7 Replies Latest reply on Sep 7, 2018 11:37 AM by Per Berntsen
    photos change color/saturation after export
    tylers57065931
      Screenshot (46).pngwhen I went to export my photos (jpeg w/ srgb) they looked fine on my laptop screen but when I go to put them on the web they become washed out and not what I originally edited. then when I go back to LR they've changed colors even though the develop sliders are the same (see example below).  I thought it was maybe my monitor calibration but they look how I intended on my phone as well.  I changed no export settings this time but I did however add some copyright metadata as well as delete the camera metadata. I have no idea what went wrong and i really don't want to edit all my photos again, some help would be greatly appreciated.
        • 1. Re: photos change color/saturation after export
          Akash Sharma Adobe Employee
          Hi tylers57065931,
          Sorry that your exports from Lightroom are looking color washed on other devices and web.
          What color space are you exporting your pictures in? Looks like you're using AdobeRGB or ProPhotoRGB, and the windows desktop wallpaper feature is not color managed.
          Try exporting in sRGB and also provide us a screenshot of your export settings.
          Akash
          • 2. Re: photos change color/saturation after export
            tylers57065931 Level 1
            Hi Akash,
            Thank you for getting to me. I am editing in the pro photo color space but exporting as an srgb (see screenshot below). the exports look fine on my computer (the right image on the original post) but when i put them on photos or flickr they wash out. and now in LR it is showing that washed out image (left image in original post) even though it exports as the way i editied it. so i want to know how my images could have changed color within lr just after an export and how to put my photos online without them washing out.
            Thanks so much,
            Tyler
            • 3. Re: photos change color/saturation after export
              Per Berntsen Adobe Community Professional
              So are you saying that your screenshot from LR shows wrong colors (and that LR displayed correct colors previously), and the screenshot from the Photos app shows correct colors?
              If so, you probably have a defective monitor profile, probably delivered by a Windows update. Since Photos is not color managed, and doesn't use the monitor profile, it would be unaffected.
              Try setting the monitor profile to sRGB.
              Go to Control Panel > Color management.
              First make sure that Use my settings for this device is checked. Then add the sRGB profile, and set it as default.
              Relaunch Lightroom for the change to take effect.
              If this fixes the issue, you should ideally calibrate the monitor with a hardware calibrator.
              • 4. Re: photos change color/saturation after export
                And here's a screenshot:
                2 people found this helpful
                • 5. Re: photos change color/saturation after export
                  Hi Per,
                  Thanks for the fix on how to change back the lightroom color profile all my pictures are now as i edited them.  However im still having the problem where when i upload the exported jpegs to google photos or flickr the thumbnail appears in full color but when you enlarge the picture it continues to wash out. My export settings have not changed from the pictures above. The picture below shows the correct edit in lightroom and a washed out example on google photos.  Is the problem more on googles end or somewhere in my Lightroom export settings?
                  • 6. Re: photos change color/saturation after export
                    thedigitaldog MVP & Adobe Community Professional
                    What browser are you using? Even with sRGB, if it isn't color managed, it will not match Lightroom. And you should always compare in Develop at 1:1.
                    • 7. Re: photos change color/saturation after export
                      You seem to be using Firefox, which is not color managed by default.
                      To enable color management, open a new tab, and type about:config in the address field and press Enter.
                      Then type gfx.color_management.mode in the search field and press Enter.
                      Double click the line with gfx.color_management.mode and in the dialog that appears, change 2 to 1 and click OK.
                      Now restart Firefox and see if the image displays correctly.
                      As for other web browsers, Chrome and Opera are color managed out of the box.
                      Internet Explorer and Edge are not color managed, and should be avoided.
