11 Replies Latest reply on Sep 16, 2018 11:20 PM by arjuns71585267
    Cannot access the AEM homepage:error
    arjuns71585267 Level 1
      Hi please help with the following error on startup of AEM on port number 4503
      org.apache.sling.scripting.sightly.SightlyException: org.apache.sling.scripting.sightly.SightlyException: Compilation errors in org/apache/sling/scripting/sightly/apps/core/wcm/components/page/v2/page/page_html.java: Line 33, column 1378 : Syntax error, annotations are only available if source level is 1.5 or greater Line 47, column 1974 : The method call(String, Object[]) in the type RenderContext is not applicable for the arguments (String, String, RenderUnit.FluentMap) Line 48, column 2045 : The method call(String, Object[]) in the type RenderContext is not applicable for the arguments (String, String, RenderUnit.FluentMap) Line 49, column 2109 : The method call(String, Object[]) in the type RenderContext is not applicable for the arguments (String, String, RenderUnit.FluentMap) Line 50, column 2177 : The method call(String, Object[]) in the type RenderContext is not applicable for the arguments (String, String, RenderUnit.FluentMap) Line 55, column 2392 : The method call(String, Object[]) in the type RenderContext is not applicable for the arguments (String, Object, String) Line 57, column 2488 : Incompatible conditional operand types Object and boolean Line 61, column 2806 : The method equals(Object) in the type Object is not applicable for the arguments (boolean) Line 87, column 3723 : The method call(String, Object[]) in the type RenderContext is not applicable for the arguments (String, Object, String) Line 89, column 3819 : Incompatible conditional operand types Object and boolean Line 93, column 4138 : The method equals(Object) in the type Object is not applicable for the arguments (boolean) Line 124, column 5849 : The method call(String, Object[]) in the type RenderContext is not applicable for the arguments (String, String, RenderUnit.FluentMap) Line 129, column 6103 : The method call(String, Object[]) in the type RenderContext is not applicable for the arguments (String, String, RenderUnit.FluentMap) Line 145, column 6851 : The method call(String, Object[]) in the type RenderContext is not applicable for the arguments (String, String, RenderUnit.FluentMap)
      RequestURI=/content/we-retail/us/en.html
      Servlet= /apps/core/wcm/components/page/v2/page/page.html
      ApacheSling/2.6 (jetty/9.3.22.v20171030, Java HotSpot(TM) 64-Bit Server VM 10.0.2, Windows 10 10.0 amd64)
