4 Replies Latest reply on Oct 12, 2018 7:30 AM by DeusMerdaeEst
    How to sync LR on two computers/RAID systems in two countries?
    DeusMerdaeEst Level 1
      I am a photographer who lives and works in two countries. I have an office with a MacPro/RAID system in one country, and I have an office with a MacPro/RAID system in another. At the moment, the two RAID systems are exact clones. I would like to keep them like that and for them both to share the same LR catalogue.
      The challenge is this: I spent a month photographing and have 1TB of images, I go to one of my offices and upload all those images onto my RAID, and then work on them in LR for maybe a week or so. I then travel to the other country to my other office. I would like to update the RAID system and the LR catalogue there so that it's the same as the other. I will then continue to work in LR on many other images as well. Next I will shoot for another project and travel to the first office again, etc.
      I can't work out a solution that allows me to work on many images in LR, both new and old, and then export only the images that I have altered. I can't use a cloud based solution, because one of the two locations has very poor internet.
      Does anyone know a solution for this?
      Thank you very much for your help.
        • 1. Re: How to sync LR on two computers/RAID systems in two countries?
          Just Shoot Me Adobe Community Professional
          If the RAID arrays in both location auto Update each other on say a daily basis then place the catalog on an external drive and carry that with you from location to location
          • 2. Re: How to sync LR on two computers/RAID systems in two countries?
            The RAID arrays can't sync because there is very poor internet at one of the two locations. I would therefore need to find a way where I can export the catalogue, but then with only the images that I have worked on. Say I have worked on 50 images from different periods, then I would like to only export those including the LR adjustments. Not sure if that is even possible.
            • 3. Re: How to sync LR on two computers/RAID systems in two countries?
              SeanMcCormack Adobe Community Professional
              I'd use XMP sidecar files. At least for Raw files anyway
              When you save metadata (control/command S) it saves all your edits and metadata (bar collections, virtual copies and flagging) into a sidecar XMP files. These files have the same name as the raw, but with the xmp extension. As long as the raw files have the same name on both computers, you can just transfers the xmp files into the folder of the images on the other computer and then use 'Read Metadata from file' (in the right click menu) with all the corresponding photos selected to have the new edits come in.
              Edit: The xmp files are tiny, so easy to transfer.
              The other option is use an external hardrive with temporary catalogs that you export and import as you go.
              • 4. Re: How to sync LR on two computers/RAID systems in two countries?
                Thank you Sean - but how would temporary catalogs work?
                I have some 500,000 images on each of my two LaCie 6Bigs. One is located in The Netherlands, one in South Africa. When I upload 2,000 images onto the 6Big in SA and work on many of those images, as well as other images that were already on there, then at some stage I will need to export those images (including the adjustments) and import them again when I'm in NL.
                The obvious challenge in that case is: how do I keep track of all the images I have worked on and that need to be added to the other system?
                I would like to keep both systems mirrored, without having to physically move them from place to place to clone them. So far, I have not heard a strategy that can do that. Unless I'm mistaken.
                Thanks.
