2 Replies Latest reply on Aug 23, 2018 10:44 AM by Bartosz_111z
    There were no rejected photos to delete LR Classic 7.5
    Bartosz_111z
      I marked the pictures to be removed using the x key. The selected photos were fade. After that I clicked "Delete Rejected Photos" and LR shows me window "There were no rejected photos to delete" I had reset preference using shift+alt key before starting program. No changes.
      Lightroom Classic version: 7.5 [ 1186149 ]
      Operating system: Windows 7  - Home Premium Edition
      Version: 6.1.7601
      Application architecture: x64
      System architecture: x64
      Logical processor count: 8
      Processor speed: 3,5 GHz
      Built-in memory: 16336,3 MB
      Graphics Processor Info:
      OpenGL: GeForce GT 630/PCIe/SSE2
      Check OpenGL support: Passed
      Vendor: NVIDIA Corporation
      Version: 3.3.0 NVIDIA 391.35
      Renderer: GeForce GT 630/PCIe/SSE2
      LanguageVersion: 3.30 NVIDIA via Cg compiler
      Total Video Memory: 2048 MB
      installed Plugins:
      1) AdobeStock
      2) Canon Tether Plugin
      3) Facebook
      4) Flickr
      5) HDR Efex Pro 2
      6) LR/Enfuse
      7) Nikon Tether Plugin
      + Opal
        • 1. Re: There were no rejected photos to delete LR Classic 7.5
          Sahil.Chawla Adobe Employee
          Hi Bartosz,
          Does the Remove or Cancel dialog contain any other information such as "The Original File cannot be deleted... missing or offline"? If so it simply means the connection between the file and Lightroom has been lost. If they are on an external drive, connect it. If that is not the case then a workaround until a permanent solution is found could be to create a delete folder on your hard drive then move the files to it via Lightroom's Library Module. Remove them from the catalog, then navigate to the folder on your hard drive and delete the files from your system.
          Regards,
          Sahil
          • 2. Re: There were no rejected photos to delete LR Classic 7.5
            Bartosz_111z Level 1
            Hi Sahil,
            There are no messages about unavailable files.
            But there is a message:
            Rejected Photos
            Edited Photos
            Problem solved - removal works but only those photos that have been edited. Strange condition. I will edit minimally to be able to delete photos
            Thank you for your help!
