1 Reply Latest reply on Feb 7, 2008 1:32 PM by mike_morearty
    Debugger can't see XML variable data
    FredMB Level 1
      I took a small app over from Flex 2 (really simple, load myxml.xml from the local directory and display contents into a textarea field).
      var pXML:XML = new XML( event.result.myRootNode );
      textArea.text = pXML.toXMLString();
      When I hit a breakpoint in Flex 2, I am able to traverse the XML nodes in the Variables window and see child xml. In Flex 3, I only get "[object Object]" for my variable. I can see the nodes in 'event.result', and there seems to be a new "object" tree as well as the 'node.ObjectProxy@...' in that.
      In Flex 2 the textArea shows the xml document, in Flex 3 it shows "[object Object]"
      Ideas? Much appreciated if so.
