7 Replies Latest reply on Sep 7, 2018 8:55 AM by Akash Sharma
    Lightroom use too much memory and CPU
    gawakoto Level 1
      Lightroom all of a sudden takes a very long while to export photos.  When i checked my activity monitor, LR is hogging my cpu and memory. This is the first time it ever happened.
        • 1. Re: Lightroom use too much memory and CPU
          Akash Sharma Adobe Employee
          Hi gawakoto,
          Sorry that Lightroom is using high memory while exporting images.
          Could you please let us know the version of Lightroom you're using and how many images at once are you exporting?
          Akash
          • 2. Re: Lightroom use too much memory and CPU
            gawakoto Level 1
            I was using the 7.5 then I tried to revert back to 7.4 still the same thing
            • 3. Re: Lightroom use too much memory and CPU
              gawakoto Level 1
              I was exporting 60 images.
              • 4. Re: Lightroom use too much memory and CPU
                Thanks for update. What are the specifications of your computer? Also, could you please provide us a screenshot of the Activity monitor illustrating high spike in CPU usage while exporting from Lightroom?
                Also, please provide us the Help>>System info details from Lightroom.
                • In Lightroom, select Help > System Info from the menu bar.
                • In the System Info dialog, click Copy.and paste it here.
                ~Akash
                • 5. Re: Lightroom use too much memory and CPU
                  gawakoto Level 1
                  Lightroom Classic version: 7.5 License: Creative CloudLanguage setting: en-CAOperating system: Mac OS 10Version: 10.13.6 Application architecture: x64Logical processor count: 4Processor speed: 2.9 GHzBuilt-in memory: 16,384.0 MBReal memory available to Lightroom: 16,384.0 MBReal memory used by Lightroom: 5,954.9 MB (36.3%)Virtual memory used by Lightroom: 7,529.4 MBMemory cache size: 161.8MBInternal Camera Raw revision: 1001Maximum thread count used by Camera Raw: 3Camera Raw SIMD optimization: SSE2,AVXCamera Raw virtual memory: 630MB / 8191MB (7%)Camera Raw real memory: 631MB / 16384MB (3%)Displays: 1) 1280x800
                  Graphics Processor Info: Metal: Intel HD Graphics 4000
                  Application folder: /Applications/Adobe Lightroom Classic CCLibrary Path: /Users/markoliverancheta/Pictures/mark ancheta 2016/mark ancheta 2016-2.lrcatSettings Folder: /Users/markoliverancheta/Library/Application Support/Adobe/Lightroom
                  Installed Plugins: 1) AdobeStock2) Aperture/iPhoto Importer Plug-in3) Aurora HDR 20174) Aurora HDR 20185) Canon Tether Plugin6) ColorChecker Passport7) Export to Photomatix Pro8) Facebook9) Flickr10) FX Photo Studio CK11) HDR Efex Pro 212) Luminar13) Luminar 201814) Macphun Creative Kit15) Nikon Tether Plugin16) ON1 Photo RAW 201817) ON1 Resize 201818) Snapheal CK
                  Config.lua flags: None
                  AudioDeviceIOBlockSize: 512AudioDeviceName: Built-in OutputAudioDeviceNumberOfChannels: 2AudioDeviceSampleRate: 44100Build: 10.0x7CoreImage: trueGL_ACCUM_ALPHA_BITS: 0GL_ACCUM_BLUE_BITS: 0GL_ACCUM_GREEN_BITS: 0GL_ACCUM_RED_BITS: 0GL_ALPHA_BITS: 8GL_BLUE_BITS: 8GL_DEPTH_BITS: 24GL_GREEN_BITS: 8GL_MAX_3D_TEXTURE_SIZE: 2048GL_MAX_TEXTURE_SIZE: 16384GL_MAX_TEXTURE_UNITS: 8GL_MAX_VIEWPORT_DIMS: 16384,16384GL_RED_BITS: 8GL_RENDERER: Intel HD Graphics 4000 OpenGL EngineGL_SHADING_LANGUAGE_VERSION: 1.20GL_STENCIL_BITS: 8GL_VENDOR: Intel Inc.GL_VERSION: 2.1 INTEL-10.36.19OGLEnabled: trueGL_EXTENSIONS: GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_blend GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_clip_volume_hint GL_EXT_debug_label GL_EXT_debug_marker GL_EXT_draw_buffers2 GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture_array GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_rectangle GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array_bgra GL_APPLE_aux_depth_stencil GL_APPLE_client_storage GL_APPLE_element_array GL_APPLE_fence GL_APPLE_float_pixels GL_APPLE_flush_buffer_range GL_APPLE_flush_render GL_APPLE_object_purgeable GL_APPLE_packed_pixels GL_APPLE_pixel_buffer GL_APPLE_rgb_422 GL_APPLE_row_bytes GL_APPLE_specular_vector GL_APPLE_texture_range GL_APPLE_transform_hint GL_APPLE_vertex_array_object GL_APPLE_vertex_array_range GL_APPLE_vertex_point_size GL_APPLE_vertex_program_evaluators GL_APPLE_ycbcr_422 GL_ATI_separate_stencil GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_IBM_rasterpos_clip GL_NV_blend_square GL_NV_conditional_render GL_NV_depth_clamp GL_NV_fog_distance GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_barrier GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod
                     On Thursday, 30 August 2018, 9:56:47 AM MDT, Akash Sharma <forums_noreply@adobe.com> wrote:
                  created by Akash Sharma in Lightroom Classic CC — The desktop-focused app - View the full discussion
                     - In Lightroom, select Help > System Info from the menu bar.
                     - In the System Info dialog, click Copy.and paste it here.
                  ~Akash
                  If the reply above answers your question, please take a moment to mark this answer as correct by visiting: https://forums.adobe.com/message/10591248#10591248 and clicking ‘Correct’ below the answer
                  Replies to this message go to everyone subscribed to this thread, not directly to the person who posted the message. To post a reply, either reply to this email or visit the message page:
                  Please note that the Adobe Forums do not accept email attachments. If you want to embed an image in your message please visit the thread in the forum and click the camera icon: https://forums.adobe.com/message/10591248#10591248
                  To unsubscribe from this thread, please visit the message page at , click "Following" at the top right, & "Stop Following"
                  Start a new discussion in Lightroom Classic CC — The desktop-focused app by email or at Adobe Community
                  For more information about maintaining your forum email notifications please go to https://forums.adobe.com/thread/1516624.
                  This email was sent by Adobe Community because you are a registered user.
                  You may unsubscribe instantly from Adobe Community, or adjust email frequency in your email preferences
                  • 7. Re: Lightroom use too much memory and CPU
                    Thanks for providing the details. Please try unchecking the option "use graphics processor" under Preferences> Performance menu in Lightroom and check if the app still uses that much memory in the Activity monitor?
                    Also, test create a new catalog and check how the application behaves.
                    Regards,
                    Akasj
