1 Reply Latest reply on Aug 27, 2018 7:17 AM by Jim_Simon
    MultiChannel Audio Export - Tracks lowered 3dB!?
    Rode Kater Producties
      Hi Guys,
      I have a rather funky problem with Premiere. It is changing my audio levels on output!
      I'm using Premiere Pro as my online editor and I make a lot of exports for broadcast and film. One thing they require me to do is to export multichannel audio so they will have access to a 5.1 mix + LtRt or to the stems I received from my audio engineer. My workflow is this:
      1. I create a new sequence
      2. I modify the channel mapping in the tracks section so that I will have a Multichannel sequence with 8 channels mapped respectively to channel 1-8 and panning them left and right so the stereo pairs all get one input from one mono channel.
      3. I add my audio clips in the right order in the timeline. When I check my VU-meters they show that all channels are mapped correctly and that volume matches the volume I see in my independent tracks VU-Meters.
      4. I export in XDCAM or ProRes and upload it to the broadcaster trusting Premiere to create an export that is the same as what I've been seeing in my timeline.
      This used to be my workflow for the last three years and I never had problems until now. Suddenly when I compare the export with my timeline there is a difference of -3dB. In older versions this never was the case so I wonder what has happened. I know that stereo pairs get attenuated -3dB when you stack them but this doesn't seem like proper behaviour. And even if this is the case, why doesn't my VU-meters reflect the changes that Premiere is applying to my audio?
      It feels like a bug and I can't find a new proper workflow to resolve this problem. The only solution I could come up with is to apply a gain of 3dB, effectively exporting 3dB too loud. This feels rather hacky and I would like to steer away from it.
      I love this problem to be resolved asap or an option to have a 'direct out'-option in the sequence settings that doesn't tinker with my audio tracks on exporting.
      Technical stuff:
      - Working on the latest version of Premiere (12.1.2)
      - Tested this problem on multiple Mac computers (High Sierra), will post back after testing on Windows as well.
