5 Replies Latest reply on Apr 11, 2008 5:49 AM by Quatrol
    DG Header renderer problem
    Misenko Level 1
      Hi, I've encountered a problem with datagrid header renderer. I have custom header renderer based on let's say - Label, or something else, doesn't matter. Now when I run the application, everything is OK. Problem occuress, when I try to click on this header to sort data. Program runs into a loop and CPU is full loaded. I've tried to debug and I've found out, that my custom item renderer constructor (CustomHeaderRenderer ) is called all the time in a loop. Don't understand why... when I use standard header renderer, everything's ok.
      This is the whole code:
      package myClasses
      import mx.controls.Label;
      public class CustomHeaderRenderer extends Label
      public function CustomHeaderRenderer()
      this.text = "Some Text";
      Does anybody knows, where could be a problem ?? thanks
        • 1. Re: DG Header renderer problem
          Misenko Level 1
          nobody knows???
          • 2. Re: DG Header renderer problem
            Sreenivas R Adobe Employee
            Can you post the whole sample code? I tried the same thing and it seems to be working.
            • 3. Re: DG Header renderer problem
              Misenko Level 1
              Hi this is the whole code for header renderer class. Then I assign this header renderer to one of the columns in my datagrid... This is assignment:
              var myHeader:ClassFactory = new ClassFactory(CustomHeaderRenderer);
              myColumn.headerRenderer = myHeader;
              that's all. This loop of permanent creation of header renderer occures when I click on the header to sort...Only thing I can see is the sorting arrow, but the header text dissapear and application goes into a loop.
              • 4. Re: DG Header renderer problem
                Here is the sample code I tried. I tried it using Flex 2.0.1 and Flex 3. I am unable to reprodue your bug.
                quote:
                <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute">
                <mx:Script>
                <![CDATA[
                private var input:Array =
                { x:100, y:10, z:11 },
                { x:20, y:12, z:14 },
                { x:10, y:14, z:18 },
                </mx:Script>
                <mx:DataGrid dataProvider="{input}">
                <mx:columns>
                <mx:DataGridColumn dataField="x" headerRenderer="CustomHeader" headerText="Sample" />
                <mx:DataGridColumn dataField="y" headerRenderer="CustomHeader" headerText="Sample" />
                <mx:DataGridColumn dataField="z" headerRenderer="CustomHeader" headerText="Sample" />
                </mx:columns>
                </mx:DataGrid>
                </mx:Application>
                quote:
                package
                public class CustomHeader extends Label
                public function CustomHeader()
                super();
                this.text = "Some text";
                • 5. Re: DG Header renderer problem
                  I've also stumbled upon this issue, the problem occurs when the data grid is using variable row heights.
                  here's an example with the problem occurring:
                  <mx:Application
                  xmlns:local="*"
                  layout="horizontal"
                  verticalAlign="middle"
                  initialize="initializeGridData()">
                  <mx:Script>
                  <![CDATA[
                  import mx.collections.ArrayCollection;
                  [Bindable]
                  private var gridData: ArrayCollection = new ArrayCollection();
                  public function initializeGridData():void
                  for (var i: uint = 0; i < 5; i++)
                  var item: Object = new Object();
                  item.sequence = i;
                  gridData.addItem(item);
                  </mx:Script>
                  <mx:DataGrid id="rankedGrid" dataProvider="{gridData}"
                  allowMultipleSelection="true" variableRowHeight="true">
                  <mx:columns>
                  <mx:DataGridColumn headerText="fixed wdith really long label"
                  width="50" dataField="sequence" headerRenderer="mx.controls.Label"/>
                  </mx:columns>
                  </mx:DataGrid>
                  </mx:Application>
