5 Replies Latest reply on Mar 28, 2008 1:51 PM by steve barker
    mxml using AS class
    steve barker Level 1
      I want to be able to talk to an AS class with mxml but am finding it quite difficult. I tried a few approaches:
      instantiate the class from within a <mx: Script .... and also <local:ASclassName..... and also an click event from a button but in all cases the class does not render the results. Here is a snippet
      <mx:Script>
      <![CDATA[
      function initApp():void
      var basic:basicClass = new basicClass();
      </mx:Script>
      package
      import flash.display.Sprite;
      import flash.text.TextField;
      import flash.events.Event;
      public class basicClass extends Sprite
      public function basicClass():void
      var textBox:TextField = new TextField();
      textBox.text = "here is some text";
      addChild(textBox);
      thanks for any help
        • 1. Re: mxml using AS class
          Gregory Lafrance Level 6
          Maybe declare the var outside the function? It seems to be of local scope to the function.
          • 2. Re: mxml using AS class
            Thanks for the reply Greg. I have changed the example now to try to make things easier but still I cant get it to run:
            <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="initApp()">
            <mx:Script>
            <![CDATA[
            import TestClassPackage.MyTestClass;
            private var mytestclass:MyTestClass;
            private function initApp():void
            var mytestclass:MyTestClass = new MyTestClass();
            addChild(mytestclass.myLabel);
            </mx:Script>
            </mx:Application>
            here is the as code
            package TestClassPackage
            import mx.controls.Label;
            public class MyTestClass extends Sprite
            public var myLabel:Label;
            public function MyTestClass()
            var myLabel:Label = new Label();
            myLabel.text="here is a label";
            trace(myLabel.text);
            thanks for any suggestions. I am sure it can be done fairly easily but its killing me trying to get the mxml app to talk to the class
            thanks again
            • 3. Re: mxml using AS class
              Garyl Woolworth Level 1
              The problem lies with the following lines.
              public function MyTestClass(){
              You are using var myLabel inside of the constructor. This creates a new scope of the variable myLabel. And the label you accessing inside of your application is referencing the original myLabel out of the constructor. The proper way to do this would be as follows.
              myLabel = new Label();
              • 4. Re: mxml using AS class
                Bryan Dresselhaus Level 1
                Have your class extend an UIComponent subclass such as mx.containers.HBox.
                package {
                import mx.containers.HBox;
                import mx.controls.TextInput;
                public class NameInfo extends HBox {
                public var firstName:String = new String();
                public var lastName:String = new String();
                private var firstNameTextInput:TextInput = new TextInput();
                private var lastNameTextInput:TextInput = new TextInput();
                public function NameInfo(){
                super();
                protected override function createChildren():void {
                super.createChildren();
                addChild(firstNameTextInput);
                addChild(lastNameTextInput);
                firstNameTextInput.text = firstName;
                lastNameTextInput.text = lastName;
                Then you can use it like:
                <local:NameInfo firstName="John" lastName="Doe"/>
                • 5. Re: mxml using AS class
                  thank you for the replies
                  both of them are very useful and answer the questions - thanks again
