I have an excel file like so:
Order | WO | Design | Qty | |
2551364 | 1 | 1248680 | 1 | |
2551365 | 2 | 1248681 | 3 |
I am exporting the file to a tab-delimited txt file.
I want to be able to make variables from this data like:
var order = ??;
var wo = ??;
var design = ??;
var qty = ??;
Some of my excel files can get up into the thousands and i want to be able to change the variables above for each row then run a function for every row.
Found this post but cant seem to get it working with the ptArr array.
Re: Excel data to construct illustrator object
From that post the ptArr array gives the x,y coordinates of the "cell" i am looking for.
How can i reference this so var order = ptArr(0,0); , var wo = ptArr(0,1); etc?
I feel like every time I post a question here i answer it myself like an hour later.
Used the grid[row][column] as coordinates to the text document to get what i wanted.
#target illustrator
function test(){ // enclosing function wraps the body of the script
if(app.documents.length < 1){ // this makes the script exit when there are no documents open
return;
var f = File.openDialog("Choose a CSV file.", "*.txt"); // choose a file with a .txt extension in Windows
if(!f){
return; // exit script if the Cancel button was pressed
var gridStr;
f.open('r');
gridStr = f.read(); // read the contents of the .txt file into a string variable
f.close();
var grid = gridStr.split(/[\n\r]/); // turn the text into groups of rows by splitting the text by nextlines or carriage returns
for(var i=0; i<grid.length; i++){ // go through each of the row groups and turn them into groups of cells by splitting with tab characters
grid = grid.split(/\t/g);
var doc = app.activeDocument; // set the active document to a variable
var ptArr = [], thisRow, x, y; // process the spreadsheet array to eliminate blank or incomplete rows
for(var i=1; i<grid.length; i++){
if(typeof(grid[1]) == "undefined" || typeof(grid[2]) == "undefined" || grid[1] == "" || grid[2] == ""){
continue; // if there are blank or missing cells where the x or y points should be, ignore this row
thisRow = grid;
x = thisRow [1].toString().replace(/"/g, '').replace(",", ".") * 1; // convert any nordic cells to numbers by removing any excel-generated quotes and replacing commas with periods, then cast to number by multiplying times one
y = thisRow [2].toString().replace(/"/g, '').replace(",", ".") * 1;
ptArr.push([x, y]); // add the processed coordinate point to array
var order = grid[0];
var wo = grid[2];
var design = grid[3];
var qty = grid[22];
alert(order);
alert(wo);
alert(design);
alert(qty);
test();
Thanks!
that's great, I like you're still trying to do it on your own while you wait.
