2 Replies Latest reply on Feb 7, 2008 9:54 AM by vatodelaville
    exporting png to html and file renaming
    vatodelaville
      After working on the png file in fireworks and exporting the html to the original file, many of the images have been renamed, but not all. This is making it difficult to organize the required files before uploading to the website. Perhaps I am missing a vital concept here. I have put the images that I work with in the folder that I have the page that I am working on. I thought this would help. Does fireworks rename everything after you insert it? Is there a better bookkeeping method of which I am ignorrant for storing the files in the right place? I would like to upload only the files relevant to the page if possible and leave the rest behind. Sorry for the multiple questions and thanks for the advice.
        • 1. Re: exporting png to html and file renaming
          Level 7
          Fireworks only renames sliced images, and this is based on your input in
          the slice name box in the Property Inspector. If you have exported areas
          that are not sliced, FW will use the default naming convention and
          default optimization settings.
          Not sure exactly what you mean. What are you inserting and where are you
          inserting it?
          > Is there a better bookkeeping method of which I am ignorant for storing the
          Exporting your slices to your images folder within your main site folder
          is the simplest method. Complex sites may have sub folders in the image
          directory for different areas of the site.
          If you are working with DW for page creation, make sure you have a site
          defined. This should help, because DW prompts you to upload dependent
          files when you upload an html page. It will leave behind any images that
          are not directly linked to the page.
          HTH
          Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
          http://www.communityMX.com/
          CommunityMX - Free Resources:
          http://www.communitymx.com/free.cfm
          .:Adobe Community Expert for Fireworks:.
          http://tinyurl.com/2a7dyp
          See my work on Flickr
          http://www.flickr.com/photos/jim_babbage/
          • 2. Re: exporting png to html and file renaming
            vatodelaville Level 1
            thanks, I'm diving in again...
