This content has been marked as final.
Show 3 replies
1. Re: Disabling Fields based on radio button
Newsgroup_User Feb 7, 2008 6:55 PM (in response to trojnfn)<form action="" method="get" name="myForm" id="myForm">
<input type="radio" name="quantity_type" value="None Given"
onclick="document.myForm.quantity.disabled = true">
<input type="radio" name="quantity_type" value="Single Lot"
onclick="document.myForm.quantity.disabled = false">
<input type="text" name="quantity" id="input1" disabled="disabled">
<input type="radio" name="quantity_type" value="Multiple Lots"
</form>
no need for the <script> block
Ken Ford
Adobe Community Expert - Dreamweaver
Fordwebs, LLC
http://www.fordwebs.com
"trojnfn" <webforumsuser@macromedia.com> wrote in message
news:fog6ig$kj5$1@forums.macromedia.com...
>I have three radio buttons and one input field. The input field corresopnds
>to
> button 2 only, and buttons 1 and 3 are just by themselves. What I want to
> do is
> if buttons 1 or 3 are selected, then the input field for button two should
> be
> disabled/grayed out. If they change their mind and check button 2 instead,
> then
> it should be enabled/white out, to accept an entry. What is happening is
> when I
> check buttons 1 or 3, the input field does become gray. But when I click
> on
> button 2, the input field remains gray/disabeld, and I am not sure how to
> enable it again. I think it is something simple but I just cannot see it.
> Please help, thanks Here is my javascript below, and the radio buttons :
> <script type='text/javascript'> function enableFields(fieldList) { var
> fieldArray = fieldList.split(','); // disable all fields for (var i=1;
> i<=1; i++) { document.getElementById('input1').value = ''; // clear out
> the value first (optional) document.getElementById('input1').disabled =
> true; document.getElementById('input1').style.backgroundColor='gray'; }
> // enable the fields passed to the function for (var i=0;
> i<fieldArray.length; i++) { document.getElementById('input' +
> fieldArray ).disabled = false; document.getElementById('input' +
> fieldArray).style.backgroundColor='white'; } } </script> <td
> valign='top'> <input type='radio' name='quantity_type' value='None Given'>
> None
> Given<br> <input type='radio' name='quantity_type' value='Single Lot'
> onclick='enableFields('1');'> Single Lot with Quantity : <input
> type='text'
> name='quantity' id='input1' disabled='true'><br> <input type='radio'
> name='quantity_type' value='Multiple Lots'> Multiple Lots (Specifiy
> quantities
> in Additional Information Box) </td>
2. Re: Disabling Fields based on radio button
trojnfn Feb 7, 2008 8:09 PM (in response to Newsgroup_User)Hello Ken,
Thanks for your help. Your method works great and does what I want it to do.
With your method, is there any way to actually gray out the input box to disable it ? It does not matter to me because it works, but the user wants to disable the input by making it gray, so that there will be absolutely no confusion.
Will that involve the javascript ?
Thanks for your help. -
3. Re: Disabling Fields based on radio button
Newsgroup_User Feb 8, 2008 5:20 AM (in response to Newsgroup_User)<script type="text/javascript">
function doDisable() {
document.myForm.quantity.style.backgroundColor = '#666666';
document.myForm.quantity.disabled = true;
function doEnable() {
document.myForm.quantity.style.backgroundColor = '#FFFFFF';
document.myForm.quantity.disabled = false;
</script>
onclick="doDisable()">
onclick="doEnable()">
<input type="text" name="quantity" id="quantity" disabled="disabled"
style="background-color:#666666">
</form>
BTW you need to change id="input1" to id="quantity" on the text input,
missed that before.
Ken Ford
Fordwebs, LLC
news:fogklv$4uv$1@forums.macromedia.com...
> Hello Ken,
> do.
> to
> confusion.
