• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
3
Print file name on pdf
Community Beginner ,
Sep 13, 2018 Sep 13, 2018
how do I print the file name on a pdf?
Views
56.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Sep 14, 2018 Sep 14, 2018
Hi Sylviab,
From the 'Comment Tool', choose "Add Text Comment", add the file name, then print the PDF file.
For detailed information about printing comments, please refer to Adobe help article Print comments | Adobe Acrobat, Reader
Anand Sri.
[Edited Response]
Votes
Translate
Translate
Adobe Employee ,
Hello Sylviab,
As per the description above, you want to print the file name on the PDF, Is that correct?
With the freeware Adobe Reader, you can use Comment Tool to add a sticky note, add the file name, then:
  • Go to Comments and then to the option icon
  • Go to Comments preferences
  • Mark "Print notes and pop-ups".
With paid version of Acrobat, you can use the Header and Footer tool to add the file name in the PDF and print it. For detailed information, you can refer to Adobe article Add headers, footers, and Bates numbering to PDFs, Adobe Acrobat
You can also add custom JavaScript in Acrobat to print the file name on PDF. You can refer to the Adobe discussion and try the suggestions Print File Name with pdf Document
In Pro DC, how to print filename in footer of pdf?
How do I add the file name to a pdf printout using Adobe Acrobat Pro DC?
Feel free to update this discussion for further assistance.
Anand Sri.
Votes
Translate
Translate
Report
Report
Thanks Anand, I was able to add the comment to the document, and I enabled the option to print comments, but the text doesn't print, it only prints the speech bubble icon.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hello Sylviab,
In the Print Dialog box, under Comments & Forms, please select 'Document and Markups' and print the PDF.
Anand Sri.
Votes
Translate
Translate
Report
Report
Thanks Anand, but it still only prints the speech bubble.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi Sylviab,
Anand Sri.
[Edited Response]
Votes
Translate
Translate
Report
Report
Community Expert ,
You're using the wrong commenting tool...
Votes
Translate
Translate
Report
Report
Got it!  Thanks
Votes
Translate
Translate
Report
Report
Sep 07, 2020 Sep 07, 2020
I need to do this with 1700 PDFs in a folder. They all need to have the filename in the same spot, and the same text format.
Is there a way I can batch this?? I'm hoping so...
Votes
Translate
Translate
Report
Report
Community Expert ,
May be possible with Adobe Acrobat Pro and Action Wizard.
Votes
Translate
Translate
Report
Report
Community Expert ,
Sep 08, 2020 Sep 08, 2020
Certainly not with Reader. You can do it in Acrobat Pro using an Action and a script, though.
Votes
Translate
Translate
Report
Report
Unfortuntaely not. Well, partially. I have to press Enter for each file.
Votes
Translate
Translate
Report
Report
Community Expert ,
Make sure to un-tick the "Prompt User" box under each command it appears.
Votes
Translate
Translate
Report
Report
New Here ,
Jan 29, 2021 Jan 29, 2021
With my Epson printer - select print - select properties - selct more options - select waternmark features - select header/footer then simply select what you want from the drop downs. Simples.
You can then add this as a preset on your more options page.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
That's great, but not all printers have such a functionality.
Votes
Translate
Translate
Report
Report
