0 Replies Latest reply on Sep 13, 2018 8:33 AM by saurabh08tiwari
    Hi I am moving an asset at that time while moving the asset one unique id generating so according to my requirement is after moving an asset I have to send notification to the owner so in that I have to send that moving asset unique id ,so after moving th
    saurabh08tiwari
      public class MoveAssetTmpToOriginalPath implements WorkflowProcess {
         private static final Logger LOGGER = LoggerFactory.getLogger(MoveAssetTmpToOriginalPath.class);
         @Reference
         private SessionService sessionService;
         private ResourceResolver resourceResolver;
         @Reference
         private MailService mailer;
         @Reference
         private UserPropertiesService userPropertiesService;
         @Override
         public void execute(WorkItem workItem, WorkflowSession workflowSession, MetaDataMap args) throws WorkflowException {
         try {
         resourceResolver = getSessionService().getReadServiceResourceResolver();
        WorkflowData workflowData = null != workItem ? workItem.getWorkflowData() : null;
        String tempPath = null != workflowData ? workflowData.getPayload().toString() : null;
        String[] tempPathSplt = null != tempPath ? tempPath.split("/") : null;
        String replctAsstName = null != tempPathSplt ? tempPathSplt[tempPathSplt.length - 1] : null;
         if (StringUtils.isNotEmpty(tempPath)) {
        Resource resource = resourceResolver.resolve(tempPath);
        Node tempAsstNode = resource.adaptTo(Node.class);
         if (tempAsstNode != null && tempAsstNode.hasNode(WorkflowConstants.JCR_CONTENT)) {
        Node jcrNode = tempAsstNode.getNode(WorkflowConstants.JCR_CONTENT);
        String asstReplctKey = getReplicatAssetKey(jcrNode);
        String assetReplctPath = getAssetReplctPath(resourceResolver, asstReplctKey) + "/" + replctAsstName;
        moveReplicateAsset(tempPath, assetReplctPath);
        Thread.sleep(30000);
        sendNotificationMail(resourceResolver, assetReplctPath);
        } catch (Exception e) {
         LOGGER.error("Exception occured while executing {}", e);
         private String getAssetReplctPath(ResourceResolver resourceResolver, String asstReplctKey) throws RepositoryException {
        String result = WorkflowConstants.CONTENT_DAM_INTEL_DIGITAL_LIBRARY_SOURCE;
         try {
        Resource resource = resourceResolver.resolve(WorkflowConstants.ETC_PROPERTIES_REPLICATED_ASSET_PATH);
        Node mapnode = resource.adaptTo(Node.class);
         if (null != mapnode && mapnode.hasProperty(WorkflowConstants.DESTINATION_PATH)) {
        Value[] destArray = mapnode.getProperty(WorkflowConstants.DESTINATION_PATH).getValues();
        result = getDestPath(asstReplctKey, result, destArray);
         LOGGER.error("An Exception occurred while getAssetReplctPath!! {}", e);
         return result;
         private static String getDestPath(String asstReplctKey, String result, Value[] destArray) throws RepositoryException {
        String val = result;
         for (Value destArrayValues : destArray) {
        String destintonPthKeyValu = destArrayValues.getString();
        String[] destValue = destintonPthKeyValu.split("=");
         if (destValue[WorkflowConstants.ZERO].equals(asstReplctKey)) {
        val = destValue[WorkflowConstants.ONE];
         break;
         return val;
         private void moveReplicateAsset(String tempPath, String assetReplctPath) throws WorkflowException {
         try {
        AssetManager assetManager = resourceResolver.adaptTo(AssetManager.class);
        Session session = resourceResolver.adaptTo(Session.class);
         if (null != assetManager && null != session) {
        assetManager.moveAsset(tempPath, assetReplctPath);
        session.save();
        session.refresh(true);
         LOGGER.error("An Exception occurred while moveReplicateAsset!! {}", e);
         private void sendNotificationMail(ResourceResolver resourceResolver, String assetReplctPath) {
        Resource resource = resourceResolver.resolve(assetReplctPath);
        Node replictdPathNode = resource.adaptTo(Node.class);
         try {
         if (replictdPathNode != null && replictdPathNode.hasNode(WorkflowConstants.JCR_CONTENT)) {
        String assetOwnerFullName = getAssetOwnerFullName(replictdPathNode);
        String title = getAssetTitle(replictdPathNode);
        String uniqueId = getUniqueId(replictdPathNode);
        String ownerEmail = getAssetOwnerEmail(replictdPathNode);
        sendSubNotifctionToAssetOwner(ownerEmail, resourceResolver, title, assetReplctPath, uniqueId, assetOwnerFullName);
         LOGGER.error("An Exception occurred while sendNotificationMail!! {}", e);
         private static String getReplicatAssetKey(Node jcrNode) {
         try {
         if (null != jcrNode && jcrNode.hasProperty(WorkflowConstants.DEST_KEY)) {
         return jcrNode.getProperty(WorkflowConstants.DEST_KEY).getString();
         LOGGER.error("An Exception occurred getReplicatAssetKey!! {}", e);
         return "";
         private static String getAssetOwnerEmail(Node node) {
        String assetOwnerEmailId = "";
         try {
         if (node.hasNode(WorkflowConstants.JCR_CONTENT)) {
        Node jcrNode = node.getNode(WorkflowConstants.JCR_CONTENT);
         if (jcrNode.hasProperty(WorkflowConstants.EMAIL)) {
        assetOwnerEmailId = jcrNode.getProperty(WorkflowConstants.EMAIL).getString();
         LOGGER.error("Exception occured while getAssetOwnerEmail", e.getMessage(), e);
         return assetOwnerEmailId;
         public SessionService getSessionService() {
         return sessionService;
         private void sendSubNotifctionToAssetOwner(String ownerEmail, ResourceResolver resourceResolver, String title, String assetReplctPath, String uniQueID, String assetOwnerFullName) throws LoginException, RepositoryException {
        ConcurrentMap<String, String> parameters = new ConcurrentHashMap<>();
        parameters.put(WorkflowConstants.SUBJECT, WorkflowConstants.ASSET_MOVE_INTEL_BOX_TO_INTEL_DIGITAL_LIBRARY);
        parameters.put(WorkflowConstants.ASSET_PATHS, assetReplctPath);
        parameters.put(WorkflowConstants.ASSET_TITLE, title);
        parameters.put(WorkflowConstants.UNIQUE_ID, uniQueID);
         LOGGER.debug("uniQueID::{}",uniQueID);
        parameters.put(WorkflowConstants.ASSET_OWNER_FULL_NAME, assetOwnerFullName);
        parameters.put(WorkflowConstants.TEMPLATE_ROOT_PATH, WorkflowConstants.REPLICATED_ASSET_NOTIFICATION_TO_OWNER);
        AssetMailHelper assetMailHelper = new AssetMailHelper();
         try {
        assetMailHelper.sendHtmlMail(resourceResolver, getMailer(), Collections.singletonMap(ownerEmail, ownerEmail), parameters, userPropertiesService);
         LOGGER.error("Exception occured while executing mail{}", e);
         private static String getAssetTitle(Node node) {
        String assetTitle = "";
         try {
         if (node != null && node.hasNode(WorkflowConstants.JCRCONTENT_METADATA)) {
        Node metadata = node.getNode(WorkflowConstants.JCRCONTENT_METADATA);
         if (metadata != null && metadata.hasProperty(WorkflowConstants.TITLE)) {
        assetTitle = metadata.getProperty(WorkflowConstants.TITLE).getString();
         LOGGER.error("Exception occured while getAssetTitle", e);
         return assetTitle;
         private static String getUniqueId(Node replictdPathNode) {
        String uniqueId = "";
         try {
         if (replictdPathNode.hasNode(WorkflowConstants.JCRCONTENT_METADATA)) {
        Node metadata = replictdPathNode.getNode(WorkflowConstants.JCRCONTENT_METADATA);
         LOGGER.debug("metadata getUniqueId::{}",metadata.getPath());
         if (metadata.hasProperty(WorkflowConstants.UNIQUE_ID)) {
        uniqueId = metadata.getProperty(WorkflowConstants.UNIQUE_ID).getString();
         LOGGER.error("Exception occured while getUniqueId", e.getMessage(), e);
         return uniqueId;
         private static String getAssetOwnerFullName(Node node) {
        String assetOwnerFullName = "";
         try {
         if (jcrNode.hasProperty(WorkflowConstants.ASSET_OWNER_FULL_NAME)) {
        assetOwnerFullName = jcrNode.getProperty(WorkflowConstants.ASSET_OWNER_FULL_NAME).getString();
         LOGGER.error("Exception occured while getAssetOwnerFullName", e.getMessage(), e);
         return assetOwnerFullName;
         public MailService getMailer() {
         return mailer;
         public void setSessionService(SessionService sessionService) {
         this.sessionService = sessionService;
