I started a film project over a year ago, and my hard drive with the project broke. I managed to have a technician recover the data, but now my film project is on a separate drive and a lot of problems are happening. I need to restart my computer every time I want to render. The app keeps crashing when I try to close it, so I always have to force quit. Additionally, when I try to save the project, it says that I am unable to and tells me to "check write permissions". So I always need to create a new file every time I save the project. It's possible that these problems are caused by the fact that these videos are all shot in 4K. I know a project like this requires a high RAM, but I use the 15-inch Macbook Pro with the touchbar, which I think should be good enough.
Here is some more information:
Update: I uninstalled and reinstalled Premiere Pro, and that has somehow caused a change, allowing me to render. I will see if I can export with no issues.
Try creating a new project and import your sequence via the Media browser. See if this solves any of the issues you describe and then work from there.
I tried, but I only get to the stage where the project is being loaded; I cannot select the sequence to import.
A few seconds after I closed the import tab, Premiere Pro started crashing. I got the message: "Sorry, a serious problem has occurred that has required Premiere Pro to shut down."
Try creating a new project and then manually copy and paste the sequences or the contents of the sequences from the old project to the new project.
If that doesn't work, try resetting the preferences:
FAQ: How to reset preferences in Premiere Pro?
If that doesn't work, try resetting the Workspaces:
Reset a workspace
Reset the current workspace to return to its original, saved layout of panels.
- Do one of the following:
- Click the Workspace menu icon and select Reset to Saved Layout.
- Choose Window > Workspace > Reset to Saved Layout.
from here:
https://helpx.adobe.com/premiere-pro/using/workspaces.html
Try this, Dannes Z: Premiere Pro CC, CC 2014, or 2014.1 freezing on startup or crashing while working (Mac OS X 10.9, an...
Let us know if it works.
Kevin
Thank you for your advice! I didn't end up using those instructions, since uninstalling and reinstalling the app seemed to do the trick. Miraculously, all my issues have disappeared, and I am more than elated!
