2 Replies Latest reply on Apr 16, 2008 12:30 AM by blslusser
    Changing Accordion Buttons
    mchtower Level 1
      Is there a way to style an accordion so that each accordion button is a different color?
        • 1. Re: Changing Accordion Buttons
          blslusser
          I'm having the same problem here. I think if you extend "AccordionHeader" and make a component in action script for each button, setting the "headerStyleName" to an image or using code to style it, you can put them in the accordion. Where and how I haven't figured out yet, but that's my first suggestion.
          Otherwise, I'd try to extend "headerRenderer" and use getHeaderAt( //index ) somehow. I think this is the way to go, but I haven't figured out exactly how just yet.
          • 2. Re: Changing Accordion Buttons
            blslusser Level 1
            I want to try "getHeaderAt( //index ).setStyle( "fillColors", ["#uint , #uint"] );"
            I think this kinda works, you still can't put an image as the background or have rounded corners at the top and normal corners at the bottom. That's the hard part, putting rounded corners at the top and right angle corners at the bottom.
