7 Replies Latest reply on Sep 25, 2018 4:25 AM by abhishekg98410891
    Target Recommendation Feed Via URL
    abhishekg98410891 Level 1
      1. In the create Feed section, if instead of FTP, we select URL than which URL we should have it? Could it be URL of AEM DAM if we save our file there?
        • 1. Re: Target Recommendation Feed Via URL
          Raag Shanker Adobe Employee
          HI Abhishek,
          As long as the feed contains data in the right format and the URL does not require authentication you should be good to go. However if the URL requires authentication then you should opt for FTP because I don't think we setup credentials for URL method.
          Hope that helps.
          Raag
          • 2. Re: Target Recommendation Feed Via URL
            Hi Shanker,
            As in the recommendation Feed sample by Adobe, first column is for "## RECSentity.id"
            Could you please let me know, what different datatypes are possible in "## RECSentity.id"? i.e Alphanumeric/numeric/character etc.??
            Could we use Page URL in  "## RECSentity.id"?
            • 3. Re: Target Recommendation Feed Via URL
              tanvia28417128 Adobe Employee
              Hi Abhishek,
              Entity ID is the product ID which is used to identify the products uniquely on the page. It can be Alphanumeric but not suggested to be a URL. You can refer below document for more details on entity ID
              Entity Attributes
              Hope that helps.
              Tanvi
              • 4. Re: Target Recommendation Feed Via URL
                Hi Shanker
                I tried uploading a feed via URL approach
                Below are the steps I took
                In the Publish instance of AEM DAM I uploaded a .csv file (feedwomenpage.csv).
                PFB URL of feed http://localhost:4503/content/dam/we-retail/feedwomenpage.csv
                Feed is available, if I check putting this URL in chrome browser
                (I created a sample feed after downloading the format from Adobe Target console itself)
                I provided this URL in Adobe Target console, in creation of feed section via csv and URL
                In schedule section, I scheduled it for daily, and provide time after 5 minutes of the time when I created this
                It does not ask for any mapping, environment all host groups and I saved it
                The Feed status Changes from Waiting for downlaod --> Unknown Error (PFA image of error)
                Kindly help me in understanding, where I am going wrong, Why this "Unknown Error" is coming??
                • 5. Re: Target Recommendation Feed Via URL
                  Tanvi
                  • 6. Re: Target Recommendation Feed Via URL
                    Hi Abhishek,
                    The URL seems to be a local host which cannot be accessed externally. Could you please upload the feed on a URL which is accessible over the internet without authentication.
                    The unknown error is most likely being caused because recommendation is not able to access the local host
                    Raag
                    • 7. Re: Target Recommendation Feed Via URL
                      Hi Shanker,
                      Hope you are doing great !!
                      My query is
                      I have two separate product lines
                      The recommendation activity which I want to run for these two different product lines is on their respective product pages
                      The few details which got displayed (look and feel) about these products is also different
                      In such a scenario,
                      Do I need to take one combined feed for both type of products from AEM OR should I take two separate feed from AEM. One for each type of product??
                      If there are two feeds, then will these two feed update the same space in recommendation catalog?? OR we can also do a separation between recommendation catalog for these two product lines??
