1 Reply Latest reply on Feb 27, 2008 6:27 AM by jmandawg
    Channel definition mx.messaging.RTMPChannel, can not be found
    jwbworks
      Hello all,
      I just downloaded the latest flex3 because I wanted to take my existing flex2 project and port it as an AIR application. However when I import my current project into flex 3 using the flex2.0.1 hotfix3 compiler. When the project was loaded I get the following problem
      I went in to the WEB-INF/flex/services-config.xml and found
      <channel-definition id="my-rtmp" class="mx.messaging.channels.RTMPChannel">
      <endpoint uri="rtmp://{server.name}:9999" class="flex.messaging.endpoints.RTMPEndpoint"/>
      <properties>
      <idle-timeout-minutes>20</idle-timeout-minutes>
      <client-to-server-maxbps>100K</client-to-server-maxbps>
      <server-to-client-maxbps>100K</server-to-client-maxbps>
      <!-- for deployment on WebSphere, must be mapped to a WorkManager available in the web application's jndi context.
      <websphere-workmanager-jndi-name>java:comp/env/wm/MessagingWorkManager</webspher e-workmanager-jndi-name>
      </properties>
      </channel-definition>
      For this project we are using BEA Weblogic, and we have been doing builds for over a year now with out issues. Any ideas what is causing the problem.
      Thank you your time
      Jeff
