7 Replies Latest reply on Sep 13, 2018 10:06 PM by hooplife
    Premiere CC 2018 Crashes every time
    hooplife Level 1
      I can't open the Premier CC 2018.  Crashes every time I open it.
        • 1. Re: Premiere CC 2018 Crashes every time
          Might want to do what is says: read the crash report.
          • 2. Re: Premiere CC 2018 Crashes every time
            Vidya Sagar Adobe Employee
            Hi hooplife,
            Sorry for the trouble. As Ann Bens mentioned, we need crash report; share a screenshot with us. FAQ: How do I capture and post a screen shot or video?
            What are the system specs(OS version, RAM, GPU, CPU)? What is the version of Premiere Pro? FAQ: How to find the exact version of Premiere Pro you're using?
            Are there any third party plugins installed in the machine? Are you logged in as an Administrator?
            Vidya
            • 3. Re: Premiere CC 2018 Crashes every time
              hooplife Level 1
              Here is my system specs
              Below is the crash report
              Process:               Adobe Premiere Pro CC 2018 [621]
              Path:                  /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/MacOS/Adobe Premiere Pro CC 2018
              Identifier:            com.adobe.PremierePro.CC12
              Version:               12.1.2 (12.1.2)
              Code Type:             X86-64 (Native)
              Parent Process:        ??? [1]
              Responsible:           Adobe Premiere Pro CC 2018 [621]
              User ID:               501
              Date/Time:             2018-09-03 15:59:38.357 +0300
              OS Version:            Mac OS X 10.12.6 (16G1114)
              Report Version:        12
              Anonymous UUID:        7A86804E-6F42-4489-F0CC-E3686B0A4E70
              Sleep/Wake UUID:       521AA26C-6AB5-4692-B425-3896DCBDE07F
              Time Awake Since Boot: 1200 seconds
              Time Since Wake:       380 seconds
              System Integrity Protection: enabled
              Crashed Thread:        0  Dispatch queue: com.apple.main-thread
              Exception Type:        EXC_BAD_INSTRUCTION (SIGILL)
              Exception Codes:       0x0000000000000001, 0x0000000000000000
              Exception Note:        EXC_CORPSE_NOTIFY
              Termination Signal:    Illegal instruction: 4
              Termination Reason:    Namespace SIGNAL, Code 0x4
              Terminating Process:   exc handler [0]
              Application Specific Information:
              dyld: in dlopen()
              BUG IN LIBTRACE: MH not found
              Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
              0   libsystem_trace.dylib          0x00007fffa8e80e97 _os_trace_image_was_unloaded + 271
              1   dyld                          0x00000001049c6cb2 dyld::removeImage(ImageLoader*) + 343
              2   dyld                          0x00000001049ca6c7 dyld::garbageCollectImages() + 870
              3   dyld                          0x00000001049d254b dlopen + 907
              4   libdyld.dylib                  0x00007fffa8c4b832 dlopen + 59
              5   com.adobe.dvacore.framework    0x00000001001274e5 dvacore::config::lazyloader::LoadAndInitDependency(char const*) + 1605
              6   com.adobe.Mezzanine.framework 0x000000010f706ec9 MZ::(anonymous namespace)::FullInitializer::FullInitializer(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, bool, bool) + 12889
              7   com.adobe.Mezzanine.framework 0x000000010f703414 MZ::Initializer::Initializer(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, bool, bool, bool) + 84
              8   com.adobe.Frontend.framework  0x00000001027e11e8 FE::(anonymous namespace)::FullInitializer::FullInitializer() + 1672
              9   com.adobe.Frontend.framework  0x00000001027e0ac5 FE::Initializer::Initializer() + 149
              10  com.adobe.Frontend.framework  0x0000000102822911 FE::AppMain(boost::shared_ptr<ASL::Module> const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 353
              11  com.adobe.Frontend.framework  0x00000001028240c3 FE::Run(boost::shared_ptr<ASL::Module> const&, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int) + 659
              12  com.adobe.PremierePro.CC12    0x0000000100007bc0 main + 896
              13  libdyld.dylib                  0x00007fffa8c4e235 start + 1
              Thread 1:
              0   libsystem_kernel.dylib        0x00007fffa8d7d44e __workq_kernreturn + 10
              1   libsystem_pthread.dylib        0x00007fffa8e67621 _pthread_wqthread + 1426
              2   libsystem_pthread.dylib        0x00007fffa8e6707d start_wqthread + 13
              Thread 2:
              1   libsystem_pthread.dylib        0x00007fffa8e6748e _pthread_wqthread + 1023
              Thread 3:
              Thread 4:: Dispatch queue: com.apple.root.default-qos
              0   libsystem_kernel.dylib        0x00007fffa8d7cc22 __psynch_mutexwait + 10
              1   libsystem_pthread.dylib        0x00007fffa8e67dfa _pthread_mutex_lock_wait + 100
              2   libsystem_pthread.dylib        0x00007fffa8e65519 _pthread_mutex_lock_slow + 285
              3   libdyld.dylib                  0x00007fffa8c4a118 dyldGlobalLockAcquire() + 16
              4   dyld                          0x00000001049d2230 dlopen + 112
              5   libdyld.dylib                  0x00007fffa8c4b832 dlopen + 59
              6   com.apple.CoreFoundation      0x00007fff934860b6 _CFBundleDlfcnCheckLoaded + 102
              7   com.apple.CoreFoundation      0x00007fff934ecf4e _CFBundleLoadExecutableAndReturnError + 318
              8   com.apple.CoreFoundation      0x00007fff93524b82 CFBundleGetFunctionPointerForName + 50
              9   com.adobe.ASLFoundation.framework 0x0000000102660cdb ASL::Module::GetProcAddress(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&) const + 363
              10  com.adobe.PluginSupport.framework 0x00000001071205ca ML::PluginImpl::GetEntryPoint(std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 138
              11  com.adobe.VideoFilterHost.framework 0x0000000107a7a3fb ML::AEPluginVideoFilterModule::GetEntryPoint() + 347
              12  com.adobe.VideoFilterHost.framework 0x0000000107aa5515 ML::AEVideoFilterModule::GlobalSetup(bool) + 245
              13  com.adobe.VideoFilterHost.framework 0x0000000107aa4f1f ML::AEVideoFilterModule::SetupFilter() + 79
              14  com.adobe.VideoFilterHost.framework 0x0000000107a7cb6b ML::AEVideoFilter::Create(ASL::InterfaceRef<ML::AEVideoFilterModule, ML::IPluginModule>) + 155
              15  com.adobe.VideoFilterHost.framework 0x0000000107aa4e77 ML::AEVideoFilterModule::CreateFilter(ASL::InterfaceRef<BE::IVideoFilter, BE::IVideoFilter>&) + 39
              16  com.adobe.VideoFilterHost.framework 0x0000000107ae3b4a ML::VideoFilterFactory::CreateVideoFilter(ASL::InterfaceRef<ML::IVideoFilterModule, ML::IVideoFilterModule>) const + 186
              17  com.adobe.VideoFilterHost.framework 0x0000000107ae3de3 ML::VideoFilterFactory::CreateVideoFilter(dvacore::utility::ImmutableString const&, int) const + 67
              18  com.adobe.EncoderHost.framework 0x000000010f0134bd EncoderHost::StandardFilterWrapper::CreateVideoFilter() + 221
              19  com.adobe.EncoderHost.framework 0x000000010f0151c1 EncoderHost::StandardFilterWrapper::IsUnderlyingVideoFilterHealthy() + 33
              20  com.adobe.EncoderHost.framework 0x000000010f02f6a1 EncoderHost::StandardFilterWrapperLumetri::UpdateMainDropList() + 209
              21  com.adobe.EncoderHost.framework 0x000000010f02f14a EncoderHost::StandardFilterWrapperLumetri::GetFilterParams(ASL::InterfaceRef<MF::IExporte rParam, MF::IExporterParam>) + 4490
              22  com.adobe.EncoderHost.framework 0x000000010f000a4b EncoderHost::StandardFilterContainer::SetupParamContainer(bool, bool) + 811
              23  com.adobe.EncoderHost.framework 0x000000010ef7bfad EncoderHost::Encoder::LoadPreset(ASL::InterfaceRef<EncoderHost::IPreset, EncoderHost::IPreset>, bool, unsigned int*, std::__1::basic_string<unsigned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> >*) + 1949
              24  com.adobe.Mezzanine.framework 0x000000010fa37bdd MZ::SequenceSettingsCache::GetSequencePreviewPresetFromCache(std::__1::basic_string<unsig ned short, std::__1::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, ASL::InterfaceRef<BE::ISequence, BE::ISequence>) + 4285
              25  com.adobe.Mezzanine.framework 0x000000010fa3c7dc MZ::(anonymous namespace)::SequenceSettingsCacheImpl::PreloadCodecsAsync() + 1340
              26  com.adobe.dvacore.framework    0x00000001001f0f82 dvacore::threads::(anonymous namespace)::SubExecutorImpl<dvacore::threads::ThreadSafeQueue<dvacore::threads::(anonymou s namespace)::AllocatedFunctionWithSerialNumber> >::CallFunctionWithExceptionHandler(boost::function<void ()> const&) + 34
              27  com.adobe.dvacore.framework    0x00000001001f222f dvacore::threads::(anonymous namespace)::SubExecutorImpl<dvacore::threads::ThreadSafeQueue<dvacore::threads::(anonymou s namespace)::AllocatedFunctionWithSerialNumber> >::OnThreadExecute(boost::shared_ptr<dvacore::threads::(anonymous namespace)::SubExecutorImpl<dvacore::threads::ThreadSafeQueue<dvacore::threads::(anonymou s namespace)::AllocatedFunctionWithSerialNumber> > > const&) + 191
              28  com.adobe.dvacore.framework    0x00000001001fcab2 dvacore::threads::ExecuteTopLevelFunction(boost::function<void ()> const&) + 98
              29  com.adobe.dvacore.framework    0x00000001002108ff dvacore::threads::WrapExecuteTopLevelFunction(void*) + 15
              30  libdispatch.dylib              0x00007fffa8c188fc _dispatch_client_callout + 8
              31  libdispatch.dylib              0x00007fffa8c27196 _dispatch_queue_override_invoke + 743
              32  libdispatch.dylib              0x00007fffa8c1a6b5 _dispatch_root_queue_drain + 476
              33  libdispatch.dylib              0x00007fffa8c1a48c _dispatch_worker_thread3 + 99
              34  libsystem_pthread.dylib        0x00007fffa8e675a2 _pthread_wqthread + 1299
              35  libsystem_pthread.dylib        0x00007fffa8e6707d start_wqthread + 13
              Thread 5:
              0   libsystem_kernel.dylib        0x00007fffa8d7dd96 kevent + 10
              1   com.adobe.dvatransport.framework 0x000000010412fbac boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 268
              2   com.adobe.dvatransport.framework 0x000000010412f65c boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 380
              3   com.adobe.dvatransport.framework 0x000000010412f325 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 181
              4   com.adobe.dvatransport.framework 0x0000000104124c42 SkyConnectionEnv::MainLoop() + 162
              5   com.adobe.dvatransport.framework 0x00000001041245f9 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
              6   com.adobe.boost-threads.framework 0x000000010003f395 boost::(anonymous namespace)::thread_proxy(void*) + 165
              7   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
              8   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
              9   libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
              Thread 6:
              0   libsystem_kernel.dylib        0x00007fffa8d7cbf2 __psynch_cvwait + 10
              1   libsystem_pthread.dylib        0x00007fffa8e687fa _pthread_cond_wait + 712
              2   com.adobe.dvatransport.framework 0x000000010412f5e7 boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 263
              4   com.adobe.dvatransport.framework 0x000000010413a75a boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 42
              5   com.adobe.dvacore.framework    0x00000001001b21e3 boost_asio_detail_posix_thread_function + 19
              6   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
              7   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
              8   libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
              Thread 7:
              2   com.adobe.dvacore.framework    0x00000001000f3831 boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 65
              3   com.adobe.dvacore.framework    0x00000001000f356b dvacore::threads::ThreadSafeQueueBase::Pop(void*&, int) + 171
              4   com.adobe.dvacore.framework    0x000000010020eb41 dvacore::threads::ThreadSafeDelayQueue::PopWithTimeout(std::__1::auto_ptr<dvacore::thread s::AllocatedFunctionT<boost::function<void ()> > >&, int) + 145
              5   com.adobe.dvacore.framework    0x000000010020d029 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 153
              6   com.adobe.dvacore.framework    0x000000010020a16f dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 367
              7   com.adobe.boost-threads.framework 0x000000010003f395 boost::(anonymous namespace)::thread_proxy(void*) + 165
              8   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
              9   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
              10  libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
              Thread 8:: VulcanMsgRecv
              0   libsystem_kernel.dylib        0x00007fffa8d7cdf6 __recvfrom + 10
              1   VulcanMessage5.dylib          0x000000010bc3a2b8 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
              2   VulcanMessage5.dylib          0x000000010bc3967c vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
              3   VulcanMessage5.dylib          0x000000010bc38974 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
              4   VulcanMessage5.dylib          0x000000010bc38838 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
              5   VulcanMessage5.dylib          0x000000010bc33477 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
              6   VulcanMessage5.dylib          0x000000010bc33f06 vcfoundation::io::Serializer::InternalDeserialize() + 30
              7   VulcanMessage5.dylib          0x000000010bc3389f vcfoundation::io::Serializer::Deserialize() + 9
              8   VulcanMessage5.dylib          0x000000010bc37924 vcfoundation::ncomm::Connection::ReadIn() + 22
              9   VulcanMessage5.dylib          0x000000010bc3737d vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
              10  VulcanMessage5.dylib          0x000000010bc3706a vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
              11  VulcanMessage5.dylib          0x000000010bc36fbd vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
              12  VulcanMessage5.dylib          0x000000010bc2a7f8 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
              13  VulcanMessage5.dylib          0x000000010bc29a36 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
              14  VulcanMessage5.dylib          0x000000010bc381bc vcfoundation::thread::AbstractThread::Run() + 72
              15  VulcanMessage5.dylib          0x000000010bc3a0b9 vcfoundation::thread::Thread::ThreadProc(void*) + 9
              16  libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
              17  libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
              18  libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
              Thread 9:: com.apple.audio.IOThread.client
              0   libsystem_kernel.dylib        0x00007fffa8d7534a mach_msg_trap + 10
              1   libsystem_kernel.dylib        0x00007fffa8d74797 mach_msg + 55
              2   com.apple.audio.CoreAudio      0x00007fff93029935 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 127
              3   com.apple.audio.CoreAudio      0x00007fff930298a6 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42
              4   com.apple.audio.CoreAudio      0x00007fff930268d0 HALC_ProxyIOContext::IOWorkLoop() + 1196
              5   com.apple.audio.CoreAudio      0x00007fff93026264 HALC_ProxyIOContext::IOThreadEntry(void*) + 128
              6   com.apple.audio.CoreAudio      0x00007fff93025fa3 HALB_IOThread::Entry(void*) + 75
              Thread 10:
              Thread 11:
              Thread 12:
              Thread 13:
              Thread 14:
              0   libsystem_kernel.dylib        0x00007fffa8d7539e semaphore_timedwait_trap + 10
              1   com.apple.CoreServices.CarbonCore 0x00007fff943ccd1b MPWaitOnSemaphore + 71
              2   REDR3D.dylib                  0x0000000135f87c87 0x135e40000 + 1342599
              3   REDR3D.dylib                  0x0000000135f3ee02 0x135e40000 + 1043970
              4   libsystem_pthread.dylib        0x00007fffa8e6793b _pthread_body + 180
              5   libsystem_pthread.dylib        0x00007fffa8e67887 _pthread_start + 286
              6   libsystem_pthread.dylib        0x00007fffa8e6708d thread_start + 13
              Thread 15:
              2   REDR3D.dylib                  0x0000000135f88807 0x135e40000 + 1345543
              Thread 16:
              Thread 17:
              Thread 18:
              Thread 19:
              2   com.apple.CoreFoundation      0x00007fff934c0434 __CFRunLoopServiceMachPort + 212
              3   com.apple.CoreFoundation      0x00007fff934bf8c1 __CFRunLoopRun + 1361
              4   com.apple.CoreFoundation      0x00007fff934bf114 CFRunLoopRunSpecific + 420
              5   com.apple.AVCVideoServices    0x000000013e74dad2 AVS::AVCVideoServicesThreadStart(AVS::AVCVideoServicesThreadParams*) + 162
              Thread 20:
              Thread 0 crashed with X86 Thread State (64-bit):
                rax: 0x0000000125054010  rbx: 0x00000000000000b2  rcx: 0x00007fffa8e8edb0  rdx: 0x00000000000000ab
                rdi: 0x0000000000000000  rsi: 0x0000000125054000  rbp: 0x00007fff5fbfb370  rsp: 0x00007fff5fbfb320
                 r8: 0x00000000000001f0   r9: 0x00000001247b2400  r10: 0x0000000000031001  r11: 0xffff8001c4bbe5e0
                r12: 0x00000001247b2800  r13: 0x00000001431eb000  r14: 0x00000001247b2808  r15: 0x4dd9090210e20031
                rip: 0x00007fffa8e80e97  rfl: 0x0000000000010246  cr2: 0x000000014bbce50b
              Logical CPU:     0
              Error Code:      0x00000000
              Trap Number:     6
              Binary Images:
                     0x100000000 -        0x100007ff7 +com.adobe.PremierePro.CC12 (12.1.2 - 12.1.2) <4B73B4B4-B982-34C9-81B2-A9A664CB8847> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/MacOS/Adobe Premiere Pro CC 2018
                     0x10000d000 -        0x100013fff +com.adobe.AdobeCrashReporter (7.7 - 7.7.0) <FA36FB74-CC30-3BFC-BC2C-4025E64F8C6A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                     0x10001f000 -        0x100020ff3 +com.adobe.boost-system.framework (12.1.2 - 12.1.2.69) <24EF9CA8-E663-3396-B593-3E275BE83204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                     0x100028000 -        0x10002cfff +com.adobe.boost-date-time.framework (12.1.2 - 12.1.2.69) <E4727EFC-83A2-31C7-8740-6AAB964723D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                     0x10003d000 -        0x10004aff7 +com.adobe.boost-threads.framework (12.1.2 - 12.1.2.69) <60EB538A-DB63-33DA-B351-2189E2945EA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                     0x100068000 -        0x100075fff +com.adobe.boost-filesystem.framework (12.1.2 - 12.1.2.69) <169D6D1B-EBBF-3529-B93E-0107A43FB7D7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                     0x10008a000 -        0x1000a3fff +com.adobe.dvaunittesting.framework (12.1.2 - 12.1.2.69) <3BF41758-7436-3E39-A4DF-C7BB0C2EE018> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                     0x1000d8000 -        0x100450fff +com.adobe.dvacore.framework (12.1.2 - 12.1.2.69) <4E8C8538-6240-36EF-B307-BEFF249EB67B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                     0x10075e000 -        0x100792fff +com.adobe.dvaappsupport.framework (12.1.2 - 12.1.2.69) <5234904E-FF9B-3AB9-8229-3F01CDF6B746> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaappsupport.framework/Versions/A/dvaappsupport
                     0x1007ea000 -        0x100ed7fff +com.adobe.dvaui.framework (12.1.2 - 12.1.2.69) <7DDB6DAD-68D9-37FD-AEB7-6BBC905B8848> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                     0x101ac7000 -        0x101cd8ff7 +com.adobe.MBCProvider.framework (12.1.2 - 12.1.2.69) <433E47AB-1261-3BBE-A0EF-0D1B655BB5D0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MBCProvider.framework/Versions/A/MBCProvider
                     0x101e8c000 -        0x101eb1fff +com.adobe.dvamediaui.framework (12.1.2 - 12.1.2.69) <6F1A328B-D44F-39AD-9101-9AB84944D299> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediaui.framework/Versions/A/dvamediaui
                     0x101f13000 -        0x102070fff +com.adobe.dvamediabrowser.framework (12.1.2 - 12.1.2.69) <D8DD93F0-663B-33CA-8902-AF52126A58CD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediabrowser.framework/Versions/A/dvamediabrowser
                     0x10231a000 -        0x1023c8ff7 +com.adobe.TransmitVRHost.framework (12.1.2 - 12.1.2.69) <0496432C-78E7-3E98-AC62-64DA66CE449C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TransmitVRHost.framework/Versions/A/TransmitVRHost
                     0x1024ec000 -        0x1024eeff7 +com.adobe.PRM.framework (12.1.2 - 12.1.2.69) <CDE494A8-D9E9-39F4-852A-7E04445D83DE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
                     0x1024f9000 -        0x102566fff +com.adobe.dvamediatypes.framework (12.1.2 - 12.1.2.69) <CF1C0566-8AF5-3ED5-9935-86E98B060B29> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                     0x10261b000 -        0x102673ff7 +com.adobe.ASLFoundation.framework (12.1.2 - 12.1.2.69) <C7FE2F6C-F42D-3131-BA2C-D1A005CFF2AF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
                     0x1026e7000 -        0x10291ffff +com.adobe.Frontend.framework (12.1.2 - 12.1.2.69) <145FFDBF-A0FF-3651-A931-F972C952031B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
                     0x102c9c000 -        0x102e5eff7 +com.adobe.amtlib (10.0.0.250 - 10.0.0.250) <172741F8-9E54-317F-A72B-51D05CC05182> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                     0x102e79000 -        0x102f4cfff +com.adobe.dvascripting.framework (12.1.2 - 12.1.2.69) <DC030805-7C1A-3B1A-A027-90AFC649C226> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvascripting.framework/Versions/A/dvascripting
                     0x103191000 -        0x1031b3fff +com.adobe.ASLMessaging.framework (12.1.2 - 12.1.2.69) <5F55175A-5BAC-39B2-93ED-2908DC2EEE0E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
                     0x103203000 -        0x103ae8fc7 +com.adobe.dvaaccelerate.framework (12.1.2 - 12.1.2.69) <6B237AA5-FB0C-39B9-BB20-D7A942D98464> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaccelerate.framework/Versions/A/dvaaccelerate
                     0x103bed000 -        0x103e4afe7 +com.adobe.dvaaudiodsp.framework (12.1.2 - 12.1.2.69) <818F0533-0CB6-3289-B4D7-1C3B69A10DDB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodsp.framework/Versions/A/dvaaudiodsp
                     0x104101000 -        0x104103ff7 +com.adobe.Memory.framework (12.1.2 - 12.1.2.69) <29A797B7-5BD7-3A40-8275-DAAC57B061ED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
                     0x10410b000 -        0x104163ff7 +com.adobe.dvatransport.framework (12.1.2 - 12.1.2.69) <88F78E08-C945-39A2-BA73-D052FEB1A166> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                     0x104200000 -        0x104221fff +com.adobe.dvamarshal.framework (12.1.2 - 12.1.2.69) <97B637CC-1E4F-3A2B-A206-C4A175EDF68C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                     0x104265000 -        0x1044b4fff +com.adobe.dynamiclink.framework (12.1.2 - 12.1.2.69) <FDFB3C59-C8C9-3261-8C76-12E44E5A0C3C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                     0x1047b6000 -        0x104859fff +com.adobe.MediaFoundation.framework (12.1.2 - 12.1.2.69) <419C7E97-5046-3739-A6A2-555E0236466B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
                     0x104946000 -        0x10496fff7 +com.adobe.SweetPeaSupport.framework (12.1.2 - 12.1.2.69) <EF1AFE64-61B8-3503-8D95-C2429C9AE27D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
                     0x1049c5000 -        0x104a02dc7  dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
                     0x104a50000 -        0x104acafff +com.adobe.AudioRenderer.framework (12.1.2 - 12.1.2.69) <97A27DC9-971D-364A-8948-EEF7D3211025> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
                     0x104b91000 -        0x104cbdff7 +com.adobe.dvacaptioning.framework (12.1.2 - 12.1.2.69) <5C9A446F-8338-3529-AF9F-2EE687B445EF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacaptioning.framework/Versions/A/dvacaptioning
                     0x104db1000 -        0x104dfcfff +com.adobe.dvatemporalxmp.framework (12.1.2 - 12.1.2.69) <A5051B93-5997-306D-8D19-E16FECF946A2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                     0x104e32000 -        0x104ebbff7 +com.adobe.dvametadata.framework (12.1.2 - 12.1.2.69) <74880A28-97DC-3774-AA80-41730CFF3699> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                     0x104f8b000 -        0x105c85ff7 +com.adobe.Backend.framework (12.1.2 - 12.1.2.69) <8A85E254-7073-30F3-8D08-0E24F00A13D3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
                     0x106c8c000 -        0x106cb5fff +com.adobe.MLFoundation.framework (12.1.2 - 12.1.2.69) <70A8FD1A-3FF3-3D05-8678-ECB3D808F60C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
                     0x106d10000 -        0x106e68fd7 +com.adobe.ImageRenderer.framework (12.1.2 - 12.1.2.69) <8D838BA1-F6A6-3BD5-A04C-D8832165554D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
                     0x106faf000 -        0x10705ffff +com.adobe.VideoFrame.framework (12.1.2 - 12.1.2.69) <AACAF49F-0186-38D4-9AC5-F2F8D6E5C7BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
                     0x1070f9000 -        0x107147ff7 +com.adobe.PluginSupport.framework (12.1.2 - 12.1.2.69) <E3E53E37-97C4-3727-91D2-07B0BC61FD06> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
                     0x1071b2000 -        0x1071eefff +com.adobe.AudioSupport.framework (12.1.2 - 12.1.2.69) <BD56A6CB-3540-359C-BD3C-C9736202C285> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
                     0x10726c000 -        0x107284fff +com.adobe.MediaUtils.framework (12.1.2 - 12.1.2.69) <FFB2D8D5-4B45-3833-AE5D-EC3F7FEAFFBF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
                     0x1072a8000 -        0x107440fff +com.adobe.ImporterHost.framework (12.1.2 - 12.1.2.69) <69FE0A9E-9B5B-3B82-9662-DA60B115E91B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
                     0x1076ca000 -        0x10771dff7 +com.adobe.AudioFilterHost.framework (12.1.2 - 12.1.2.69) <81C4C349-0F0A-3D2E-8DFC-12419277E082> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
                     0x1077aa000 -        0x1078d1ff7 +com.adobe.VideoRenderer.framework (12.1.2 - 12.1.2.69) <75A24572-0877-3454-85AD-8A0594EFCD0B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
                     0x107a57000 -        0x107b86fff +com.adobe.VideoFilterHost.framework (12.1.2 - 12.1.2.69) <7604CA03-B7FD-38DC-AD07-4E5734FA128C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
                     0x107d09000 -        0x107d21fff +com.adobe.ProjectSupport.framework (12.1.2 - 12.1.2.69) <D2E66A75-7DA9-3021-8991-58367227D7D3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
                     0x107d58000 -        0x107ea9ff7 +com.adobe.dvametadataDB.framework (12.1.2 - 12.1.2.69) <4708F30C-E326-37AE-B6EE-DA3BF602C229> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadataDB.framework/Versions/A/dvametadataDB
                     0x107ef4000 -        0x108008fff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 145 - 79.162860) <9C4D43CC-0925-3157-85D3-266A1F093831> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                     0x108167000 -        0x1081d0ff7 +com.adobe.DynamicLinkMedia.framework (12.1.2 - 12.1.2.69) <060E5F73-BF96-39F7-884F-79F5579C8C0D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/DynamicLinkMedia.framework/Versions/A/DynamicLinkMedia
                     0x1082be000 -        0x1082d2fff +com.adobe.CCLibrariesSupport.framework (12.1.2 - 12.1.2.69) <8B9F7E1C-E419-3431-A29D-8FCA6D177F2F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CCLibrariesSupport.framework/Versions/A/CCLibrariesSupport
                     0x108307000 -        0x108329ff7 +com.adobe.dvavulcansupport.framework (12.1.2 - 12.1.2.69) <535CE33D-2DC8-3972-AD5E-6CF385043CDA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvavulcansupport.framework/Versions/A/dvavulcansupport
                     0x10835f000 -        0x1083bcfff +com.adobe.csxsmanager.framework (12.1.2 - 12.1.2.69) <7544549A-7115-313A-836B-3F1BD8C0B5B0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CSXSManager.framework/Versions/A/CSXSManager
                     0x108443000 -        0x108474ff7 +com.adobe.boost-program-options.framework (12.1.2 - 12.1.2.69) <228DFA51-8A91-3A05-AC26-872AE6517D9F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_program_options.framework/Versions/A/boost_program_opt ions
                     0x1084d1000 -        0x10856bfff +com.adobe.boost-regex.framework (12.1.2 - 12.1.2.69) <411D4511-E2D7-33E6-AB96-0B00C7D34887> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                     0x1085e1000 -        0x108713fff +com.adobe.dvastorage.framework (12.1.2 - 12.1.2.69) <70DEA66D-58FF-39F6-95E3-417C78F050FE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastorage.framework/Versions/A/dvastorage
                     0x10877e000 -        0x1088defff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.7 -f 42 - 79.162860) <1F29F6FF-53E8-39A1-9B5E-0A27BBE9FDE7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                     0x108a1b000 -        0x108a37ffb +com.adobe.libzip.framework (12.1.2 - 12.1.2.69) <A0AA6A5E-AA7A-38A5-ADF7-3A54AAC02880> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libzip.framework/Versions/A/libzip
                     0x108a4f000 -        0x108f4aff7 +com.adobe.ATEWrapper.framework (12.1.2 - 12.1.2.69) <CAD2611D-B7D8-341E-B13F-4A2D87F311AA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ATEWrapper.framework/Versions/A/ATEWrapper
                     0x1094b9000 -        0x10973ffcb +com.adobe.PlugPlug (8.0.0.55 - 8.0.0.55) <B685BDFA-3EA3-3BF7-A88A-5EE5164DBCED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                     0x1099b8000 -        0x109c69ff7 +libxerces-c-3.1.dylib (0) <226354C7-81DD-3502-9CCB-500EC181627A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libxerces-c-3.1.dylib
                     0x109e19000 -        0x109ecbfff +libgit2.dylib (0) <DB34258D-83CF-3F30-ABCA-1F2FA4D52D53> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libgit2.dylib
                     0x109eef000 -        0x109fe9fff +com.adobe.adobe_caps (adobe_caps 10.0.0.5 - 10.0.0.5) <E029224F-4AD9-3054-87A7-AB5FAAD7CD1F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                     0x109ffa000 -        0x10a0b5fff +com.adobe.dvaaudiofilterhost.framework (12.1.2 - 12.1.2.69) <B68A17BE-0CD9-35FA-8D86-4AED6C0AC62C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilterhost.framework/Versions/A/dvaaudiofilterhost
                     0x10a1dc000 -        0x10a33aff7 +com.adobe.dvaaudiofilters.framework (12.1.2 - 12.1.2.69) <2090E919-55A3-36B8-8C3C-CE2CC321A444> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilters.framework/Versions/A/dvaaudiofilters
                     0x10a52d000 -        0x10a589ff7  com.apple.audio.CoreAudioKit (1.6.6 - 1.6.6) <DD6F8D1F-69EE-335A-8654-72B24E25423D> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
                     0x10a5cf000 -        0x10a60dff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
                     0x10a635000 -        0x10a761ff7  com.apple.AudioVideoBridging (503.2 - 503.2) <90DFEC17-1857-3C9E-BDFC-41AFE115296A> /System/Library/Frameworks/AudioVideoBridging.framework/Versions/A/AudioVideoBridging
                     0x10a816000 -        0x10a82ffff  libexpat.1.dylib (15.1) <588CA992-60BB-363B-BEE7-3CC0A26C1AFA> /usr/lib/libexpat.1.dylib
                     0x10a839000 -        0x10a84dff3  com.apple.AudioServerApplication (1.0 - 200.9) <4977039B-FC27-3D6E-9B3E-81B3071ADBB3> /System/Library/PrivateFrameworks/AudioServerApplication.framework/Versions/A/AudioServer Application
                     0x10a85d000 -        0x10a86cfff  com.apple.TimeSync (1.0 - 503.1) <D06817FE-7DEC-3F8C-9484-2EA4CFBC0889> /System/Library/PrivateFrameworks/TimeSync.framework/Versions/A/TimeSync
                     0x10a87e000 -        0x10a937fff +com.adobe.dvanet.framework (12.1.2 - 12.1.2.69) <FA83A194-6156-3BA8-B834-0F666F2DB153> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
                     0x10aa5a000 -        0x10b1bdfff +com.adobe.EAClient.framework (12.1.2 - 12.1.2.69) <F57BDECE-C558-370B-AB80-1BDAF7FA4B74> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAClient.framework/Versions/A/EAClient
                     0x10bbcb000 -        0x10bbeffff +VulcanControl.dylib (5.4.0.12 - 5.4.0.12 Copyright 2017, Adobe Systems Incorporated. All rights reserved.) <28EE3D33-EA55-38D6-91AA-63225B82B0A5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VulcanControl.dylib
                     0x10bc1c000 -        0x10bc57ff7 +VulcanMessage5.dylib (5.3.0.18 - 5.3.0.18 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <9E8F32A6-84F5-33EF-854C-9D0590105050> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VulcanMessage5.dylib
                     0x10bca1000 -        0x10bcb9fff +com.adobe.TeamProjectsLocalClient.framework (12.1.2 - 12.1.2.69) <674A1891-89B4-3035-94E7-82AA716912BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TeamProjectsLocalClient.framework/Versions/A/TeamProjectsLoc alClient
                     0x10bcf3000 -        0x10bdb3ff7 +com.adobe.dvaeve.framework (12.1.2 - 12.1.2.69) <9EBF04FD-F699-35CD-9080-903E763BA3A7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                     0x10bf0d000 -        0x10c000ff7 +com.adobe.dvanetsync.framework (12.1.2 - 12.1.2.69) <81666DDC-1449-36B0-9CC2-91F88EEA266C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvanetsync.framework/Versions/A/dvanetsync
                     0x10c174000 -        0x10c2e6ff7 +com.adobe.dvaworkspace.framework (12.1.2 - 12.1.2.69) <5167E87B-9BFF-3482-8ED3-D97177623CDB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                     0x10c5ee000 -        0x10c6aeff7 +com.adobe.AdobeXMPCompareAndMerge (Adobe XMP Compare And Merge 2.0 -c 7 - 79.162860) <E8B0F4F8-F9FB-3A4E-9B6F-A3C4CAB5D995> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeXMPCompareAndMerge.framework/Versions/A/AdobeXMPCompare AndMerge
                     0x10c819000 -        0x10c9e8fff +com.adobe.GPUFoundation.framework (12.1.2 - 12.1.2.69) <95B23730-940A-3BC4-B774-7BF7A28767C4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/GPUFoundation.framework/Versions/A/GPUFoundation
                     0x10cb21000 -        0x10cb34fff +com.adobe.RuntimeInstaller.framework (12.1.2 - 12.1.2.69) <56CF8516-E47B-34D7-8CA7-028B4FAA623B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RuntimeInstaller.framework/Versions/A/RuntimeInstaller
                     0x10cb53000 -        0x10cc37ff7 +com.mainconcept.mc.mfimport (10.5 - 10.5.17.5963) <C3926B1A-0AB4-37B6-9F44-39E399CD2B94> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mfimport.framework/Versions/10/mc_mfimport
                     0x10cc46000 -        0x10cdcdfff +com.adobe.atl-audio.framework (12.1.2 - 12.1.2.69) <44F6270C-417D-3B01-A05A-8AEFE2E1F2AF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/atl_audio.framework/Versions/A/atl_audio
                     0x10cdf7000 -        0x10cecdfff +com.adobe.dvaaudiodevice.framework (12.1.2 - 12.1.2.69) <A95196BF-AF0A-30B2-9186-2AF95ACA18FE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                     0x10d087000 -        0x10d15bfff +com.adobe.OpticalFlow.framework (12.1.2 - 12.1.2.69) <3D947580-654E-3718-AF85-801839184764> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OpticalFlow.framework/Versions/A/OpticalFlow
                     0x10d221000 -        0x10d22dfff +com.adobe.BravoInitializer.framework (12.1.2 - 12.1.2.69) <436469E3-B3AE-320B-B960-3EB40539BCA8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
                     0x10d24a000 -        0x10d356fff +com.adobe.ACE (AdobeACE 2.20.02.40104 - 2.20.02.40104) <4E99F32C-DF9A-30DE-ADCB-75498D2B206C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                     0x10d36f000 -        0x10d868fff +com.adobe.AGM (AdobeAGM 4.30.87.40104 - 4.30.87.40104) <D7DD88C5-47A8-3771-AA98-D3898889A554> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                     0x10d915000 -        0x10d92bfff +com.adobe.BIB (AdobeBIB 1.2.03.40104 - 1.2.03.40104) <8FB4C147-F145-3886-BBC9-66F4027EBAE5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                     0x10d934000 -        0x10dc34ff7 +com.adobe.CoolType (AdobeCoolType 5.17.00.40104.1 - 5.17.00.40104) <BD3DFF22-2E03-391E-8E1A-933AA0046204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                     0x10dc86000 -        0x10ddb0ff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/wrservices.framework/Versions/A/WRServices
                     0x10de06000 -        0x10de26ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.40104 - 1.1.40104) <3D52E2D3-C27B-314F-83B6-BCBA00F6D87D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                     0x10de2e000 -        0x10de3efff +com.adobe.ProjectConverterHost.framework (12.1.2 - 12.1.2.69) <3BA089F2-EE8C-39FF-9E0C-E7DD6D23F06B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConverterHo st
                     0x10de66000 -        0x10de87fff +com.adobe.ImmersiveVideo.framework (12.1.2 - 12.1.2.69) <36E93CA8-ECAF-352D-B139-FA538A56DD19> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ImmersiveVideo.framework/Versions/A/ImmersiveVideo
                     0x10deab000 -        0x10df17ff7 +com.adobe.DisplaySurface.framework (12.1.2 - 12.1.2.69) <C9B98269-28C9-3F52-96EA-C0AE3D9E3CAC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/DisplaySurface.framework/Versions/A/DisplaySurface
                     0x10df97000 -        0x10e350fff +com.adobe.UIFramework.framework (12.1.2 - 12.1.2.69) <868C7FBC-6E27-3059-A2A1-95247905D36B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
                     0x10eb87000 -        0x10ebacff7 +com.adobe.dvavirtualui.framework (12.1.2 - 12.1.2.69) <46C049C3-FD4D-3880-950F-7F43883330EE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvavirtualui.framework/Versions/A/dvavirtualui
                     0x10ec07000 -        0x10ec6fff7 +com.adobe.PlayerHost.framework (12.1.2 - 12.1.2.69) <2D45B21F-9E60-3F8E-94F4-0D6D99365F91> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
                     0x10ed4b000 -        0x10ee17ff7 +com.adobe.ExporterHost.framework (12.1.2 - 12.1.2.69) <8CA3E0BA-FB21-373B-95BC-B1BAF9164374> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
                     0x10ef33000 -        0x10f0c5fff +com.adobe.EncoderHost.framework (12.1.2 - 12.1.2.69) <8C6A2EBD-ED0A-3438-9C22-3F67AAF19BBE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
                     0x10f2c6000 -        0x10f331ff7 +com.adobe.RecorderHost.framework (12.1.2 - 12.1.2.69) <CEDFCFD3-8C14-3995-B21E-0D88C75DA73B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
                     0x10f42a000 -        0x10f45eff7 +com.adobe.AudioFilters.framework (12.1.2 - 12.1.2.69) <91453FBC-53DC-3B29-A566-75527CBC3A55> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
                     0x10f4d2000 -        0x10ff60fff +com.adobe.Mezzanine.framework (12.1.2 - 12.1.2.69) <15380DB2-236C-3B52-A156-BE7A11113AD0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
                     0x110b53000 -        0x110b8bff7 +com.adobe.MediaCoreUI.framework (12.1.2 - 12.1.2.69) <FC3FFAE7-F381-34B8-96A1-DB959675BA38> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
                     0x110beb000 -        0x110e4bff7 +com.adobe.SettingsUI.framework (12.1.2 - 12.1.2.69) <E52003A4-B314-3F16-AE88-BFF7941F7DBD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
                     0x1112c3000 -        0x11172cfff +com.adobe.HSL.framework (12.1.2 - 12.1.2.69) <D575B13E-1FEA-3BDB-B5B9-B853FAA8021D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
                     0x111d98000 -        0x111ddbfff +com.adobe.TransmitHost.framework (12.1.2 - 12.1.2.69) <037FEF47-EC5C-3762-BFB9-858AB74779FF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TransmitHost.framework/Versions/A/TransmitHost
                     0x111e3e000 -        0x111f03ff7 +com.adobe.exo.framework (12.1.2 - 12.1.2.69) <968342CE-E32F-3E52-811C-B7F1B9EE4B84> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/exo.framework/Versions/A/exo
                     0x1120ce000 -        0x112113ff7 +com.adobe.dynamiclinkUI.framework (12.1.2 - 12.1.2.69) <1F3F6F73-FEA2-3210-B6C6-4CAB1870B85F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dynamiclinkUI.framework/Versions/A/dynamiclinkUI
                     0x1121a8000 -        0x11223cfff +com.adobe.drawbotagm.framework (12.1.2 - 12.1.2.69) <3CC7CD7A-D378-3C33-9ED0-274F038E9E42> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/drawbotagm.framework/Versions/A/drawbotagm
                     0x1122fa000 -        0x1124eefe7 +com.adobe.CodecSupport.framework (12.1.2 - 12.1.2.69) <8FE9AE4A-B2D3-3765-9CA2-51AABA7D2CD8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CodecSupport.framework/Versions/A/CodecSupport
                     0x11269d000 -        0x112836fef +com.mainconcept.mc.dec.mp2v (10.5 - 10.5.17.5963) <6566B253-5F5D-38B7-9667-E1D62249F4BC> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/10/mc_dec_mp2v
                     0x112845000 -        0x112ad7fcf +com.mainconcept.mc.bc.dec.avc (10.5 - 10.5.17.5963) <9CF5072E-9C3F-3E48-B18A-48D8DB988539> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_bc_dec_avc.framework/Versions/10/mc_bc_dec_avc
                     0x112aee000 -        0x112cc6fe7 +com.mainconcept.mc.dec.mp4v (10.5 - 10.5.17.5963) <3D65323B-3AA2-399F-923A-3C7E670957D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_mp4v.framework/Versions/10/mc_dec_mp4v
                     0x112cd9000 -        0x114242fef +com.canon.CrmSdk (2.0.0.35 - 2.0.0.35) <975241B6-A7F7-3ED4-A5F4-65EC2B948400> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/CrmSdk.framework/Versions/A/CrmSdk
                     0x11443e000 -        0x114484fef +com.adobe.ProResOpt.framework (12.1.2 - 12.1.2.69) <93A0800B-59F1-3E14-9128-8C0547C640B2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ProResOpt.framework/Versions/A/ProResOpt
                     0x1144bb000 -        0x1144c7fff +com.adobe.QT64Utils.framework (12.1.2 - 12.1.2.69) <2FC70546-FAC0-36B3-AA2E-D6C30AD71A68> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QT64Utils.framework/Versions/A/QT64Utils
                     0x1144df000 -        0x1149c0fc7 +libDNxHR.dylib (0) <16E89552-7DB0-3ABA-87A1-C9111E71CE84> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libDNxHR.dylib
                     0x114aaf000 -        0x114c1dff7 +libSonyRawDev.dylib (3) <0DEAB123-EEB1-3567-BEB4-074484F55878> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libSonyRawDev.dylib
                     0x114cb9000 -        0x115f15fff +libArriRawSDK.dylib (0) <EB0D5F76-6989-3DAC-8560-35016D7E4D47> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libArriRawSDK.dylib
                     0x11663a000 -        0x116716fe7 +libmp4decMT.dylib (1.1.3) <A663DA9C-874F-742A-58B2-B5665D99CA03> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmp4decMT.dylib
                     0x116775000 -        0x11687ffff +libCFHDDecoder.dylib (1) <0C9B6356-F555-39E0-9054-81E3FAC4DE55> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libCFHDDecoder.dylib
                     0x116920000 -        0x116a22fff +libCFHDEncoder.dylib (1) <A3B4AE2B-D61C-339A-8DD1-B2E523640425> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libCFHDEncoder.dylib
                     0x116ad1000 -        0x116b0eff7 +libcudart.6.5.dylib (6.5.14) <D461AB76-19EE-3BDD-A579-3942130A15B0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcudart.6.5.dylib
                     0x116b1a000 -        0x116c3afef +libiomp5.dylib (0) <24D4D9F0-95F7-3930-9662-CD356D42B2C1> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libiomp5.dylib
                     0x116caa000 -        0x116cd9ff7 +libcilkrts.5.dylib (0) <04FF28DE-1EA4-3A82-ACED-7B8BD7CA100A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcilkrts.5.dylib
                     0x116cf7000 -        0x116d1cff7 +com.adobe.QTParser.framework (12.1.2 - 12.1.2.69) <451126BD-5016-3F2C-A571-CC87C87CF169> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
                     0x116d44000 -        0x116e29fdf +libProResDecoder.dylib (0) <F006F4E9-D737-3E29-949E-113035495E4B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libProResDecoder.dylib
                     0x116e6a000 -        0x116ea5fff +libcudart.dylib (0) <6E55D67C-1A95-3C2B-B2C1-C3F5827A3F03> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libcudart.dylib
                     0x116eb3000 -        0x116ed9ff7 +com.adobe.TimeCarving.framework (12.1.2 - 12.1.2.69) <EF7B833B-1611-3F22-92F5-55CDD228697E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TimeCarving.framework/Versions/A/TimeCarving
                     0x116f1d000 -        0x116f9dfff +com.adobe.MediaFinder.framework (12.1.2 - 12.1.2.69) <9656E167-BFDD-38CE-AA0F-252BA63C6BF4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MediaFinder.framework/Versions/A/MediaFinder
                     0x1170a0000 -        0x117249fff +com.adobe.SynKitLib (1.0.0.91 - 1.0.0.91) <FB3028A1-2329-311E-AB97-90CECA1870A9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
                     0x117375000 -        0x117409fff +com.adobe.sccore.framework (4.5.6 - 4.5.6.1) <ED3A028B-68A7-37D8-9127-F99AB0970B65> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/sccore.framework/Versions/A/sccore
                     0x11749e000 -        0x11753aff7 +com.adobe.extendscript.framework (4.5.6 - 4.5.6.1) <265AC5A0-FA72-3D47-99CF-9371A7582B62> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/extendscript.framework/Versions/A/extendscript
                     0x1175da000 -        0x117622ff7 +com.adobe.ahclientframework (3.0.0.7 - 3.0.0.7) <4D54E721-153B-3DE0-BC31-5B1500295EEF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                     0x11765a000 -        0x11767afff +com.adobe.AMEAppFoundation.framework (12.1.2 - 12.1.2.69) <93F41D3D-9879-3EE7-8B42-EBEBAE7EA6D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
                     0x1176cb000 -        0x1176d0fff +com.adobe.dvaundo.framework (12.1.2 - 12.1.2.69) <15A81932-504B-31EA-89C0-92BF8EA83387> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaundo.framework/Versions/A/dvaundo
                     0x1176de000 -        0x117778fff +com.adobe.essentialsound.framework (12.1.2 - 12.1.2.69) <83657D4C-A0A8-3D72-B581-1C7E858EECA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/essentialsound.framework/Versions/A/essentialsound
                     0x117882000 -        0x1178dbfff +com.adobe.FontEngine.framework (12.1.2 - 12.1.2.69) <2DB8738C-F712-3FAB-B598-1177C00F8E20> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
                     0x11796f000 -        0x117986fff +com.adobe.TitleLayer.framework (12.1.2 - 12.1.2.69) <589EF00E-F74A-398C-AC9A-5810FF6151A2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
                     0x117b23000 -        0x117b2bff7 +com.adobe.TitleImageManager.framework (12.1.2 - 12.1.2.69) <4006371A-05F0-3F0B-93CF-66B4AE75C274> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
                     0x117b3a000 -        0x117bbeff7 +com.adobe.TitleCharacterFactory.framework (12.1.2 - 12.1.2.69) <2610FFB0-AB4E-350E-8B63-689E590039D8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacterFac tory
                     0x117c42000 -        0x117d91ff7 +com.adobe.TitleCG.framework (12.1.2 - 12.1.2.69) <5B6BCB7E-DA1E-3551-93FF-118B4535FD86> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
                     0x117e9e000 -        0x1180cbfff +com.adobe.TitleLayout.framework (12.1.2 - 12.1.2.69) <8B58ECBA-468E-3BA8-8BD7-FCA86B167518> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
                     0x1185d9000 -        0x118629fff +com.adobe.TitleRenderer.framework (12.1.2 - 12.1.2.69) <0BBB073A-A497-39E3-BA4E-8E4AD308857A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TitleRenderer.framework/Versions/A/TitleRenderer
                     0x1186b9000 -        0x11870cff7 +com.adobe.dvaaudiofilterhostui.framework (12.1.2 - 12.1.2.69) <6F650B83-DF5D-3693-9D24-CB28E876D6C2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofilterhostui.framework/Versions/A/dvaaudiofilterhost ui
                     0x1187e7000 -        0x1188b7fff +com.adobe.dvametadataUI.framework (12.1.2 - 12.1.2.69) <8695151E-E481-3EF6-83D2-62A819D4D67E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                     0x118a04000 -        0x118a0eff7 +com.adobe.dvamarkerUI.framework (12.1.2 - 12.1.2.69) <20C88E1E-80B8-3B90-A141-DBE43575A58D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvamarkerUI.framework/Versions/A/dvamarkerUI
                     0x118a33000 -        0x118c45fff +com.adobe.EACodec.framework (12.1.2 - 12.1.2.69) <74428346-9289-3935-9E2C-A43C9383AF82> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EACodec.framework/Versions/A/EACodec
                     0x118d23000 -        0x118fe3ff7 +com.adobe.EAMedia.framework (12.1.2 - 12.1.2.69) <D4B5E45E-0040-3A67-B9EA-8F1D8522BC14> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAMedia.framework/Versions/A/EAMedia
                     0x119346000 -        0x119850ff7 +com.adobe.EAProjectBridge.framework (12.1.2 - 12.1.2.69) <6AFF03E3-AF61-3AE6-AB89-192F9D835371> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAProjectBridge.framework/Versions/A/EAProjectBridge
                     0x119eaf000 -        0x119ec8fff +com.adobe.dvastoryparser.framework (12.1.2 - 12.1.2.69) <BE91B646-3223-3A8A-9C4C-A46E480CF6B6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastoryparser.framework/Versions/A/dvastoryparser
                     0x119ee9000 -        0x119f11ff7 +com.adobe.dvatypekit.framework (12.1.2 - 12.1.2.69) <594817A4-3D82-3333-B5AF-DBA5AE97DDDF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvatypekit.framework/Versions/A/dvatypekit
                     0x119f50000 -        0x119ffbfff +com.diaquest.pro4.omf (1.0.0.1022 - 1.0.0.1022) <CC5C6568-78E8-3E2C-B900-2F4392A0309D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Pro4OMF.framework/Versions/A/Pro4OMF
                     0x11a027000 -        0x11a03cff7 +com.adobe.postprocess.framework (12.1.2 - 12.1.2.69) <A90C6102-223B-3B36-A5F3-60E4ACEB690A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/postprocess.framework/Versions/A/postprocess
                     0x11a06d000 -        0x11a3defe7 +com.mainconcept.mc.enc.avc (10.5 - 10.5.17.5963) <68C4B627-70A1-3451-8178-5B00CBDC4779> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_avc.framework/Versions/10/mc_enc_avc
                     0x11a517000 -        0x11a729fc7 +com.mainconcept.mc.dec.avc (10.5 - 10.5.17.5963) <ABB8EB0E-532F-3C65-84A3-3D1206FC2E89> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_dec_avc.framework/Versions/10/mc_dec_avc
                     0x11a73b000 -        0x11a9ccfff +com.mainconcept.mc.mux.mp4 (10.5 - 10.5.17.5963) <9C81FC97-3172-30C6-AB48-AB49515BA1D6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mux_mp4.framework/Versions/10/mc_mux_mp4
                     0x11a9f9000 -        0x11aa35ff7 +com.adobe.boost-serialization.framework (12.1.2 - 12.1.2.69) <006B6435-0439-3B99-8820-20EF07908B34> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/boost_serialization.framework/Versions/A/boost_serialization
                     0x11ab02000 -        0x11b04eff7 +com.adobe.TeamProjectsLocalLib.framework (12.1.2 - 12.1.2.69) <07742390-2F94-3303-B21D-D7BBF4D2C132> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TeamProjectsLocalLib.framework/Versions/A/TeamProjectsLocalL ib
                     0x11b5fe000 -        0x11bb94b27 +adobe.cloudservices.liveedit.LiveEditClient (1.0 - 1) <9A981AA5-734D-3591-A029-96B2DAF10888> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LiveEditClient.framework/Versions/A/LiveEditClient
                     0x11bfb1000 -        0x11c485ff7 +com.adobe.Dialogs.framework (12.1.2 - 12.1.2.69) <C436E904-AE02-38C3-8EA8-14B552E64C0C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Dialogs.framework/Versions/A/Dialogs
                     0x11ca55000 -        0x11cb0cff7 +com.adobe.PProDynamicLinkServer.framework (12.1.2 - 12.1.2.69) <6CBD4908-B736-3D35-A4AA-FBF6C989DB70> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PProDynamicLinkServer.framework/Versions/A/PProDynamicLinkSe rver
                     0x11ccd0000 -        0x11ce79fff +com.adobe.EAPrBridge.framework (12.1.2 - 12.1.2.69) <C80D2C85-95AB-3D4B-BBAB-F5A8F9B6B50E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/EAPrBridge.framework/Versions/A/EAPrBridge
                     0x11d10b000 -        0x11d122ff7 +com.adobe.dvacaptioningui.framework (12.1.2 - 12.1.2.69) <684F757A-CE8A-376B-A88F-1E3F1E4E4607> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacaptioningui.framework/Versions/A/dvacaptioningui
                     0x11d14a000 -        0x11d326ff7 +com.adobe.RendererGPU.framework (12.1.2 - 12.1.2.69) <9E5C7BA8-3A0E-3A78-B69E-D3CE87494016> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RendererGPU.framework/Versions/A/RendererGPU
                     0x11d468000 -        0x11d63dff7 +com.adobe.IngestCore.framework (12.1.2 - 12.1.2.69) <0B61D9D8-35A2-36AD-8DAF-6EF0342ACE1A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestCore.framework/Versions/A/IngestCore
                     0x11d972000 -        0x11da36fff +com.adobe.IngestDialog.framework (12.1.2 - 12.1.2.69) <0696C3F1-A7ED-3FE8-AE93-334B0EFF4F9F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestDialog.framework/Versions/A/IngestDialog
                     0x11dbef000 -        0x11dc1eff7 +com.adobe.dvacontrolsurfacehost.framework (12.1.2 - 12.1.2.69) <2E26F17D-512F-3D0C-B47E-15A436C04DA3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvacontrolsurfacehost.framework/Versions/A/dvacontrolsurface host
                     0x11dca8000 -        0x11dcdbfff +com.adobe.dvaaudiodeviceui.framework (12.1.2 - 12.1.2.69) <8D705EA9-5C4A-37BB-B534-1B1C0CD1CF49> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiodeviceui.framework/Versions/A/dvaaudiodeviceui
                     0x11dd36000 -        0x11dd67fff +com.adobe.Registration.framework (12.1.2 - 12.1.2.69) <98218561-A270-3828-91E0-96E44F38184A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Registration.framework/Versions/A/Registration
                     0x11dda0000 -        0x11ddb5ff7 +com.adobe.OnBoardingBase.framework (12.1.2 - 12.1.2.69) <F9007BB0-1CF9-32B1-BD5E-229B213F4C2C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OnBoardingBase.framework/Versions/A/OnBoardingBase
                     0x11ddef000 -        0x11df3dfff +com.adobe.MobileAppLayer.framework (12.1.2 - 12.1.2.69) <3160CBBA-F49F-3DEE-A586-D496564AA3E5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MobileAppLayer.framework/Versions/A/MobileAppLayer
                     0x11e274000 -        0x11e3c0fff +com.adobe.ScriptLayerPPro.framework (12.1.2 - 12.1.2.69) <85CED389-8750-39BE-893A-0F6DC25BDA06> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayerPPro.framework/Versions/A/ScriptLayerPPro
                     0x11e5ba000 -        0x11e993ff7 +com.adobe.ScriptLayerPProQE.framework (12.1.2 - 12.1.2.69) <E60D0D25-8AC8-3ADE-AEC1-7B6BB2C548E7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayerPProQE.framework/Versions/A/ScriptLayerPProQE
                     0x11f376000 -        0x11f3afff7 +com.adobe.HandlerAudioMiniMixer.framework (12.1.2 - 12.1.2.69) <7570454C-7BDA-3A5D-B00A-4CCB27DC676C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioMiniMixer.framework/Versions/A/HandlerAudioMiniM ixer
                     0x11f422000 -        0x11f4ddff7 +com.adobe.HandlerColor.framework (12.1.2 - 12.1.2.69) <C4E933D5-5F56-3A76-9C7C-1C00A328C92D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerColor.framework/Versions/A/HandlerColor
                     0x11f609000 -        0x11f635ff7 +com.adobe.HandlerCSXS.framework (12.1.2 - 12.1.2.69) <2F0CCDDA-3650-3ADA-A8CA-25FA87B4E122> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCSXS.framework/Versions/A/HandlerCSXS
                     0x11f6b2000 -        0x11f8ccff7 +com.adobe.HandlerEffectControls.framework (12.1.2 - 12.1.2.69) <4A4AB44C-0EAD-3496-9359-3478834CD518> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffectCont rols
                     0x11fb71000 -        0x11fbb5ff7 +com.adobe.HandlerMediaBrowser.framework (12.1.2 - 12.1.2.69) <9B16483B-6AB3-3E24-96A2-F7F925DC4619> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMediaBrowser.framework/Versions/A/HandlerMediaBrowser
                     0x11fc6d000 -        0x11fdd1fff +com.adobe.HandlerProgramMonitor.framework (12.1.2 - 12.1.2.69) <7AC73AB3-D2FA-360B-A19A-1CF5042AF0B8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProgramMonitor.framework/Versions/A/HandlerProgramMon itor
                     0x11ffea000 -        0x1202beff7 +com.adobe.HandlerProject.framework (12.1.2 - 12.1.2.69) <DF846AD2-04FF-3F47-BAAF-646651AA1689> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
                     0x12072e000 -        0x120a56ff7 +com.adobe.HandlerTimeline.framework (12.1.2 - 12.1.2.69) <66195A9B-954E-3616-9967-0FF5202AF7F6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
                     0x120e26000 -        0x120e7cff7 +com.adobe.HandlerTools.framework (12.1.2 - 12.1.2.69) <F8E6F606-EAAA-3D64-B2FE-39827AAD02BB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTools.framework/Versions/A/HandlerTools
                     0x120fa6000 -        0x12115dff7 +com.adobe.HandlerTitler.framework (12.1.2 - 12.1.2.69) <1863F354-F666-3565-8873-1EC5CA65EFA0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTitler.framework/Versions/A/HandlerTitler
                     0x1214b0000 -        0x12150afff +com.adobe.HandlerAudioClipMixer.framework (12.1.2 - 12.1.2.69) <16776F6C-A52E-347E-8451-2D3BDA5167B2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioClipMixer.framework/Versions/A/HandlerAudioClipM ixer
                     0x1215c7000 -        0x121667ff7 +com.adobe.HandlerAudioMixer.framework (12.1.2 - 12.1.2.69) <E3D2B286-E9D9-35CC-9400-2FC60570FB90> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
                     0x121774000 -        0x1217c8fff +com.adobe.HandlerCaptions.framework (12.1.2 - 12.1.2.69) <253CB6E4-EE41-313A-B033-E84192E8B59F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCaptions.framework/Versions/A/HandlerCaptions
                     0x121866000 -        0x1218eafff +com.adobe.HandlerCapture.framework (12.1.2 - 12.1.2.69) <6C3FB66F-018E-3434-9302-FE9AF70B35A3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
                     0x1219f5000 -        0x121a3dff7 +com.adobe.HandlerEditToTape.framework (12.1.2 - 12.1.2.69) <C826C51D-D1B3-3955-A070-5A1383EBD9D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEditToTape.framework/Versions/A/HandlerEditToTape
                     0x121ae5000 -        0x121b53fff +com.adobe.HandlerEffects.framework (12.1.2 - 12.1.2.69) <8D6F4079-4A81-3AB8-B2C4-D0F6C9AEBDEE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEffects.framework/Versions/A/HandlerEffects
                     0x121c1a000 -        0x121c33ff7 +com.adobe.HandlerEssentialSound.framework (12.1.2 - 12.1.2.69) <AD99F017-8C49-33B4-B78F-AD693FCB2ADE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEssentialSound.framework/Versions/A/HandlerEssentialS ound
                     0x121c81000 -        0x121ca0ff7 +com.adobe.HandlerEvents.framework (12.1.2 - 12.1.2.69) <27D4B764-ACE7-394F-8B42-021CA925919F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
                     0x121cf4000 -        0x121d08ff7 +com.adobe.HandlerGetProperties.framework (12.1.2 - 12.1.2.69) <F6583899-3713-3A40-86C3-65EEE84AFCD2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProperti es
                     0x121d3f000 -        0x121ec7ff7 +com.adobe.HandlerGraphics.framework (12.1.2 - 12.1.2.69) <D8932F8B-8420-35FD-A5CA-09C9D6BEB1C9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerGraphics.framework/Versions/A/HandlerGraphics
                     0x122142000 -        0x122159ff7 +com.adobe.HandlerHistory.framework (12.1.2 - 12.1.2.69) <90FDBC3E-6DA7-31EE-9E4B-84A436F11B93> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
                     0x122196000 -        0x1221b7fff +com.adobe.HandlerInfo.framework (12.1.2 - 12.1.2.69) <D38E5CE9-4073-3F84-ACA2-A891A10C7AEF> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
                     0x122204000 -        0x122248ff7 +com.adobe.HandlerMarkerList.framework (12.1.2 - 12.1.2.69) <16F37EC8-0C68-3DBC-9125-288FEFCE9EF4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMarkerList.framework/Versions/A/HandlerMarkerList
                     0x1222ee000 -        0x12233ffff +com.adobe.HandlerMetadataEditor.framework (12.1.2 - 12.1.2.69) <0B0E30F2-E36A-3FBD-9D31-14B8D2A20369> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerMetadataEditor.framework/Versions/A/HandlerMetadataEd itor
                     0x1223f8000 -        0x1223fcfff +com.adobe.HandlerProgress.framework (12.1.2 - 12.1.2.69) <9ADC2841-083C-3DCA-BB34-565949086C2C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerProgress.framework/Versions/A/HandlerProgress
                     0x12240f000 -        0x12241fff7 +com.adobe.HandlerScopes.framework (12.1.2 - 12.1.2.69) <E40CD507-7749-3D75-9585-4803E5EED496> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerScopes.framework/Versions/A/HandlerScopes
                     0x122447000 -        0x1225d1ff7 +com.adobe.HandlerSourceMonitor.framework (12.1.2 - 12.1.2.69) <9AC7779E-369C-3AF6-A256-667AC8F2ADBD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerSourceMonitor.framework/Versions/A/HandlerSourceMonit or
                     0x12279c000 -        0x1227a5ff7 +com.adobe.HandlerStoryPanel.framework (12.1.2 - 12.1.2.69) <5A6FBEB5-467E-3253-BEDC-36C8B3BF1207> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerStoryPanel.framework/Versions/A/HandlerStoryPanel
                     0x1227c5000 -        0x1227f1ff7 +com.adobe.HandlerTimecode.framework (12.1.2 - 12.1.2.69) <110975EB-9974-3598-AF65-39F0449B2F3F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/HandlerTimecode.framework/Versions/A/HandlerTimecode
                     0x122856000 -        0x122b71fff +com.adobe.dvaadameve.framework (12.1.2 - 12.1.2.69) <D839908C-CEB6-3152-AF34-F930AF4F891D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
                     0x1231ff000 -        0x1233a5fff +com.adobe.dvaaudiofiltersui.framework (12.1.2 - 12.1.2.69) <734266EF-9DA3-34C2-BB10-1ABDA9103CFA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaaudiofiltersui.framework/Versions/A/dvaaudiofiltersui
                     0x1236e5000 -        0x123766fff +com.adobe.ControlSurface.framework (12.1.2 - 12.1.2.69) <EBD39BF2-2EB4-32CD-8CD9-F747A6BD13D0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ControlSurface.framework/Versions/A/ControlSurface
                     0x123810000 -        0x123830ff7 +com.adobe.OnBoarding.framework (12.1.2 - 12.1.2.69) <4B808FC0-40EE-3DD7-AECE-6936F46C5568> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OnBoarding.framework/Versions/A/OnBoarding
                     0x12388a000 -        0x1239f8ff7 +com.adobe.Batch.framework (12.1.2 - 12.1.2.69) <AF7F59B9-2E08-374C-8599-A40538A29BE8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/Batch.framework/Versions/A/Batch
                     0x123cda000 -        0x123cf5ff7 +com.adobe.IngestGlue.framework (12.1.2 - 12.1.2.69) <A0A8EB59-2206-3F2E-A0E7-EB43B41314FA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IngestGlue.framework/Versions/A/IngestGlue
                     0x123d3a000 -        0x123edcfff +com.adobe.headlights.LogSessionFramework (7.4.1.112.46866) <F8E6A446-3724-3F70-A396-E1A01325FE0A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                     0x124078000 -        0x124176ff3 +ZXPSignLib-minimal-dylib.dylib (0) <B50C7884-6179-3925-AF15-0013257D0F6B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ZXPSignLib-minimal-dylib.dylib
                     0x1241a4000 -        0x124248fff +com.adobe.dvascriptingES.framework (12.1.2 - 12.1.2.69) <3483CB3E-1DC2-3486-961F-8520D8A3FB28> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvascriptingES.framework/Versions/A/dvascriptingES
                     0x124340000 -        0x124384ff7 +com.adobe.dvastorypanel.framework (12.1.2 - 12.1.2.69) <8C9C700C-1C8B-3700-B30A-929AB6303AFD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvastorypanel.framework/Versions/A/dvastorypanel
                     0x12441f000 -        0x1244abff7 +com.adobe.essentialsoundui.framework (12.1.2 - 12.1.2.69) <AB7B2F5C-D98B-36FD-8CAA-50D896B60C04> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/essentialsoundui.framework/Versions/A/essentialsoundui
                     0x1245dd000 -        0x124651ff7 +com.adobe.ScriptLayer.framework (12.1.2 - 12.1.2.69) <408C5B51-D263-3A41-82D3-7F00E0FD95CB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLayer
                     0x124fc1000 -        0x124febfff  GLRendererFloat (14.0.16) <32A016EE-63CF-3D07-9BAB-C4EB3E8E479D> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                     0x124ff5000 -        0x124ff7ffb  com.apple.textencoding.unicode (3.0 - 3.0) <450E3370-B9E4-3179-89E5-98858FD25F23> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                     0x1295d7000 -        0x12977dfff  GLEngine (14.0.16) <E8C60E20-6414-32B2-8964-41882943D9C1> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                     0x12a800000 -        0x12b254ff7  com.apple.driver.AppleIntelKBLGraphicsGLDriver (10.25.17 - 10.2.5) <EFBF3628-9022-3843-9499-0ADE8FC2C9C8> /System/Library/Extensions/AppleIntelKBLGraphicsGLDriver.bundle/Contents/MacOS/AppleIntel KBLGraphicsGLDriver
                     0x12b780000 -        0x12b781fff +com.adobe.TransmitDesktopAudio.framework (12.1.2 - 12.1.2.69) <DC555A97-F712-317D-9758-29CBCF49B940> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitDesktopAudio.bundle/Contents/MacOS/TransmitDesk topAudio
                     0x12c4a9000 -        0x12c4bbff3  libTraditionalChineseConverter.dylib (70) <EA69A689-C005-3636-B647-A20DE3715E2D> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                     0x12c4c4000 -        0x12c4e0ffb  libJapaneseConverter.dylib (70) <F96283F0-C366-30FE-853E-9C5C0F44FE14> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                     0x12c4e6000 -        0x12c4f5ffb  libSimplifiedChineseConverter.dylib (70) <9DF419B1-9049-3FB1-B6BB-85267B8E3B06> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                     0x12fcc4000 -        0x12fcc8fff  libFontRegistryUI.dylib (196.4) <4EEE5715-A024-3A4B-BF0E-D55325B8E129> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Resourc es/libFontRegistryUI.dylib
                     0x12fcd1000 -        0x12fcf7fef +com.mainconcept.mc.enc.dv (10.5 - 10.5.17.5963) <C8D63373-D045-39AA-B486-72076413C2A5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
                     0x12fd0c000 -        0x12fd10fff  com.apple.audio.AppleHDAHALPlugIn (279.48 - 279.48) <ECA84145-2AC4-347D-BBC0-933AAAC15356> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                     0x12fed0000 -        0x12fef2fff  libKoreanConverter.dylib (70) <6C272E7B-5507-3B42-A885-500FED07DDE4> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                     0x1306c1000 -        0x1306c7ff7 +com.mainconcept.mc.enc.mp2sr (10.5 - 10.5.17.5963) <8339AD25-167D-3BFE-A37A-D914F6A10B32> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp2sr.framework/Versions/10/mc_enc_mp2sr
                     0x130900000 -        0x13098efff  com.apple.driver.AppleIntelKBLGraphicsMTLDriver (10.25.17 - 10.2.5) <1DABF9B1-3110-31CC-A50B-1351183E4AF3> /System/Library/Extensions/AppleIntelKBLGraphicsMTLDriver.bundle/Contents/MacOS/AppleInte lKBLGraphicsMTLDriver
                     0x135e40000 -        0x136063fe7 +REDR3D.dylib (0) <3F88935C-39CB-3D8F-AA68-478BEF1CC694> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDR3D.dylib
                     0x137344000 -        0x13741afff +REDCuda.dylib (0) <DC0FCD27-04BD-319F-A701-7369107E056E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDCuda.dylib
                     0x138a1e000 -        0x138c0fff7 +REDOpenCL.dylib (0) <D54DBEDF-8CEB-3FFF-9C86-D92670D10D66> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/REDOpenCL.dylib
                     0x138d18000 -        0x138d1aff7 +T.dylib (0) <291DE13A-BFAF-37FF-A00C-B493F87B2817> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/T.dylib
                     0x139d80000 -        0x139daaff7 +com.adobe.EASequenceRenderer.framework (12.1.2 - 12.1.2.69) <BA94E812-51CE-3D7C-8936-F88F0E00EAD3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/EASequenceRenderer.bundle/Contents/MacOS/EASequenceRend erer
                     0x13a1e4000 -        0x13a260ff7 +com.adobe.ExporterMPEG2.framework (12.1.2 - 12.1.2.69) <9C5C4423-F378-30C1-AB6B-A714BAFBD550> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEG2.bundle/Contents/MacOS/ExporterMPEG2
                     0x13a2e6000 -        0x13a2f5fff +com.mainconcept.mc.enc.mpa (10.5 - 10.5.17.5963) <8011D934-1E46-3917-A050-F1BD6C7DB12A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mpa.framework/Versions/10/mc_enc_mpa
                     0x13a325000 -        0x13a515fe7 +com.mainconcept.mc.enc.mp2v (10.5 - 10.5.17.5963) <111832A9-C088-350C-8096-0EDF0BEA00D5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp2v.framework/Versions/10/mc_enc_mp2v
                     0x13a589000 -        0x13a691ff7 +com.mainconcept.mc.mux.mp2 (10.5 - 10.5.17.5963) <FA2E5FB7-A906-38AC-A19D-16D3B5B031E2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_mux_mp2.framework/Versions/10/mc_mux_mp2
                     0x13a999000 -        0x13aae5fe7 +com.adobe.ExporterMPEG4.framework (12.1.2 - 12.1.2.69) <85D17E66-6CD9-3C84-A9B3-FDF3AA8DF0C4> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEG4.bundle/Contents/MacOS/ExporterMPEG4
                     0x13ac05000 -        0x13add3fff +com.mainconcept.mc.enc.mp4v (10.5 - 10.5.17.5963) <6DC87BB2-C6B8-3606-B594-4A456FD44149> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_mp4v.framework/Versions/10/mc_enc_mp4v
                     0x13ae47000 -        0x13b1c0fff +com.mainconcept.mc.bc.enc.avc (10.5 - 10.5.17.5963) <16AA44F7-D279-35D8-AD8D-7D48BFB06E65> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_bc_enc_avc.framework/Versions/10/mc_bc_enc_avc
                     0x13b31a000 -        0x13b3c0fef +com.adobe.IPPMPEGDecoder.framework (12.1.2 - 12.1.2.69) <FB14E648-0856-368C-A42B-E0138F91A643> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
                     0x13b780000 -        0x13b8b6ff7 +com.adobe.ExporterMXF.framework (12.1.2 - 12.1.2.69) <AF061E97-35D2-3ACB-85A1-F3233147E223> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMXF.bundle/Contents/MacOS/ExporterMXF
                     0x13b9f5000 -        0x13ba1fff7 +libMOG_Framework.5.0.14.dylib (0) <4D5416B3-194E-30A2-B35B-7F500E754E1B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMOG_Framework.5.0.14.dylib
                     0x13ba9d000 -        0x13c227fff +libMXF_SDK.5.0.14.dylib (0) <29E0F2C6-A091-3C82-9962-A0DB3071FC4E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/MOG/Frameworks/libMXF_SDK.5.0.14.dylib
                     0x13d47d000 -        0x13d527fff +com.adobe.ExporterXDCAMHD.framework (12.1.2 - 12.1.2.69) <89CE6B00-959C-3315-866A-D15E348BCC18> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterXDCAMHD.bundle/Contents/MacOS/ExporterXDCAMHD
                     0x13d5cf000 -        0x13d5d9fff +com.mainconcept.mc.enc.avcsr (10.5 - 10.5.17.5963) <1727D243-B2DD-3047-B68A-98BCA1A00A7E> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_avcsr.framework/Versions/10/mc_enc_avcsr
                     0x13d5df000 -        0x13d5f7fff +com.adobe.ImporterAVFoundation.framework (12.1.2 - 12.1.2.69) <A24E42DF-FAAA-31A2-9AD7-24741C960F80> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterAVFoundation.bundle/Contents/MacOS/ImporterAVFo undation
                     0x13d618000 -        0x13d648ff7 +com.adobe.PlatformAudioCodecs.framework (12.1.2 - 12.1.2.69) <D09914DB-85F8-30E1-B618-9ED666CEAD6C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PlatformAudioCodecs.framework/Versions/A/PlatformAudioCodecs
                     0x13d67a000 -        0x13d769fff +com.mainconcept.mc.demux.mp2 (10.5 - 10.5.17.0258) <C86FD5AF-C224-31B6-B073-023A5217E3F9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_demux_mp2.framework/Versions/10/mc_demux_mp2
                     0x13d77b000 -        0x13d78eff7 +com.adobe.ImporterDataStream.framework (12.1.2 - 12.1.2.69) <E78A8666-3F9A-3169-9239-F93497100971> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterDataStream.bundle/Contents/MacOS/ImporterDataSt ream
                     0x13d7b4000 -        0x13d855fff +com.adobe.AdobeSensorManager (Adobe Sensor Manager 2.0 -s 018 - 79.162672) <E5812E75-AF80-3066-B077-2A74FCF23C5A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeSensorManager.framework/Versions/A/AdobeSensorManager
                     0x13d8fd000 -        0x13d980ff7 +com.adobe.ImporterRED.framework (12.1.2 - 12.1.2.69) <1CEDD72E-20C3-31B1-A2E6-A216D01CC5E6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ImporterRED.bundle/Contents/MacOS/ImporterRED
                     0x13da13000 -        0x13dbe3fe7 +com.adobe.PremierePro.OpenEXR (1.0 - 1.0) <5923A225-A8ED-05D1-CA50-B4A7EFA35DF0> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/OpenEXR Premiere.bundle/Contents/MacOS/OpenEXR Premiere
                     0x13ddb3000 -        0x13ddc1ff7 +com.adobe.PremiereFiltersMetaPlugin.framework (12.1.2 - 12.1.2.69) <FA8AE1CB-9997-36C8-8AAC-F11CBE825C94> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/PremiereF iltersMetaPlugin
                     0x13ddd3000 -        0x13dde2ff7 +com.adobe.TransitionsMetaPlugin.framework (12.1.2 - 12.1.2.69) <AF8E096B-A87A-3F44-868E-4B7533602178> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/TransitionsMe taPlugin
                     0x13ddf5000 -        0x13e24afff +quvis.wraptor (1.0 - 1) <540DAE90-F54B-3780-861A-D694BFB06310> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/wraptor.bundle/Contents/MacOS/wraptor
                     0x13e70d000 -        0x13e71fff7 +com.adobe.TransmitDV.framework (12.1.2 - 12.1.2.69) <F888C04F-C05B-3901-AF92-100FB4FBC18D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitDV.bundle/Contents/MacOS/TransmitDV
                     0x13e73d000 -        0x13e767ff7  com.apple.AVCVideoServices (1.0 - 42) <FEAE1854-5F7E-3B3E-B6EA-BD825B3CB467> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
                     0x13e7a2000 -        0x13e7a9ff7 +com.adobe.TransmitFullScreen.framework (12.1.2 - 12.1.2.69) <B81D958C-5209-3296-95BA-377CCFD5A52B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitFullScreen.bundle/Contents/MacOS/TransmitFullSc reen
                     0x13e7b8000 -        0x13e814fff +com.adobe.PlayerMediaCore.framework (12.1.2 - 12.1.2.69) <A50C7094-8BB4-3254-9D8B-ECD64499B48B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCore
                     0x13e87e000 -        0x13e8b1fff +com.adobe.RendererCPU.framework (12.1.2 - 12.1.2.69) <D6F9D3C4-B510-36D9-B730-DEA05C755E47> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RendererCPU.framework/Versions/A/RendererCPU
                     0x13e8f2000 -        0x13eacafff +com.adobe.TransmitScopes.framework (12.1.2 - 12.1.2.69) <C390FFD2-1720-35AF-9413-83110826D152> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitScopes.bundle/Contents/MacOS/TransmitScopes
                     0x1402ef000 -        0x140372fff +com.adobe.TransmitVR.framework (12.1.2 - 12.1.2.69) <EBAE97DE-9EAC-3484-BD5E-7F2D7419B9CD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/TransmitVR.bundle/Contents/MacOS/TransmitVR
                     0x140412000 -        0x140461fff +com.adobe.ExporterQuickTimeHost.framework (12.1.2 - 12.1.2.69) <5A393D08-B475-384B-979C-879E85E127DB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/ExporterQui ckTimeHost
                     0x1404a3000 -        0x1404bbff7 +com.adobe.QTWriter.framework (12.1.2 - 12.1.2.69) <31B98252-B41F-35AE-86F6-D9BB27EFA16D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/QTWriter.framework/Versions/A/QTWriter
                     0x14060c000 -        0x14064bfff +com.adobe.ExporterMPEGPreview.framework (12.1.2 - 12.1.2.69) <96227B34-145C-359F-9382-2C9E5B69918B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Plug-Ins/Common/ExporterMPEGPreview.bundle/Contents/MacOS/ExporterMPEGP review
                     0x140682000 -        0x1406bbff7 +com.mainconcept.mc.enc.aac (10.5 - 10.5.17.5963) <D4FB82FE-A372-38EA-B45F-5ACC4A72A273> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/mc_enc_aac.framework/Versions/10/mc_enc_aac
                     0x14103f000 -        0x1410acfff +com.adobe.ICUData (4.0 - 3.61) <604A18BB-29F6-34EC-98D4-3CC65EA9298C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
                     0x1410c1000 -        0x1411a6fff +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.39392 - 3.8.0.39392) <B14D700D-5B31-353D-947A-CCE76A2CF281> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                     0x141258000 -        0x141270fff +M.dylib (0) <BA9E08E4-7A64-32C8-901E-7834B7B2C32B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/M.dylib
                     0x141284000 -        0x141287ff3 +VAL.dylib (0) <E6CCE008-C8CE-39B6-B4C9-D0B25ADA3EE2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/VAL.dylib
                     0x141298000 -        0x141365ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.39530) <5C13ACD4-BD1F-3DF5-B8A7-B388E27D7660> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                     0x1413ad000 -        0x1413deff7 +com.adobe.ARE (AdobeARE 1.5.02.40104 - 1.5.02.40104) <C6C3440E-3FD8-36A9-9D5E-90E999486EE6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                     0x1413ef000 -        0x14174ffff +com.adobe.MPS (AdobeMPS 5.8.1.40104 - 5.8.1.40104) <02FC8477-213B-310D-8330-A648E85BE77C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                     0x1419e2000 -        0x1421acfff +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 15.0.0.40112) <4EB2970C-AC64-3E1B-B67A-4B7B23581025> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobePDFL.framework/Versions/A/AdobePDFL
                     0x14288f000 -        0x1428b4fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.39392 - 3.8.0.39392) <FC4F241D-05A6-36E1-8CFE-8FDC58F2AB2B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
                     0x1428e1000 -        0x142907fff +com.adobe.AXE16SharedExpat (AdobeAXE16SharedExpat 3.8.0.39392 - 3.8.0.39392) <A2837D5A-14F4-3A5C-BD33-2DFA5039CF99> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobeAXE16SharedExpat.framework/Versions/A/AdobeAXE16SharedE xpat
                     0x142af4000 -        0x142b96ff7 +com.adobe.ICUConverter (4.0 - 3.61) <4D6A813A-56D5-3CE1-8743-2BA65500FD20> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
                     0x142bc1000 -        0x142bc8fff +LIST.dylib (0) <D20BF7AA-F2BF-3AFD-B47A-BFCBBB8D1376> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/LIST.dylib
                     0x142bd9000 -        0x142be6fff +BEZ.dylib (0) <D365A64F-DA8F-3582-8D7F-F7487986C909> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BEZ.dylib
                     0x142bf1000 -        0x142bf5fff +BM.dylib (0) <8F54C751-9641-305B-AD33-838C90FEF4AD> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BM.dylib
                     0x142fac000 -        0x143030fff +U.dylib (0) <43C3CC11-0C31-32B3-BF12-375624B4BCC6> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/U.dylib
                     0x1431eb000 -        0x1432d7ff7 +MEE.dylib (0) <83D216FE-DD20-38FC-BCFE-218287BB4559> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MEE.dylib
                     0x1433d0000 -        0x143427ff7 +display.dylib (0) <23CB95FF-9595-3DC1-81D1-97C343EB4E1C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/display.dylib
                     0x143475000 -        0x143495fff +FILE.dylib (0) <0995DABB-6017-3BB9-A9D3-D28ACE7BC3FA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FILE.dylib
                     0x1434cb000 -        0x143510fff +SLU.dylib (0) <30AD4361-3AF8-3F0B-8F3B-9534F6AEDEAA> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SLU.dylib
                     0x14359f000 -        0x1435b7fff +PREF.dylib (0) <C6F46919-5B11-35E8-9D31-7B058C54ACA1> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PREF.dylib
                     0x1435d9000 -        0x14360bff7 +MC.dylib (0) <8745408B-9DCB-3DC2-B648-33E43349ED36> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MC.dylib
                     0x14365c000 -        0x14366dfff +PLUG.dylib (0) <73416E55-A2C3-398D-AF2F-BCF809F5209F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PLUG.dylib
                     0x143686000 -        0x1436bbff7 +COR.dylib (0) <2DA5CF16-8294-3FCB-B452-33B436060C1B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/COR.dylib
                     0x143716000 -        0x1439ecff7 +PF.dylib (0) <718ACB33-4985-3756-95E1-6CECFCDE9458> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PF.dylib
                     0x143b67000 -        0x144044fff +TXT.dylib (0) <565FC3ED-E9E3-38D4-BD34-4769C298410C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TXT.dylib
                     0x14461b000 -        0x14466bff7 +TDL.dylib (0) <9EB1F420-1D58-35F5-9A88-D2412C19CE27> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TDL.dylib
                     0x1446ab000 -        0x1446f9ff7 +TDB.dylib (0) <AE1B295A-3190-34BA-8C60-3EBE8859AC23> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/TDB.dylib
                     0x144766000 -        0x1447a1ff7 +OM.dylib (0) <1FD80A95-3F36-3B83-8E75-E480794E78C2> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/OM.dylib
                     0x1447df000 -        0x144804fff +P.dylib (0) <CBFB6FB1-CD61-37EB-8402-575D62FB394B> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/P.dylib
                     0x14481e000 -        0x144847fff +PREM.dylib (0) <1C98433E-50AA-3690-B57B-0B284C119A0D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PREM.dylib
                     0x144899000 -        0x1448e8fff +SND.dylib (0) <E9C7F81E-F718-38EF-A89F-4AA5B5B7302A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SND.dylib
                     0x144966000 -        0x144995fff +RG.dylib (0) <83F4B8FF-28C3-3F37-B478-08C66EDC09F5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/RG.dylib
                     0x1449d7000 -        0x144a2bff7 +MSK.dylib (0) <1A21A0F7-CD8A-326C-A3CA-2E08FED05C3D> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/MSK.dylib
                     0x144a7e000 -        0x144a96fff +PR.dylib (0) <004CB06D-C1BE-3159-B6CC-A985D57FC92C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PR.dylib
                     0x144acb000 -        0x144ad2fff +SAM.dylib (0) <FDF6A8ED-6054-3E8F-B0AC-199D0F63A598> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SAM.dylib
                     0x14aa0e000 -        0x14ac63fff +PIN.dylib (0) <AEB340E2-1C60-3853-8702-9B1247AB3795> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/PIN.dylib
                     0x14aec2000 -        0x14af69ff7 +FLT.dylib (0) <1EADE55E-4FB0-3F22-B848-4BBAB0B34204> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FLT.dylib
                     0x14b0a9000 -        0x14b162fff +FRP.dylib (0) <37F400AB-08B8-3868-8841-FB0CE30935B5> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FRP.dylib
                     0x14b256000 -        0x14b278fff +SegMatServices.dylib (0) <1DB59F6A-8061-3E11-9D08-7997652F766F> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/SegMatServices.dylib
                     0x14b2c2000 -        0x14ba27ff7 +BEE.dylib (0) <E32F7614-52EB-3EEF-AACF-BCF02D5AD109> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/BEE.dylib
                     0x14c6a7000 -        0x14c6f0ff7 +FLO.dylib (0) <4D52795F-3A52-39E4-8CCA-DB1DE1D1A4A3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/FLO.dylib
                     0x14c712000 -        0x14c74cfef +libtbb.dylib (0) <10144FAB-48B9-34ED-833B-A3F7E65BC4ED> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libtbb.dylib
                     0x14c78f000 -        0x14c7b3fff +libtbbmalloc.dylib (0) <4AED21B6-C175-31A4-BA52-70A811C1B0F8> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libtbbmalloc.dylib
                     0x14c7eb000 -        0x14c9fdfcf +com.adobe.AIDE (1.5.0 - 1.5.0.40084) <F51445AC-916B-3012-8872-9E633C7AF505> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
                     0x14ca2d000 -        0x14cae8fff +com.adobe.dvaplayer.framework (12.1.2 - 12.1.2.69) <4DE4839D-0EC6-3C20-947C-3BACF0B5CB1C> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                     0x14cc72000 -        0x14cc83ff7 +com.adobe.GPUKernels.framework (12.1.2 - 12.1.2.69) <2BAAC10B-71D2-35A3-9E91-E163A5D2EE88> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/GPUKernels.framework/Versions/A/GPUKernels
                     0x14cc92000 -        0x14cca9ff7 +com.adobe.eaurl.framework (12.1.2 - 12.1.2.69) <317BA78E-888B-3312-AA15-77E2E787720A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/eaurl.framework/Versions/A/eaurl
                     0x14ccd6000 -        0x150856fdf +com.adobe.psl (AdobePSL 15.1.0.38776 - 15.1.0.38776) <22036635-21E0-35A5-8103-CCD034766DE3> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                     0x150d4e000 -        0x150e3fff7 +com.adobe.ICUUnicode (4.0 - 3.61) <431F0368-6F63-3B0D-A215-D6866EEACA9A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
                     0x150e8c000 -        0x151d32fe7 +libmkl_intel_lp64.dylib (0) <3A603969-1A39-3CAB-8CED-1350DFA6DFC7> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_intel_lp64.dylib
                     0x151f0a000 -        0x153836fff +libmkl_intel_thread.dylib (0) <B03E1F34-4E4E-3FBE-A9DE-14D37A5E440A> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_intel_thread.dylib
                     0x153eac000 -        0x1555d0f4f +libmkl_core.dylib (0) <ED21EAB7-AFC8-3C50-8480-E28823A5D4CB> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libmkl_core.dylib
                     0x155874000 -        0x155a46fff +libicui18n.dylib (0) <1B56F6C7-045A-3A03-99C1-57D1A91A7909> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libicui18n.dylib
                     0x155bf6000 -        0x155d3afff +libicuuc.dylib (0) <77E17D41-9214-3C2D-B526-CE0D81FAEC05> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libicuuc.dylib
                     0x155e0c000 -        0x155e1bfff +libv8_libbase.dylib (0) <7CD26441-BBE7-3BFF-9935-7BCC739ADE37> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8_libbase.dylib
                     0x155e35000 -        0x155e40fff +libv8_libplatform.dylib (0) <9EA88668-D5D6-3FC1-B9C6-CE1E53D228CE> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8_libplatform.dylib
                     0x155e53000 -        0x156902ff7 +libv8.dylib (0) <1A68B9C1-DC1C-3A70-83A4-73890130CAF9> /Applications/Adobe Premiere Pro CC 2018/Adobe Premiere Pro CC 2018.app/Contents/Frameworks/libv8.dylib
                  0x7fff8e0e7000 -     0x7fff8e42cff7  com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                  0x7fff8fc5e000 -     0x7fff8fc62ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <00D11B5C-E29F-3938-A8DD-D40A26201821> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                  0x7fff8fc63000 -     0x7fff8fe24fff  com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                  0x7fff8fe25000 -     0x7fff8fec7ff7  com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
                  0x7fff8ff92000 -     0x7fff8ff92fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                  0x7fff8ff93000 -     0x7fff8ffaaffb  libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                  0x7fff8ffab000 -     0x7fff904c4feb  com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                  0x7fff904c5000 -     0x7fff90636ff3  libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                  0x7fff90637000 -     0x7fff9064bffb  libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
                  0x7fff9064c000 -     0x7fff90a42fef  libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                  0x7fff90a43000 -     0x7fff90a59fff  libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                  0x7fff90a5a000 -     0x7fff90a60fff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libQuadrature.dylib
                  0x7fff90a61000 -     0x7fff90a75ff7  libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                  0x7fff90a76000 -     0x7fff90bfdfe7  libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                  0x7fff90bfe000 -     0x7fff90cb0fff  libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                  0x7fff90cb1000 -     0x7fff90cb1fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                  0x7fff90f70000 -     0x7fff91d49ff3  com.apple.AppKit (6.9 - 1504.83.101) <12BF4F22-5FDE-309E-8A19-BC97CC293D46> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                  0x7fff91d5b000 -     0x7fff91d5bfff  com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                  0x7fff91d5c000 -     0x7fff91dcaff7  com.apple.ApplicationServices.ATS (377 - 422.3) <73C230CF-3213-3DCA-B528-664FEC76A90C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                  0x7fff91e64000 -     0x7fff91f93fff  libFontParser.dylib (194.13) <BE507D17-17D0-37E8-A317-6921118BD283> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                  0x7fff91f94000 -     0x7fff91fdefff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                  0x7fff9203b000 -     0x7fff9206efff  libTrueTypeScaler.dylib (194.13) <F982F582-E2C8-3902-9C79-BB3F4B8199D2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
                  0x7fff920db000 -     0x7fff92185ff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                  0x7fff92186000 -     0x7fff921d7fff  com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                  0x7fff921d8000 -     0x7fff921e7ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                  0x7fff921e8000 -     0x7fff92235fff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                  0x7fff92236000 -     0x7fff92271fff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                  0x7fff92272000 -     0x7fff9227dfff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                  0x7fff9227e000 -     0x7fff9248aff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <AF56E94D-5F38-3718-99A3-D23BA0B56BA9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                  0x7fff9248b000 -     0x7fff9248bfff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <860636FF-F3B1-32AB-BD6E-75357FB16625> /
