• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Extract data from XML
Enthusiast ,
Aug 21, 2018 Aug 21, 2018
(Testing on CF2016)
I have test CFM file that creates an XML file with the result as:
<TransferredValueTxn>
<TransferredValueTxnReq>
<ReqCat>TransferredUse</ReqCat>
<ReqAction>StatInq</ReqAction>
<Date>20100318</Date>
<Time>124430</Time>
<PartnerName>PARTNER</PartnerName>
<CardActionInfo>
<PIN>th2i-s4is-4a34-fa9k-e71u</PIN>
<AcctNum>optional</AcctNum>
<SrcRefNum>987654</SrcRefNum>
</CardActionInfo>
</TransferredValueTxnReq>
</TransferredValueTxn>
I use another CFM page to retrieve this data:
<cfhttp url="http://127.0.0.1/dev/api/test.cfm" method="get" result="objGet">
<CFDUMP VAR="#objget#">
This gives me all of the data in the FILECONTENT, which is
<?xml version="1.0" ?> <TransferredValueTxn> <TransferredValueTxnReq> <ReqCat>TransferredUse</ReqCat> <ReqAction>StatInq</ReqAction> <Date>20100318</Date> <Time>124430</Time> <PartnerName>PARTNER</PartnerName> <CardActionInfo> <PIN>th2i-s4is-4a34-fa9k-e71u</PIN> <AcctNum>optional</AcctNum> <SrcRefNum>987654</SrcRefNum> </CardActionInfo> </TransferredValueTxnReq> </TransferredValueTxn>
Could anybody give me some guidance as to how I would extract all of the data into separate variables so that I could then work with the data.
Views
822
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Aug 21, 2018 Aug 21, 2018
https://forums.adobe.com/people/ACS+LLC  wrote
My code was super simple
<cfdump var="#xmlParse(objget)#">
I have a developer that takes care of complex issues on an as needed basis. I decided it's going to be quicker to have him do it. He's doing the first one and then I'll be able to see if I can use that to build the rest.
I fear I'll end up spending too much time trying to get to grips with it.
There's something odd in al
Votes
Translate
Translate
Community Expert ,
This is a very brief answer due to limited time, so maybe someone else will give you a better one. But until then, put it XMLParse to see how the XML data is essentially converted to arrays and structures, and work from there.
<cfdump var="#xmlParse(objget)#>
Dave Watts, Fig Leaf Software
Votes
Translate
Translate
Report
Report
Enthusiast ,
Thanks Dave.
I did give it a shot to see if it could help me jump this hurdle but it returned an error
Complex object types cannot be converted to simple values.
Maybe somebody else will add to the thread.
Thanks.
Votes
Translate
Translate
Report
Report
Community Expert ,
I left off the closing quote. Otherwise, you should be able to use CFDUMP with any variable in CF at all, including complex objects.
Votes
Translate
Translate
Report
Report
Enthusiast ,
I did notice that, and added it, but that's when I got that error
Votes
Translate
Translate
Report
Report
LEGEND ,
I had a project a long time ago that required allowing users to upload an XML file (typically 3MB) that would extract location data for offices around the world, build a query and insert it into a database.  It's very long and complex, and I won't post it here.. but I will provide some code samples, maybe that can help.
As far as the error message you are getting, something, somewhere is trying to save a complex object as a variable, which obviously can't be done.  I'd have to see your code in order to spot it.
Anyhoo.. after a file is uploaded, I check to make sure that the mimetype is application/xml or text/xml.  Once that has passed, then I read the contents of the .xml file into a variable and check that the contents are proper XML.
<cffile action="read" file="#variables.folder#/to.xml" variable="variables.thisXML" />
<cfswitch expression="#IsXml(variables.thisXML)#">
    <cfcase value="yes">
          <cfset variables.thisXML = xmlParse(variables.thisXML) />
          <cfset variables.CNSLarray = XmlSearch(variables.thisXML,'/contact_info/list_org_id') /><!--- my desired information is now in an array --->
          <cfset variables.CNSL = QueryNew('ID,ORG_ID,NAME,CITY,STATE,ZIP,EMAIL,PHONE') />
          <cfset QueryAddRow(variables.CNSL,arrayLen(variables.CNSLarray)) /><!--- add rows equal to length of my array --->
          <cfloop from="1" to="#arrayLen(variables.CNSLarray)#" index="idx">
              <cfset querySetCell(variables.CNSL,'ID',variables.CNSLarray[idx]) />
          </cfloop>
          <cfset StructDelete(variables,'CNSLarray')  /><!--- garbage collection --->
              <!---  query to delete all data in location table --->
              <!--- query to insert all new data --->
    </cfcase>
    <cfdefaultcase>FILE IS NOT XML - ABORTING<cfabort /></cfdefaultcase>
</cfswitch>
HTH,
^ _ ^
Votes
Translate
Translate
Report
Report
Enthusiast ,
Thanks for that, much appreciated.
There's something odd in all of this, if I try to CFOUTPUT the cfhttp.filecontent, it also throws an error, I guess it must be because of the format, maybe, possibly.
Votes
Translate
Translate
Report
Report
LEGEND ,
Depends upon the error message/details.
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
Community Expert ,
The result attribute of cfhttp is a structure. You get an error because you are attempting to parse it as if it is a string.
You were almost there. Your XML can be obtained as follows:
<cfset xmlString=objGet.fileContent>
<!--- alternative--->
<cfhttp url="http://127.0.0.1/dev/api/test.cfm" method="get">
<cfset xmlString=cfhttp.fileContent>
<cfset xmlObject=xmlParse(xmlString)>
<cfdump var="#xmlObject#">
Votes
Translate
Translate
Report
Report
Enthusiast ,
Got it thanks that did the trick, I can now see the data. My next hurdle would be to actually find a way to use it.
As I've set a developer on this now, I'll get to see how he does this final part and hopefully I'll be able to reverse that in order to create it for other API's that I also need to create.
Votes
Translate
Translate
Report
Report
Community Expert ,
Aug 22, 2018 Aug 22, 2018
Hi @ACS LLC, please mark the correct answer. It will help someone in future.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Aug 24, 2018 Aug 24, 2018
LATEST
Done
Votes
Translate
Translate
Report
Report
Resources
Documentation
