1 Reply Latest reply on Feb 7, 2008 5:49 AM by Gregory Lafrance
    passing data between states
    vij010 Level 1
      How do you pass data between 2 states in an application ?, I have a login form I want to capture the user name and show the name on a seperate state, how do I pass the value ?
      Vj
        • 1. Re: passing data between states
          Gregory Lafrance Level 6
          If you are using ViewState then you could use global variables. Or you could use an array, or maybe a custom object. If you are using components defined in separate files you could pass info using Application.application, parentDocument, or parentApplication properties, and other techniques.
