4 Replies Latest reply on Sep 15, 2018 1:10 PM by jane-e
    check box form question
    craigb36097816 Level 1
      can i have a yes checkbox and a no checkbox
      and have it so the user can not check both?
      thanks
        • 1. Re: check box form question
          Sure. Just give them the same name but different export values.
          On 14 September 2018 at 22:57, craigb36097816 <forums_noreply@adobe.com>
          • 2. Re: check box form question
            jane-e Adobe Community Professional
            That's the idea of a radio button, which can be formatted with a checkmark. Checkboxes are generally used when you can choose more than one; radio buttons for selecting only one.
            • 3. Re: check box form question
              The problem with radio-buttons is that the selection can't be undone, unless you reset the form (which it turns out isn't even available in the Reader interface, so it has to be done through a button in the form itself, if the author created it). That's not the case with check-boxes, which is why it's usually better to use the latter.
              • 4. Re: check box form question
                That's a good point, Gilad. You could, technically, create a reset button that would only reset that set of radio buttons but that would probably add more confusion for the user and I don't especially recommend it.
                I hadn't thought of using the check box feature with the radio button function, but it's a great idea. I can't wait until it's time to create my next form so I can try it!
                ~ Jane
