right and 2mm up. I thought this was so simple I'd be able to find a script for it already made but no luck. I know enough about scripts to modify them but not to make from scratch.
Not very scripting related but the long story behind why I want this script is that I'm doing some isometric drawings of 3D shapes and so want to speed up shifting elements on the page. Ideally I suppose I should learn a 3D program but using InDesign is soooo much more comfortable!
Hi Steve,
you say "selected anchor point(s)", but I think you mean selected path points.
A single path point can be reached by its path.
If an object is selected like the one you are showing:
var pathPoints = app.selection[0].paths[0].pathPoints.everyItem().getElements();
Now you have all path points of the first path of that selected object stored in an array.
FWIW: An object could be constructed of one or more paths.
To get the ones you selected is difficult, because scripting does know nothing about
...Copy link to clipboard
Hi Steve,
To get the ones you selected is difficult, because scripting does know nothing about your selection on path points!
A big omission in the document object model.
You could test for their position and if the rule is move the ones that are right-most you could sort or compare x/y values that are present in property anchor of pathPoint. Or one could use the menu command for cut that is available by scripting and you compare the ones left by their anchor values to the ones that were before to single out the ones selected. After an undo of cut you can work with the ones you identified by their index.
https://www.indesignjs.de/extendscriptAPI/indesign-latest/#PathPoint.html
Bottom line: There is no "simple script" to move selected path points.
Regards,
Uwe
Hello Uwe
Many thanks for your response, I think I understand why what I thought would be simple is in fact not!
Taking another approach, can scripting be used to add or subtract values in the toolbar? See below the X & Y coordinates, could a script be written to add 3mm to X and 2mm to Y?
At the moment I place my cursor in the X box and type "+3mm" tab to the next box, right arrow to deselect, type "+2mm" then enter
Thanks again, Steve.
steveh10657863 wrote
… can scripting be used to add or subtract values in the toolbar?
Hi Steve,
I don't think so.
Regards,
Uwe
Thanks Uwe
OK last ditch approach! "Transform Sequence Again" can do what I want but only on the last two values used. Can scripting insert values into InDesign's "memory" so performing "Transform Sequence Again" would make a move based on those values?
Many thanks, Steve.
Sorry. Same answer, I think. And that is: No.
FWIW: If you manage to do a couple of actions that any of the transform menu items can do again, you could invoke the menu items by script.
Regards,
Uwe
P.S. A way to do this would be to make a script to make an object, move it X 2mm and Y 3mm, then delete it. Then running "Transform Sequence Again" makes that same move. However it doesn't work too well because Transform Again doesn't move just the selected anchor points, it moves the whole object. Would still be useful though.
Sorry, this also will not work.
Unless you find a way to move an object solely by using the menu commands and then use a script to use another menu command with transform.
Regards,
Uwe
Sorry I don't know exactly what you mean by solely using menu commands, would Object -> Transform -> Move -> Horizontal: 3mm, Vertical: -2mm work?
Many thanks, Steve.
Even if some surname me "M. 1-Click", just change the H/V increments in the ID general prefs. to '1mm" and use the "arrow" keyboards!
"3" clicks to the top, "2" clicks on the left!
Of course, you could select now others paths points and play 4 up / 3 right! …
Simple and quick! … The only true difficulty: … be able to count here until 4!
Best,
Michel, for FRIdNGE
Very good idea, Michel!
Best,
Uwe
Thanks Michel, unfortunately those figures were just examples, the actual figures I'm using have no common denominator and there's two more unique figures for the other plane as well!
I'll mark this thread answered and start a new one about just moving objects.
