Hello everone,
I am using CF 2016
There are some CF Build-in Spreadsheet functions like SpreadsheetFormatRows, SpreadsheetAddRow, etc.... to help developer to convert a CF table page into a Native Excel file. Unfortunately there is no CF Build-in power point table functions such as PPTAddTable, PPTAddRow, etc to convert CF table page to native Power Point file.
The reason I want to convert to native table in PPT because our user will need to edit the data in the table of the PPT file
I wonder if anyone out there ever have a method to do such the job
We don't install the MS Offices products in the Production server machine
Please advise
Thank you so much
I'm not sure, but I believe that only PowerPoint can make a .ppt file. PP is very different from Excel or Word.
V/r,
^ _ ^
UPDATE: There is a site called https://smallpdf.com/pdf-to-ppt that can, apparently, convert a PDF to .ppt. I cannot access the link but you could create a CF PDF and then use that to convert to .ppt. Maybe. Just guessing.
We use the cfpresentation tag to generate PPTs on CF11.
Inside the cfpresentationslide section, insert a standard HTML table and it will be editable in PowerPoint.
It's true, what @Paule12345 says. Write the table as an HTML file. In fact, you may style it using CSS, for example, and make it as fancy as you wish. Then include it in the presentation.
As an example, save the following code as myPresentation.cfm.
<cfpresentation title="myPresentation" format="ppt" destination="#expandpath('myTestPresentation.ppt')#" overwrite="yes" >
<cfpresentationslide src="testTable.html">
</cfpresentationslide>
</cfpresentation>
In the same directory as the CFM file, save the HTML table from W3Schools as the file testTable.html. Launch the CFM file.
The result should be a Powerpoint file, myTestPresentation.ppt, containing the table.
