rateOfSpeed=1;
clockStartTime = thisComp.layer(“slider”).effect(“Slider Control”)(“Slider”)*60;
clockTimeNumber = Math.floor(clockStartTime – rateOfSpeed*time);
function addZero(n) {
if (n<10) return “0” + n else return n;
minutes = Math.floor(clockTimeNumber/60);
seconds = clockTimeNumber%60;
if (clockStartTime > 0 && time < clockStartTime) {
addZero(minutes) + “:” + addZero(seconds);
} else {“00:00”}
This is the code I'm using to create a timer but there is an error and it dosen't work.
[This post moved to After Effects Scripting by Moderator]
Took me like 15 minutes to figure this out. It's your keyboard. Switch it to English. The quotes are not of the correct type. Also, your minus from the third line of code its not a minus. Here is the working code:
rateOfSpeed=1;
clockStartTime =thisComp.layer("slider").effect("Slider Control")("Slider")*60;
clockTimeNumber = Math.floor(clockStartTime - rateOfSpeed*time);
if (n<10) return "0" + n else return n;
addZero(minutes) + ":" + addZero(seconds);
} else {"00:00"}
Moved from After Effects Scripting to After Effects Expressions
