1 Reply Latest reply on Feb 8, 2008 1:13 AM by jammiejinx
    Pull var from XML data
    jammiejinx Level 1
      I've been given a bit of AS to to modify but I'm having trouble with one thing. I'm trying to define a variable from an XML document. The variable would be pulled from the last value val6. I really know very little in depth AS, I can get the value to be displayed in a text field and to trace but not as a variable I can use elsewhere.
      Thanks in advance for any help.
        • 1. Re: Pull var from XML data
          jammiejinx Level 1
          Ok I'll try to explain a little clearer:
          I have an XML document, one value of the XML is to be a URL which I would then like to use in the actionscript as the image file path when loading external images.
          The reason being that the file will be used on different sites with different file paths (out of my control).
